Thread: Help electrical problems, trying to get to GSW
Results 1 to 12 of 12
  1. #1 Help electrical problems, trying to get to GSW
    Senior Member Lifetime Supporter ZJ TINS's Avatar
    Jun 2006
    Cedar Rapids Ia
    So I put a Taurus fan in with relays. This works great.
    But my battery died.
    I check and find 1.6 amps drain everything with off, key off.
    After much checking, removing fuse number 7 (in the kick panel) drops the current to 0.25 amps which I am told is high but acceptable.
    Fuse #7 is the BCM.
    Also the battery has died several times over extended none charge times in the last 3 months.
    5 years ago the headlamp auto dim started working intermittently.
    During my fan install the overhead lights stopped going out they are always on, but the VIC does not show a loose door. I pulled their connector.
    Any ideas how to further verify/test the BCM?
    Any other ideas on what to check.
    If I pull the BCM fuse is the car driveable or what stops working?
    “I ask, sir, what is the militia? It is the whole people, except for a few public officials.”- George Mason
    "The beauty of the second amendment is that it will not be needed until they try to take it." -Thomas Jefferson
    “The great object is that every man be armed.” -Patrick Henry
  2. #2 Re: Help electrical problems, trying to get to GSW
    Santa Fe, NM
    I don't know if it's any help or not, but I seem to recall that when I had battery drain issues it was caused by the sensor for the flip glass on the hatch. I don't know if that's applicable to your ZJ or not or if that is tied into the BCM circuit but it might be worth a shot.
    Andy
  3. #3 Help electrical problems, trying to get to GSW
    Fruita, CO
    Remind me about "bcm"?
    My power drains were so bad that a freshly charged high end battery would die in a day and have been from fuses 2 and 8 and I pulled 1 at some point (don't remember what for) and so far aside from no interior lighting nothing has any "extra" issues and the power drains are gone
    Because Jeep.
  4. #4 Re: Help electrical problems, trying to get to GSW
    Jun 2006
    Cedar Rapids Ia
    So I am coming but no jeep . It will be great to see everyone again.
    I will get a BCM and repair when back.
    I did find a free copy of the 1996 factory service manual in PDF.
    http://www.uscars.biz/uscars/jeep-do...er_zj_1996.pdf
  5. #5 Re: Help electrical problems, trying to get to GSW
    Fruita, CO
    Quote Originally Posted by ZJ TINS View Post
    Now that is a true Gsw Family! Wish you could bring the jeep but it will be awesome to have you anyways!
    Because Jeep.
  6. #6 Re: Help electrical problems, trying to get to GSW
    There isn't time to grab a BCM from a yard and give it a try?
  7. #7 Re: Help electrical problems, trying to get to GSW
    Have you had any issues with interior lights staying on?
    There are switches on the back of each of the door key cylinders (driver, passenger, rear hatch) that are a common failure point. The BCM will sense the cylinder rotating and turn on the interior lights via a relay. Also check the two door pin switches and the two sensors on the latches in the tailgate and lift glass. These also tell the BCM to activate interior lights.
    If any of these switches/sensors are bad you can just unplug them to get them to an inactive state.
  8. #8 Re: Help electrical problems, trying to get to GSW
    You could just pull the negative battery cable when parking it overnight too.
  9. #9 Re: Help electrical problems, trying to get to GSW
    Jun 2006
    Cedar Rapids Ia
    Debated that but if something got worse we did not want to get stranded.
    Iowa, trucks sure, Jeeps hmmm...
  10. #10 Re: Help electrical problems, trying to get to GSW
    What year and motor do you have? I can pull one from my 95 4.0L. I don't know if motor matters.
  11. #11 Re: Help electrical problems, trying to get to GSW
    Fruita, CO
    Any more on this!
    Because Jeep.
  12. #12 Re: Help electrical problems, trying to get to GSW
    Jun 2006
    Cedar Rapids Ia
    Went to GSW had a great time (road with Tom).
    It was great to see everyone again... and the new face too!
    Got the BCM, will install soon, busy ATM (job hunting).
