Thread: Project Hugs Version 4.0
Page 6 of 6 FirstFirst 123456
Results 126 to 135 of 135
  1. #126 Re: Project Hugs Version 4.0
    New OE mounts are NLA and aftermarket stock replacement are crap. I don't need Bomb Proof mounts, or even the poly inserts I've found. Is there any kind of solid rubber insert out there? Buy some cheap aftermarket mounts and fill the voids with window weld?
  2. #127 Re: Project Hugs Version 4.0
    The last time I did mine I used NAPA. They have been decent for me. I just figure that they are going to wear out with the torque and flex that we subject our vehicles to, and that these were good enough unless I wanted to upgrade significantly to the bomb proof ones.
    https://www.napaonline.com/en/p/DTT6...ut=motor+mount
    https://www.napaonline.com/en/p/BK_6...ut=motor+mount
  3. #128 Re: Project Hugs Version 4.0
    Thanks for the input, I was looking into those. We have an account with Napa at work, and even at that cost they're a good bit more than the average ones from Anchor, DEA, and Westar that all share pretty much the same part number. I did see that the Bomb Proof mounts do use a rubber isolator, which I like, but that's still a big pill to swallow, even vs the Napa ones. Maybe I'll just buy another cheap one for now, these mounts did see a lot of tweaking and stress during the trans swap. Once I get some more miles and some real offroad use on them maybe I'll be ready to spend some more $$.
  4. #129 Re: Project Hugs Version 4.0
    After putting a few commutes under my belt with the AX15 in I've determined the shifter could definitely use some more tweaking. I could modify the XJ shifter again, but I thought I'd look at my other options, like YJ, TJ, etc. In my research this morning I came across a comparison picture between a Jeep AX15 shifter base and a Dakota AX15 shifter base. What this reveals is that the Dakota has a taller shifter tower and more shifter below the pivot the point. Bingo! This looks like an affordable, available on the used parts market short shifter! I think I may track one of these down and give it a shot. It also looks like the TJ shifters may have the same taller tower and longer lever below the pivot.
    http://www.turbo-mopar.com/forums/ph...hp?photo=16925
  5. #130 Re: Project Hugs Version 4.0
    As always when dealing with an older vehicle, on to the next problem! Been battling a hard start/long crank situation since getting Hugs back on the roads. Coolant and intake temp sensors test good, fuel pressure is good with no immediate drop off, etc. I finally made a break through last night and looks like a spark issue. Crank sensor is new with the swap, plug, wires, cap and rotor are recent. I had no spark out of the coil, so I'm leaning towards a coil, and hopefully not the distributor. It smelled like fuel after a few rounds of cranking, so injector pulse seems to be good.
  6. #131 Re: Project Hugs Version 4.0
    Well, every time I've gone after it to diag the starting issue it's started. Sometimes it struggles a bit, but a little bit of throttle got it going. Spark tester is in place and will remain there for a while. I did grab a new cam position sensor at the yard over the weekend and threw it in. I also have Mopar crank sensor coming just for good measure. Figure I'll keep the aftermarket one in the spares kit.
    OTH hand I pulled the shifter and rotated the top half on the bottom half 90 degrees and it's in a much more natural position and less of a reach, now.
  7. #132 Re: Project Hugs Version 4.0
    Mopar crank sensor didn't fix the starting issue, and it kept getting worse. Finally it was consistent enough to diagnose it. I had printed out a bunch of wiring diagrams and with the help of those, and some really funky symptoms, I tracked down the issue. It was to the point where I'd turn the key on to start diag and things would click on and off repeatedly. I noticed the injectors doing it first, then realized the ASD relay was doing it, too. Consulted my diagrams and found they share a circuit that's switched by the ECU. Got lucky and scored a remanned ECU at the salvage yard for $40. Starts up nice and quick, now, every time.
    After I got that sorted I actually cleaned up the interior a little bit. Quick vacuum, spot cleaned a few nasty spots on the back seat, and cleaned the inside of the windows. I also put a fresh coat of RainX on the windshield. I think I'm going to pull the carpet in the cargo area and put down some bedliner. Half of those cheesy strips that are just clipped to the carpet are missing anyways.
    And here's how the shifter sits, now. First pic is in 1st gear, second pic is reverse.
  8. #133 Re: Project Hugs Version 4.0
    Replaced the leaking valve stem on the one wheel today. Also changed out the fluid in the trans. Did some research and found that GL5 gear oil is not good for the synchros in the trans, and it's what's most readily available these days. I'm not really sure what I grabbed off the shelf at the local parts store when I put this together. I had some Royal Purple Max Gear left over from my YJ years ago and I liked how that shifted, so I grabbed a couple more quarts and swapped it out. It does feel better, but I think the synchros are hurt already. I don't necessarily feel the 1500-ish miles I've put on it with improper fluid are to blame. The trans is used, and the XJ it came out of did have 37s and a turbo on it.
  9. #134 Re: Project Hugs Version 4.0
    So I got something for Christmas that's more fun, though it is somewhat functional. It's proving to be way more of a PITA to install than I expected, but I'm rolling with it because I've wanted one since I was a kid. This install also gave me a good reason to clean up the leftover ABS wiring some. I de-pinned a bunch of it from the plug by the headlight and then from the main module connector, too. The rest I coiled up and tucked back towards the firewall and it ended up hiding under the washer reservoir, for the most part. With it tidied up it made some more room for my install. So, what did I get, you ask...
    Yup, I'm one of those guys. Lol! Like I said, I've wanted a 4x4 with a snorkel since I was a kid. Still working on getting the connector piece inside the fender connected to the air box. It looks like the fender will need to come off. I burned up some time messing with the wiring today. This one came from Amazon for $100. Overall it fits well, though the template puts the holes a touch low. I'm also trying to work out an actual seal between the main snorkel and the piece inside the fender. It's a pretty loose fit as delivered.
    Down to a single wire out of this plug, now.
    What I fully removed.
    This bundle runs into the cabin and I did not have time today to mess with that.
  10. #135 Re: Project Hugs Version 4.0
    Today Project Hugs got a new windshield. The original was still (mostly) in place after 27-ish years and almost 186k miles. I thought it was starting to delaminate on the two right corners, but the windshield guy said it was actually separating from the backer that the adhesive sticks to. Hence the "(mostly) in place" comment above. He said pretty much the entire bottom edge was loose. There's a very good chance it would have popped out/broken if I had flexed it up.
