What do you have for sale? What are you looking for?
I have a set of Dana 35 Yukon heavy duty shafts for drums. They are the over sized ones that don't work with disks. $200 for both. Not many ZJs need these but I have a set.
I have a WJ D30 long side shaft, used but in good shape. $30
Stock ZJ steering, probably ok for trail spares
Currie ZJ steering, better shape than the stock, but Dave and Pam beat on the set before I bought it from Dave
I may have given Dave $75 for the Currie, but I don't remember. Stock, just make an offer. I can't use either anymore since I went 1-ton steering.
Looking for a case of ZJ gremlin repellent (electrical specific) willing to pay decent if you have a full case as I will need as much as I can get!
5.5" IRO springs as I lowered my ZJ when swapping bodies. Also Doetsch Tech 8000 shocks for the 5.5" lift F&R for stock setting axle brackets. Less than 7k miles, 2 seasons on them. They have a great spring rate just taller than I want on 33x10.5x15 tires w/stock rims.
Shocks - $100.00 for the set of four
Springs - $210.00 for the front and rear
I've got a d44a open carrier and kevins old bumper (wj)
I have a pair of http://www.summitracing.com/parts/bsn-f4be56249h5]Bilstein 5100[/url] shocks as well. 29.70 in. Extended/17.91 in. Collapsed Lengths, Eyelet/Eyelet. $100 pair.
1995 Lifted Grand Cherokee Ltd. ZJ parting out
Just about everything is available, I will group parts together with discounted prices and feel free to make an offer, prices based off of Denver Craigslist and too much coffee. Pictures available on request, I will try to post some soon.
4.0 stroker, 4.7L Accurate power kit, Hesco high flow head, 24lb/hr 4 hole injectors, 99+ intake, 62mm bored throttle body, Airaid intake spacer, Turbo City intake with AFE air filter, Mike Leech header (dented from driveshaft) new cap and rotor and all accessories. Only 4k miles. Engine runs but needs tuning. $1,000
42RE transmission built to handle the stroker $500
NP231 with SYE $300
High pinion Dana 30 front with 4.10s open hub to hub $200
Ford 8.8 rear 31 spline from an Explorer with 4.10s, Aussie locker and setup for triangulated 4-link (Clayton style) Spare shafts available. $500
4” Custom longarm suspension. 4” springs, arms are 2” 1/4” wall round tube, front arms are y-link with Johnny joints on body side and rubber bushing on the axle side, upper arm is a JKS arm with c-bracket to mount to axle. Rear arms are Johnny Joints and Crawler joints one on each end, each arm has a left and right hand so it is an easy and infinite adjustment. You will need to figure out body mounts as I am not grinding mine off. Claytons should work. $600
Tom woods rear driveshaft fits 4.0/42RE/231 with sye to 8.8 $100
Front u-joint driveshaft SOLD
Aluminum radiator $100
Kevin's trackbar bracket with JKS adjustable trackbar. $150
Kevin’s radiator support, sight bend and one bolt is cross threaded $50
Waggy steering box. SPF
Good battery, 2 years old, 3 year warranty $30
Black exterior, fenders are trimmed, doors are fine, driver door and hatch are flat black were white and then spray painted. Hood is silver. $50 each
Head lights and tail lights $20
Power side view mirrors driver $30 passenger $15 mirror is cracked.
Ford Taurus two speed fan. SPF
Interior is tan with tan leather no rips, smooth seats not the puffy ones. $100 for all the seats.
WJ knuckle swap parts, knuckles, calipers, and a tie rod. $150
Spidertrax wheel adapters 5 on 4.5 to 5 on 5, with spare tire adapter. $50
Stock gas tank skid. $50
Addco swaybar. This is an over sized version from the normal bar. I will include homemade discos for the dog bone ends on the bar. $100
Stock t-case skid with some welded in reinforcements. $20
Other interior items ask or offer, that’s too much to list.
I will remove or mark items as sold or spoken for.
Would this be an okay place to offer to bring any vendor parts you guys might want? Save a ton on shipping costs. I'll already be bringing a few things for the raffle too.
Put a link to your site in your sig, and your steering box brace thread. It is hard to find you.
Hey Ted how you want for that positive attitude 😃
Does anyone happen to have a left (drivers) side taillight for a 02' WJ that the would like to sell?
I called a shop I need to go to tomorrow and he said $35.
That would be awesome if you could!
