Thread: 8.8 swap done abs not working
Results 1 to 8 of 8
  1. #1 8.8 swap done abs not working
    Sep 2015
    Lemont IL
    I have a 95 4.0 ZJ that I did a 8.8 swap on and I can't seem to get the ABS to work now. The ABS work prior to the swap and if I connect the two stock sensors the light will go out at startup. I cut the two stock sensors off and connected both browns to the red wire to the sensor and both black wires to the green wire on the sensor. I then reversed them and it still did not work. I checked the speed sensor and it showed opened with my meter so I bought a new one and still have the same issue.
    I bought the 8.8 from a guy how had it in his ZJ and he had already removed every other tooth off the reluctor. I searched and I can't find anything else to try, what am I doing wrong?
    My wife and I both drive this and it will be driven in the snow so I would like the ABS to work.
  2. #2 Re: 8.8 swap done abs not working
    Junior Member gthaefner's Avatar
    Nov 2004
    Fort Collins, CO
    You will never get the abs to work with the 8.8 axle installed. Factory used individual wheel speed sensor in the rear, ford uses a tone wheel off the carrier. Plus, you would have to get the exact same wave length from the ford sensor to mimic the jeep sensor. When i did my 8.8 swap, i cut off the sensors, removed the fuse and relay from the ABS to get the light to turn off.
    Good Luck!
    94zj locked and loaded
  3. #3 Re: 8.8 swap done abs not working
    Tom Z did get his working back in the day, not sure what he did though.
    Sent from my Nexus 6 using Tapatalk
  4. #4 Re: 8.8 swap done abs not working
    Senior Member dp96zj's Avatar
    Texas
    DJJordache did it too, and I seem to recall (years ago) that he had a thread detailing exactly what he did to get the ABS to work. For the life of me, I can't seem to find the post...
  5. #5 Re: 8.8 swap done abs not working
    Senior Member Sudz's Avatar
    Pennsy
  6. #6 Re: 8.8 swap done abs not working
    Sep 2015
    Lemont IL
    I read that post and that's how I wired mine up but it still does not work. He did this to a 90 XJ and I have a 94 ZJ, my ABS did work before the axle swap and if I wire both sensors back up the ABS light goes out after start up.
    It has to be a signal/sensor problem because the light stays on at start up before I even move.
  7. #7 Re: 8.8 swap done abs not working
    yeah but did you read the other part of CUTTING EVERY OTHER tooth off to make it 54 teeth?
    and yes I did it on a 90XJ and my 93ZJ and have heard of others doing it the SAME way with success
    edit: maybe the sensor in the 8.8 is bad...
    edit 2: http://mallcrawlin.com/forum/showthr...l=1#post130097
    showing how I did it on my ZJ
  8. #8 Re: 8.8 swap done abs not working
    Sep 2015
    Lemont IL
    Yes mine already had every other tooth removed, I mentioned that in my first post. He even had part of the jeep harness connected to the 8.8 sensor plug when I bought it from him. He just cut the wires when he pulled the axles from his ZJ.
    It does have a new sensor in it because the old one was bad, it showed open when I connected my meter to it.
    When I start it up with the old jeep sensors connected the light goes out.
    When I start it up with the new 8.8 sensor connector the light is on, this tells me that the initial abs check fails and I think it is because the 8.8 sensor I have has a different reading than the stock jeep ones.
    I wonder if the auto parts store speed sensor isn't giving the same readings back that a factory ford 8.8 speed sensor would give.
    BTW thanks for the help, I've read your post a few times to see if I missed anything.
