Page 16 of 16 FirstFirst ... 678910111213141516
Results 376 to 381 of 381
  1. #376 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    got it fully welded, sanded with 36 grit and then i hit it with an orbital with 220 to see th low spots.
    i need to fill a few low spots, cut the top for the storage compartment, build a lid, build cup holders, power outlets, and mounts.
  2. #377 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Feb 2016
    E-town PA
    So you're 40% done with it...LOL! It's great that you have this keep your spirits up throughout your treatment.
  3. #378 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by Tuzmaster View Post
    1) I looked through your thread yesterday and did not see any pics on how you mounted them. Would you mind posting them again?
    2) also, how did you glue them back so neatly. If i try it, Ill wind up having glue all over the inside of the lens
    So I though i had pics of the brackets welded on without the plastic cover. I dont. I will pull the covers if you want. Its pretty simple i just welded some 1" x .125" flatbar to the c pillar and d pillar. They poke through the plastic cover and the molle grill just bolts to it using extruded t nuts.
    The tail lights i used buna windsheild putty. I will take a pic of the box. Its like playdough, you just roll a skinny peice and lay it in the grouve on the sealing faces. Press the pieces together and heat to 265f then press them.together again.
  4. #379 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Making some soft shavkle snatch block rings.
  5. #380 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
  6. #381 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Member Tuzmaster's Avatar
    Dec 2016
    Colorado Springs
    Those pics and explanation helps a lot! Thanks. Will see if this works with the shelf thats still in process of being built in the rear.
