Thread: 249 rear output seal replacement?
Results 1 to 4 of 4
  1. #1 249 rear output seal replacement?
    Senior Member norton's Avatar
    Mar 2005
    About 5 miles north of nowhere in Kansas
    Transfer case is off, replaced tranny output seal, case input seal, front output seal. I'd like to do the rear output seal too while its out but I'm having a hard time figuring if I can without opening up the case. I did search, was very helpful on the other seals. I did find a writeup on the 242 output seal but its clearly different than the 249. I'll snap a photo when I get back home to my shop if that would help. It does appear to have a flange like the original front output seal but my buddy seems to think otherwise on how to remove it.
    I'm not considering a swap btw. This case is still strong and I have another 249 already from my old zj. I like em but I realize not everyone does, cheers and thanks!
    93 5.2 2" 31's
  2. #2 Re: 249 rear output seal replacement?
    You might have to pop the tail cone off, but that's not a huge deal. Neither is cracking the case.
  3. #3 Re: 249 rear output seal replacement?
    It's been a while, but I think I just pried it out with a screwdriver. Nothing special. Use a large socket to install the new one. Don't damage it at all or it will leak like the old one. Second install is easier though.
  4. #4 Re: 249 rear output seal replacement?
    Mar 2005
    That worked. Thanks
    93 5.2 2" 31's
