Thread: NP242 HD transfter case
Results 1 to 3 of 3
  1. #1 NP242 HD transfter case
    Built NP242 HD transfter case $400
    1-1/4 wide chain and sprockets, 6-gear planetary, from Hummer/AMG tcase, but case is from a 242 J, so it has all the typical gear selections.
    SYE with 32 spline output shaft (flange style)
    Includes flange style end for drive shaft
  2. #2 Re: NP242 HD transfter case
    Mar 2008
    PA.
    Which SYE did you use?
  3. #3 Re: NP242 HD transfter case
    It was a custom job, basically a heavy duty hack&tap:
    • Started with a 32-spline flanged slip yoke, shortened it and machined it for the pilot diameter and bolt pattern of a 1310 DC joint. Like this, modified to match this.
    • Shortened the tail cone machined it to accept a new seal to fit the new output flange.
    • Shortened the output shaft and drilled/tapped the end to retain the output flange.
