I found this and I think it is pretty cool. Really helps you to determine how you want to set your links up for your suspension.
http://mysite.verizon.net/triaged/fi...arLinkV3.0.zip
Helps to ask all those little questions that we often overlook while thinking about our suspension.
Cheers
Last edited by OverkillZJ; 10-30-2005 at 10:48 AM. Reason: Added new working link.
Awwwwesome Alaska. Were converting my friends 5-link long arms to a 4-link and that is exactly what we needed.
Brentt, or anyone else,
How do I figure COG.
Jason
Yours is too high!! :lol:Originally Posted by nmzj
Somehow or another you have to figure out the dispursion, if thats even a fawking word, lol, of the weight. I would say on most lifted ZJ's it's probably right around the firewall, at about the top of the tranny hump maybe, that's just a TOTAL guess though.
Alot of people use the top bolt on the bellhousing as thier COG. It's a pretty good estimate from what i've gathered.Originally Posted by nmzj
LOL I knew someone would say that...I plan to lower that...on a tubed buggy, would the COG be in the same/similar place?Originally Posted by BigDaveZJ
without taking the time to balance it in all three planes....you need to guestimate.
I too use my top bellhousing bolt. IMO it is a better to estimate it a little high and plan for that then estimate it low and find out on the trail.....the hard way.
I would think on a rig like Cody's, the COG would be a little lower and further forward, hence the endo last year. On the Chalupa it's probably a lot closer to a full bodied because there's more sheet metal and the cage structure more closely resembles the stock lines. Like if you take weight off the northwest corner of a compass, the COG is gonna move SE proportionate to the weight removed and the weight remaining.
I think the site is down. I've tried to use it a few times but it failed to load. I DID save the Excel formulas format and stuff and used it to build my suspension (and fine tune). It came out working very well.Originally Posted by Alaska ZJ
What tire size can I fit with those cool spinners and Eibach lowering springs?
:wink:
Do body lift pucks from a 1956 Dodge Power Wagon work on ZJ?
:wink: :wink:
Did mommy remember to pack my Prozac with my condoms?
:wink: :wink: :wink:
Link for version 2.0
http://home.earthlink.net/~triaged/F...latorV2.0a.zip
Now... Someone want to take the time to help define some of these returned values and what they mean?
Some of my numbers are looking really weird, and I don't know if they're good or my guestimates were really that bad.... :?
wow ya....that is definitly beyond me. I'd love tobe able to figure this out to help me with my rig.
gearhead, you need to have a 4 link rear for that to do anything for you. If i recall you have a 5 link (you still use the track bar) this will not work for you.
I will be doing a 4 link in the rear when i go to put my 14b up in.
sweet. shoot me a IM and i'l halp if ya need and info
wow, tell me all you guys understand that giberish. holy cow, thats confusing stuff
So what do you guys put down as your COG in the 4 link calculator? Yea yea I read the post and I can guestamate for myself but I wanted to see what you guys put in for yours.
Thats sweet. I love stuff like that. Somebody put some work into that. I don't suppose they are on this board?
The dude that makes the 4 link calc is putting out a new version. Aparently this new version can calculate the math on your full suspension cycle and tell you the antisquat/dive through the cycle (changes durring movement) as well as some other pretty trick things.
Is the new version out yet?
The beta is out... I don't know if he has all of the bugs worked out of it yet... I'll see if I can snag a link shortly
Here is version 3.0 i found on pbb. He changed the format alittle and added material and travel calulations and other poop.
The second link is the pbb thread. Paaeace.
http://home.earthlink.net/~triaged/...BarLinkV3.0.zip
http://www.pirate4x4.com/forum/showthread.php?t=204893
