GSW 2016 - Who's going/Dub honey do's??? - Page 3
Thread: GSW 2016 - Who's going/Dub honey do's???
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 86
  1. #51 Re: GSW 2016 - Who's going/Dub honey do's???
    Junior Member Toy50's Avatar
    Feb 2015
    Sparks, Nv
    Brown Santa finally came! Dropped off 9 BFG tires for the Dub and Super duty and 4 trailer tires��. I'll get them mounted and have discount tires balance them. 2 MORE WEEKS!!!
  2. #52 Re: GSW 2016 - Who's going/Dub honey do's???
    Cedar Rapids Ia
    I have a 4 day weekand I might get most done:
    Must do
    <New tires, Cooper AT3
    <Exhaust noise
    <Weld on sway bar link pin mount
    <De-rust and paint
    <Flush and replace tranny fluid
    Above done
    Install new sway bar bushings, remove broken screw
    Install new quick disco straps
    Fix noises in back
    Fix driver door light switch (frame sag)
    Flush Clean Radiator
    Install hi flow thermostat, thermostat housing
    Install 136 amp alternator
    E-fan, electronics, install high speed override switch
    Fix noises in back (most done)
    Rebuild E-brakes (none now)
    Clean headlights (too late for replacement)
    Grease everything
    Add check valve to vacuum hose to control box
    Gear oil
    Can survive trip without
    Install under hood e-lamp
    Mount radio power box
    Fix glove box
    Install bumper lights
    Can do later
    Headliner
    Front Ball joints
    Patch underbody, wheel well, and passenger floor
    Seat covers with new heat elements
    Mount vacuum pump and controls if needed
    “I ask, sir, what is the militia? It is the whole people, except for a few public officials.”- George Mason
    "The beauty of the second amendment is that it will not be needed until they try to take it." -Thomas Jefferson
    “The great object is that every man be armed.” -Patrick Henry
  3. #53 Re: GSW 2016 - Who's going/Dub honey do's???
    Grinder might get more work than I thought...
  4. #54 Re: GSW 2016 - Who's going/Dub honey do's???
    Feb 2015
    Sparks, Nv
    Keep going!! This is going to be good
  5. #55 Re: GSW 2016 - Who's going/Dub honey do's???
    Member dubj's Avatar
    Aug 2012
    denver, colorado
    Quote Originally Posted by jsteves View Post
    35's?
  6. #56 Re: GSW 2016 - Who's going/Dub honey do's???
    Junior Member 93 grandwagoneer's Avatar
    Jul 2007
    huntington beach
    well woodys making it this year! just need to change all fluids already got new tires and im sure there is other crap ill find along the way lol
    rick aka woody
  7. #57 Re: GSW 2016 - Who's going/Dub honey do's???
    Quote Originally Posted by dubj View Post
    35's?
    Yep!
  8. #58 Re: GSW 2016 - Who's going/Dub honey do's???
    Nice!!!
  9. #59 Re: GSW 2016 - Who's going/Dub honey do's???
    Member MoonyJohn's Avatar
    West Linn
    Im not on mallcrawlin much, but I am going this year! So far the only thing that I have left to do is wire up a couple light switches since ricochet has made me a custom set of headlights with pods in them. Other than that Ive got everything pretty much ready to go!
    Cant wait to make it out for the first time!
    ZJ to WJ to JK back to WJ 4 Lyfe
  10. #60 Re: GSW 2016 - Who's going/Dub honey do's???
    Awesome!! See you there!!
  11. #61 Re: GSW 2016 - Who's going/Dub honey do's???
    Feb 2015
    Sparks, Nv
    Anyone see the forecast for next week?? 107* ... better go check my AC.
  12. #62 Re: GSW 2016 - Who's going/Dub honey do's???
    Quote Originally Posted by Toy50 View Post
    Don't scare me like that! I see 103 for Monday but mid 90's for GSW.
    https://weather.com/weather/tenday/l/Moab+UT+84532:4:US
  13. #63 Re: GSW 2016 - Who's going/Dub honey do's???
    Glad I flushed my cooling system and put a/c back on the ZJ! Hopefully it won't be that hot though, I think low 90s is most likely. And certainly more tolerable. Although 107 still wouldn't be the hottest GSW.
    Sent from my Nexus 6 using Tapatalk
  14. #64 Re: GSW 2016 - Who's going/Dub honey do's???
    Feb 2015
    Edgewater, Co
    I have been checking Weather Underground for about 2 weeks now and the trend that I have seen is they have shown upper 90s for the extended forecast, but as the day gets closer the forecasted temps are dropping 5 or 10 degrees.
    We have endured 100s, but I would much prefer 90s
  15. #65 Re: GSW 2016 - Who's going/Dub honey do's???
    Quote Originally Posted by Chuchmouse View Post
    We have endured 100s, but I would much prefer 70s
    Fixed! 😉
  16. #66 Re: GSW 2016 - Who's going/Dub honey do's???
    I don't know about 70's, that brought the rain last year and we know how that turned out!
    Also, I am no making a big push to install my hood vents and fix the a/c.
  17. #67 Re: GSW 2016 - Who's going/Dub honey do's???
    Feb 2015
    Edgewater, Co
    70s with the guarantee of no rain would be fine
    Jim has convinced me over the years that using the A/C is actually a bad thing because your body has to keep acclimating to the heat every time you get out. Even if we have A/C we do not use it
  18. #68 Re: GSW 2016 - Who's going/Dub honey do's???
    I have the gauges and vacuum pump if you need them.
  19. #69 Re: GSW 2016 - Who's going/Dub honey do's???
    Thanks, I may take you up on that. I may just drop it off at a shop.
  20. #70 Re: GSW 2016 - Who's going/Dub honey do's???
    I'm going to be in Minneapolis during GSW
  21. #71 Re: GSW 2016 - Who's going/Dub honey do's???
    recon zj's Avatar
    Surf City, USA
    Well, after replacing the radiator (a story in itself), water pump & fan clutch, all hoses and the heater return tube, thermostat and housing and a new battery on the ZJ, I cranked it up to finish filling the coolant yesterday evening. Started feeling a mist, and found fresh coolant spewing out from the area at the top left of the water pump. Crap! Since I still had a new tire to mount, balance and then get it aligned, I decided to stop for now and just bring the WK2 again this year. This is supposed to fun and I'm on vacation, so I'm not going to stress out rushing to get this thing done by Monday.
    Means my "to do" list before GSW just got a lot shorter, and I'll have time to cool off before tackling the ZJ again. Needless to say (but I will anyway), I'll be running the easy trails.
  22. #72 Re: GSW 2016 - Who's going/Dub honey do's???
    Backup Jeeps are the best!
  23. #73 Re: GSW 2016 - Who's going/Dub honey do's???
    Aug 2012
    denver, colorado
    Wish I had one, I'm headed back from moab in the morning due to having blown up both front shafts and the rear diff and after only 3 easy trails
  24. #74 GSW 2016 - Who's going/Dub honey do's???
    That sucks, 37's break stuff
  25. #75 Re: GSW 2016 - Who's going/Dub honey do's???
    Aug 2012
    denver, colorado
    Wanna borrow them?
