Has anyone made custom C Gussets for a WJ Dana 30? Im not interested in the ironrock sandwich "gussets" that will cause clearance issues with RCV joints.
I want actual gussets that weld between the inboard face of the C and the top of the axle tube like artec gussets. Problem is, the artec gussets are for TJ 30s with much larger clearance between the inner C and the coil bucket.
I also had the though of cutting a piece that fit between the inner C and the coil bucket box while also tying into the top of the tube but im not sure if that bucket is thick enough to achieve the strength increase I want.
I may resort to torching off the stock buckets and replacing them with something that gives me clearance for an artec style C gusset but not if I don't have to.
