ARP 100-7703
http://www.summitracing.com/parts/ARP-100-7703/
mine, 5/8" thick spacer per side, installed 6 years ago - zero issues
^Thanks!
I noticed with 35/12.5/15 new mtr/k's, on 3.5" bs wheels that on tighter turns they rub the coils just slightly, so I'm probably going to put like 1/2" spacers on.
Thanks for the link to the studs
I finally picked up an 8.8 this week and have been reading over this thread a number of times but had a few questions.
From what I gather, the ZJ rotors, calipers, and pads can all be moved over to the 8.8; however, the ZJ rotors are not compatible with the explorer calipers and vice-versa. I need new rotors either way, but am I better off using the ZJ calipers and buying ZJ rotors, or (if the 8.8 calipers are in good shape) using the 8.8 calipers and buying explorer rotors?
I take it the explorer parking brake setup works with either rotors?
I hope I didn't miss this info somewhere - any insight would be appreciated.
Cables work with both makes
I stuck with all zj brakes and don't have any complaints
I used the 8.8 brakes since my 35 had drums
Cool, thanks for the responses. I may go with ZJ brakes because they appear to be a little cheaper.
I'm currently putting all new parking brakes on my 8.8 that has my old zj's 35. Everything seems to be getting along. You can get performance brake stuff to help the little caliper/rotor combo stop a good deal better IMHO.
finished the e-brake install, figured I'd take some pics when doing the passenger side for anyone else who might need 'em
Safety note: wear safety glasses!! you will be playing around with springs that have a lot of stored energy once installed that could easily make you a better pirate!!!
heres what I started with, had to get the parking brake expander/lever thing from a salvage yard cause my 8.8 didn't even have that!
slide the lever in through the boot carefully
this is my stock parking brake cable fitting perfectly with the stock 8.8 brake stuff
general layout of how everything goes together sans the lever
I started by putting one of the big yellow springs on the back side of the shoes and then put them on, helps to keep the shoes pressed against the backing plate until you put the retaining pins in
now you put the adjustor in, make sure you'll be able to access it from the access hole in the backing plate for when you need to adjust your parking brakes
now its time for the retainers, these can be a real pain! It helped me to use a c-clamp to clamp the shoe to the backing plate and then use needle nose vice grips to compress the retaining spring while I used needle nose pliers to pull the pin through the retaining spring ( I made these terms up, dont know that theyre really called lol)
now you can put the other big yellow spring on, again the needle nose vice grips help a ton!
and last step, you place the short spring underneath the adjuster
Here's why I strongly recommend taking the axle shafts out to do this job: no room! and honestly, couldn't your 8.8 use some new lube love?
if you see anything I missed and should please don't hesitate to let me know.
So am I the only n00b with a stock muffler doing this swap? I swapped in the 8.8 this weekend and the driveshaft contacts the muffler. Time to relocate or replace I guess.
My exhaust stops before the rear axle
I did the swap with no exhaust problems, but it could be setup specific. I have a 93/4.0/249/Aw4 setup
