just came across this, but thought i would say something any way. i did a 231 swap in my grand and hated it. it lasted about 2 monts. case and point.
http://i171.photobucket.com/albums/u...042308_112.jpg
i later found a 241 DLD out of a 3/4 ton dodge. it was a direct bolt in. i had to use the slip yoke off of the dodge shaft (didnt have the cash for a SYE kit) and a conversion joint, but every thing else just bolted in. the input gear is the same spline count as the grand, and the same length. even the front shaft is the same. the 241 uses a 6 planetary gear, and the mane shaft is 1/2" in diameter bigger.
Alright, I am picking up a newer 242 that has the 23 spline.
It has the electronic speedo.
My Heep is a 97, so the gear cut should be the same, but is there a diagram for wiring in the VIC?
Also is the speedo the same?
I am getting the case for cheap, and my 249 giving me crap.
Do they have different yoke sizes than stock zj's?
What vehicle does the case come from? If it's a WJ or XJ the yokes should be the same as your ZJ. I don't think 242s came in Wranglers (maybe the new ones do), but if it came from a wrangler you have to change the output yoke going to the front so it will fit the double cardan joint on your driveshaft. I believe you can rob it from your 249 and put it on there though if you really have to.
As far as the speedo goes- maybe someone else can answer that. When I put in my 231 I just swapped the speedo gear from the 249 and put it in the 231. Since yours is electronic it may not be that easy, but I'm not sure.
Do a search on the VIC. I think I remember you're supposed to take it out, disconnect the red wires and connect the 2 black wires or something. Someone's wrote about it though.
Good luck.
-RC
Almost true. TJ's have the same double cardan front driveshaft that ZJ's and XJ's use. Most WJ's to my knowledge used some bastardized booted CV joints, and probably different yokes too. Now on a YJ 231, you are partly correct as well. The yoke on the YJ 231 is for a single u-jointed shaft, but your 249 yoke will not mate up to the 231 output.
I'm doing the 231 swap on my ZJ too, and have a question about the rear driveshaft length. I searched, but I couldn't find anything with a clear answer.
I've got a '96 with the V8 & 2"bb with the 249/d44a rear, does anyone know the length of the rear driveshaft they used between a 231/d44a?
ZJ's never came with a 231 and a 44a. Some had the 231 when the ZJs first came out, but that was when they were still using a 35c rear axle. FWIW when I put my 249 right next to my 231 when I was swapping them, they're exactly the same length to the tailhousing. This was with a '88 231. Maybe some of the newer ones are shorter. I had no trouble with using my stock rear driveshaft though.
-RC
Not to be an a-hole, but the main reason so many do a 231 swap is so they have the aftermarket support of a true slip yolk eliminator...available for the 231, but sadly not the 242. My point being, get a SYE kit, then measure. If I recall correctly, my Tom Woods was 38 inches...from a 231 w/SYE to and old school d44.
I know how budgests go, and how money is tight...but if you are even remotely serious about this you will someday need a SYE, they are like $250 bucks, get it now.
If thats just not do-able, then you are just gonna have to see what might fit. I doubt you will find many who swap out t-cases before they swap the aluminum d44.
Forget the 231, buy one of my D300s instead.
To get back on topic, when I did the swap I had to shorten my driveshaft by 1". I was using a 231 out of a 96 XJ. Do the swap and see if you're gonna need a different length driveshaft, have someone shorten/lengthen it if needed, and so there is no down time just drive around in front wheel drive. Just take it easy if you do.
The 242 I am getting is out of a 2000 XJ with 55K miles on it!
Stupid question, but do you think I will need to change the yoke, or shorten/lengthen the driveshafts, front or rear with this swap?
I have a 97 with the 249.
Hopefully the front will be the same cause I just got a new shaft, hahaha
Also I probably will need to change the input shafts also right?
Thanks
I sure as hell hope I dont need to change the front DS, I just friggen bought this one, lol
I have a 231 with a Tera Low kit from a 97 TJ and would like to put it in a 98 5.9l ZJ. (TJ AX-15, ZJ 46RE)
I know the input shaft is too long and needs to be swapped to the shorter shaft. Can the shaft from the Tera Low be swapped with the shaft from the 249 to make it work?
My understanding is YES but wanted to get some ideas before tear-down.
Thanks
we may end up doing this..... depending on how it comes out....besides if we need to shorten it I know a good driveshaft shop off of 610 that I get my stuff done at
I'm helping him swap tcase 96 249->2001xj 231 since he has never done it before. right now his 231 is almost all put back together at my work b/c I took it apart to check to make sure the internals were all ok on a junkyard tcase.
ok sorry i dont have time to read the entire thing and i am in a time crunch. but i have the chance to buy a 231 out of a 94 zj with a 42re
i have a 94 with a 249 will it be a direct swap
I put in the 231 with a SYEafter blowing apart my 242 back in October... I absolutely LOVE it! My only problem, is that I don't have a "gate" for the 231 or the bezel, so I can't just yank on the handle.
You only pull it until it engages into the 4x4, then stop pulling.
The XJ gate didn't fit.
Anyone got suggestions? or even better, one that may fit?
Lemme know by PM please... Don't wanna threadjack this more that I already have.
Thanks guys!
how about using a 231 gate?
the 242 gate is the same thing too, yes I know they have different part numbers but I have held them side by side in my hands and there is no difference in dimensions of the length of the placement of the 4high nub.
Yo DJ, thanks for the help on the tcase inputs. It's been ages since you gave me some advice on the input lengths and you were right. I picked up a 97ish 231j and that bitch bolted right up to my 96 V8 ZJ. Have to have my driveshaft shortened. I'm not swapping in an 8.8 just yet. For reference my driveshaft length for my 96 V8 is supposed to be 31.75 ujoint center to ujoint center. That's with a RE 4.5 lift with adjustable arms so I'm sure some people's results might be different. Next up is to swap in that Clayton's kit that's been in my garage for ages.
Didn't I give you a ZJ transfer case shifter and linkage a couple years ago when I lived in Williamsville? If it's not you, then it was Cherokee. Either way, the gate included with the linkage was from a ZJ with a 231.
Regardless, I am struggling to see what your problem is? Do you not want to need to shift the tcase to the right to shift into 4LO? Did Eric change something with your shifter when he put in the 231?
no problem I actually did this swap on dp96zj (96 V8 44RE 249-> XJ 01 AW4 231) and it was the same as yours was with the same issue of needing to shorten the rear shaft. I also ran into one more thing during the swap that the nonadjustable shift linkage arm was too long and I had to shorten it by one inch but it was not a big deal after that.
Hey Jared!
Yeah that was me you gave the other linkage to...
You know, I didn't even think about thatgate. I'll have to check that out when I get home.
The problem is, that with no gate in there right now, the shifter is sloppy.
You pull it back to get it into 4WD, but only pull it until it "feels" like it goes in. If you don't pull it par enough or too far, it either sits in neutral, or grinds being between gears.
I'd like to be able to pull it until it stops, and know that it was in the correct gear.
You would still have to push it to the right and back to get into 4LO, but would prevent "missing" the 4WD gear.
It's not so much for me, but my dad and one of my friends who drove it have both had a problem with it. It's something that you need to get a "feel for" and for some people, that isn't an option.
I haven't messed with the shift linkage just yet so I'm not sure if everything will line up and work or not. I can manually shift it through the gears without it lining up but I'm not sure what it will feel like when I'm actually in the Jeep. I may have to buy that tab from the stealership.
