family wj build
Thread: family wj build
Results 1 to 12 of 12
  1. #1 family wj build
    Nov 2017
    Nanaimo BC
    with my expanding family i needed a reliable comfortable overlanding vehicle and as luck would have it i picked up a mint 03 overland with 145k on it
    my donor parts are from my 85 toy
    95 LT1 nv4500 atlas 4 spd 60/14bolt
    i ran the lt1 for years and have tons of parts for it so instead of buying adapters to get my atlas to bolt to the 4.7 and make a weaker driveline i decided to swap it in
    im using a clayton long arm kit and cut out flares
  2. #2 Re: family wj build
    Nov 2017
    Nanaimo BC
    motor is from a 95 f body
    motor mounts bolt into factory location
    i dont have a pic of the tranny in from the inside but it comes up under the small storage area below the hvac controls. the tower is pretty high on the nv4500 but hoping it will work out.
  3. #3 Re: family wj build
    Member dubj's Avatar
    Aug 2012
    denver, colorado
    can we have some pictures? that sounds pretty awesome and like quite the build!
    im guessing your motor is in a similar spot as mine since my nv4500 also come through the dash
  4. #4 Re: family wj build
    Nov 2017
    Nanaimo BC
    got the pics to work but have no idea why the second set are rotated.... do you have a pic of your setup inside
  5. #5 Re: family wj build
    Nov 2017
    Nanaimo BC
    im glad i went with the "frame stiffeners" as the PO had figured out where to jack to lift the entire side of the jeep at a single point which along with his multiple attempts slightly crushed the bottom of the folded metal unibody frame rail. also the rear mount on the clayton 4 link needs a better mounting point imo. i think once i get the rear driveshaft in i might fab a small cross member connecting the two sides at that mount. i already added a small addition to the back of each rear mount.
  6. #6 Re: family wj build
    Junior Member gthaefner's Avatar
    Nov 2004
    Fort Collins, CO
    Awesome start to a build! I know when I bought the skid plate from Clayton for my zj, it came with a support you weld between the rear framerails. Not sure if it’s the same for a WJ.
    94zj locked and loaded
  7. #7 Re: family wj build
    Nov 2017
    Nanaimo BC
    Quote Originally Posted by gthaefner View Post
    ya some sort of belly will definitely strengthen it and protect the atlas. once it get moving under its own power ill build something
  8. #8 Re: family wj build
    awesome!
  9. #9 Re: family wj build
    Nov 2017
    Nanaimo BC
    have made a bit of progress. going to reuse my old bump stops. the old factory coils un compressed turned out to be what my lift coils will be compressed
  10. #10 Re: family wj build
    Nov 2017
    Nanaimo BC
    i didnt want to give up my high steer so i went with a short trac bar. ill see how it drives
  11. #11 Re: family wj build
    Nov 2017
    Nanaimo BC
    swapped out my old trusted super joints for some spicer lifetimes
  12. #12 Re: family wj build
    Nov 2017
    Nanaimo BC
    rear 14 bolt with its truss
    had to get it out so i could do the brakes on my dodge
