Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension - Page 16
Page 16 of 16 FirstFirst ... 678910111213141516
Results 376 to 396 of 396
  1. #376 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    got it fully welded, sanded with 36 grit and then i hit it with an orbital with 220 to see th low spots.
    i need to fill a few low spots, cut the top for the storage compartment, build a lid, build cup holders, power outlets, and mounts.
  2. #377 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    So you're 40% done with it...LOL! It's great that you have this keep your spirits up throughout your treatment.
  3. #378 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by Tuzmaster View Post
    1) I looked through your thread yesterday and did not see any pics on how you mounted them. Would you mind posting them again?
    2) also, how did you glue them back so neatly. If i try it, Ill wind up having glue all over the inside of the lens
    So I though i had pics of the brackets welded on without the plastic cover. I dont. I will pull the covers if you want. Its pretty simple i just welded some 1" x .125" flatbar to the c pillar and d pillar. They poke through the plastic cover and the molle grill just bolts to it using extruded t nuts.
    The tail lights i used buna windsheild putty. I will take a pic of the box. Its like playdough, you just roll a skinny peice and lay it in the grouve on the sealing faces. Press the pieces together and heat to 265f then press them.together again.
  4. #379 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Making some soft shavkle snatch block rings.
  5. #380 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
  6. #381 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Member Tuzmaster's Avatar
    Dec 2016
    Colorado Springs
    Those pics and explanation helps a lot! Thanks. Will see if this works with the shelf thats still in process of being built in the rear.
  7. #382 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    and the final product. still deciding if i'm going to coat them or not.
    quickly polished, i wanted to make sure the ID was as smooth as possible.
    and on the soft shackle
  8. #383 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    I got a chance to work on the front mounts.
    I made 2 of these on a drill press an used a modified 3/8" drill bit to made the counter bore with a flat bottom.
    the cap screw head sticks up the material thickness of the console skins.
    welded to the back side
    from the top
    nice and flush
    i made some plates with captive nuts welded to the bottom of the tranny tunnel to bolt to.
    i also cleaned up the fitment between the factory console and the new one.
  9. #384 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got a chance to make some more progress.
    got the lock mounted.
    I'm going to waterjet a new latch the one that came with it is not long enough
    i also got the inside finished...dont mind the safety loafers...
    i'm going to rubber line the interior to stop any rattling.
  10. #385 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Where do I get a pair of those safety loafers?
  11. #386 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    DC shoes man!!!
  12. #387 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    This might be one of the coolest modifications to a ZJ that I've seen!
  13. #388 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by OverkillZJ View Post
    Thanks. I love it. I switched gears a bit and started building a lowrider minitruck. 1991 mazda b2600i 2wd on 20's
  14. #389 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Is that what the BMW seats are going in?
  15. #390 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Thats the current plan.
  16. #391 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    I got some motivation today after recently getting the buggy repairs finished.
    I wanted really big cup holders. The stainless tumbler is a RTIC 8ball it’s one of my favorite cups. Fits like a glove. I will make some foam inserts to better fit a beer.
    Hopefully tomorrow I can make some progress on the lid. I want to get this powder coated ASAP.
  17. #392 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i needed a bulkhead for running the three brake lines through the floor of the jeep. this is the supply to the cutting brake and the 2 returns going to the rear axle.
    i was going to cut bend and tig weld one...but then i remembered we bought 3d printer. so here we go.
    the design
    printed from onyx resin reinforced with fibreglass.
    here is all the parts with both rubber gaskets.
    here is the rubber gasket installed in the top part. the 3 dimples are holes where the brake lines will pass through.
    here it is put together.
  18. #393 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Just when we think "how can this build get any better?" you pull out something like this! Lol!
  19. #394 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got some more progress on the truck. I got my boatside plastic installed so i needed a rail for my highlift jack as well as a foundation for the fender bars i need to bend up when i start the cage.
  20. #395 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Looks good! The pic with high lift working kinda answers my question wondering about your front wheel wells and what all you clearanced without digging back through. Those pics also make me feel better about my fender lip work!
  21. #396 Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Aug 2009
    knoxville, TN
    The Jeep looks fantastic, after a trip to Big Bear, Johnson Valley, Rubicon, and Moab last month I desperately need to do hydro assist. I very much like your setup. Has it turned out to work as you expected it to?
There are currently 10 users browsing this thread. (0 members and 10 guests)
