Thread: WJ 4.7 fuel consumption went up and doesent want to start
Results 1 to 7 of 7
  1. #1 WJ 4.7 fuel consumption went up and doesent want to start
    Oct 2016
    Estonia
    Hi,
    Im having problems with my 4.7 WJ. When its cold, it takes about 3 seconds of cranking before it starts. It used to start under a second. Additionally, average fuel consumption went from 15.2 to 19.7 litres per 100km after the starting problems started.
    If I turn the ignition about 3 times, before starting it starts better.
    No codes come up when key is turned 3 times. Also took it to the dealership few days ago and ran diagnostics cpu. Again, no results.
    Where to look and what to replace?
    Thanks
  2. #2 Re: WJ 4.7 fuel consumption went up and doesent want to start
    My first guess would be you might have a leaky injector.
  3. #3 Re: WJ 4.7 fuel consumption went up and doesent want to start
    Oct 2016
    Estonia
    Unfortunately I havent managed to discover any leaks. Inspected pipes form the tank to the engine. Everything is dry. Also the injector rails are dry.
  4. #4 Re: WJ 4.7 fuel consumption went up and doesent want to start
    The injector wouldn't be shutting off all the way and leaking into the combustion chamber, not leaking externally.
  5. #5 Re: WJ 4.7 fuel consumption went up and doesent want to start
    Member Tuzmaster's Avatar
    Dec 2016
    Colorado Springs
    Check to make sure your MAP or MAF sensors are in good condition. You would have one or the other but not both. pre 01 (I believe) you would have a MAP (Manifold Absolute Pressure) sensor. Post, you would have MAF (Mass Airflow Sensor). MAP sensor would be on the throttle body, while MAF on the intake hose somewhere.
    Get a cleaner of some sort and clean them out. If that does something, than whichever sensor you have is probably going bad.
    If you already figured it out, than ignore this post
  6. #6 Re: WJ 4.7 fuel consumption went up and doesent want to start
    Thanks, I'm getting in the 10-11 mpg range. I'll try the maf cleaner.
  7. #7 Re: WJ 4.7 fuel consumption went up and doesent want to start
    Oct 2019
    Lexington, Kentucky
    I had the starting issue in my wj. My fuel gauge was out anyways so i decided to change fuel pumps. Fixed starting issue, may be something for you to look into!
