Thread: 4:10s with 33s
Results 1 to 7 of 7
  1. #1 4:10s with 33s
    Sep 2015
    NEPA
    I figured I would post this question in this section since I'm doing an 8.8 swap. Ok, I have an 8.8 with 4:10 gears in it and I plan buy a dana 30 with the same gears as the 8.8. How do the 4:10s move 33s with the 4.0?
  2. #2 Re: 4:10s with 33s
    It will do fine as long as you don't spend much time on the highway going up hills or towing anything. If you do, you'll really want 4.56s.
  3. #3 Re: 4:10s with 33s
    Sep 2015
    NEPA
    The jeep is only for the woods and roads leading towards them. Sounds good. Thanks man
  4. #4 Re: 4:10s with 33s
    I ran 33's and 4:10's for 2 years, it was fine. I have a V8, if you have a I6, it will be a dog on the road but in 4-low it will be ok. I went to 4.56 for 35's, but I'm going to 5.13's for my next axle build (35's or 37's).
    Also the 4.56 gears for a D30 have a tiny pinion, so 4.10's will be stronger.
  5. #5 Re: 4:10s with 33s
    Sep 2015
    NEPA
    So it'll be similar performance that I have now running 31s with stock gearing, 3:55s I think?
  6. #6 Re: 4:10s with 33s
    Quote Originally Posted by Scarabotti View Post
    It is very similar, I ran both 31's on 3.55's, and 33's on 4.10s in a 4.0, it was ok. I swapped in a stroker because I felt there wasn't enough power. I like to go faster and I am at altitude so less power and the hills are longer.
  7. #7 Re: 4:10s with 33s
    Houston, TX
    ditto.
    I was on 35s and 4.10s and dropped to 33s and 410s, my reasoning is I would rather be locked with 33's than open on 35s. my 4.7L stroker helps in the power dept =).
    my old 35" BFG AT's were lower on tread vs my new MT MTZP3 33's I only lost about 1/4" height TOPS with the new tires.
