Thread: Need source for ZJ window regulator
Results 1 to 3 of 3
  1. #1 Need source for ZJ window regulator
    Jun 2006
    Cedar Rapids Ia
    So the Driver Side Rear window is loose. Either the gear has stripped teeth or the mount is loose.
    I do not see anyone selling a replacement regulator, anyone know of a source?
    If not I get a used part or cobble a fix myself.
    I may seriously just silicone it in place, then either pull the connector or disable the motor, some way without causing a fault message.
  2. #2 Re: Need source for ZJ window regulator
    RockAuto doesn't have any that I can find, you may be stuck cobbling stuff together from a junkyard.
  3. #3 Re: Need source for ZJ window regulator
    Feb 2016
    E-town PA
    The junkyards around here are literally riddled with ZJs, so I'd probably go that route. I checked Dorman's website, only front regs. Kinda surprised, honestly.
