Thread: D35 pinion bearing replace and setting pattern
Results 1 to 2 of 2
  1. #1 D35 pinion bearing replace and setting pattern
    Sep 2007
    Slovenija
    Hi Guys
    Been awhile sence I been here, still loving jeeps..
    Can you get me advice for setting pattern on D35 axle.
    I replaced pinion bearings and clutch packs (spring washer was broken).
    Now, I have hard time to set gears.
    Here is a picture of pattern check with original pinion bearings. Backlash is set to 0.2mm.
    SETUP1
    With original shim (1mm) under lower pinion bearing and (the same setup like above) backlash set to 0.2mm
    What do you think about this setup1?
  2. #2 Re: D35 pinion bearing replace and setting pattern
    Feb 2016
    E-town PA
    I know this is a very late response, but the first pic looks like your pinion gear is set too deep by the pattern shown. The second pic looks better, but I'm not sure what changed from the first pic. Did you check the pinion depth before and after? Did you change anything with the carrier bearings?
