only modification done is I opened up the holes just a LITTLE for putting the ZJ ABS sensors through the knuckle adapter brackets.
YES I have some NEW inserts for your stock knuckle to remove any slop for the stock taper of the TRE insert. as seen as the silver things in this pic between the bolts and the nuts: http://offroadonly.com/shop/steering...llation-kit-2/
I would still be running this but I swapped to WJ steering and knuckles
info about the setup: http://offroadonly.com/shop/steering...ft-hand-drive/
Google images for installed pics: https://www.google.com/search?q=oro+...w=1920&bih=922
Name:  2017-07-16 17.31.40.jpg
Size:  31.8 KBName:  2017-07-16 17.31.47.jpg
Size:  36.3 KBName:  2017-07-16 17.31.51.jpg
will let go cheap to get it out of my garage...
$100 shipped in USA, maybe CA too =)
