Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension - Page 13
Page 13 of 16 FirstFirst ... 345678910111213141516 LastLast
Results 301 to 325 of 396
  1. #301 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    What kind of steering pump issues are you having?
  2. #302 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by ELLLLLIOTTTTT View Post
    Looks killer! BTW, your garage is bigger than my house....
    But my house is 500ft from the ocean
    thanks. its coming along nicely.
  3. #303 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by egg View Post
    i have had many issues.
    one was dealing with a leaking PS pump res. then the variable steering steering box shitting the bed. Then i put in a normal steering box and the pump couldn't keep up. SO i swapped to a normal pump, but it leaked at the res. so i swapped it for another and it leaked too.
    so i'm getting a NEW pump and putting it in. I should have it dealt with this weekend.
  4. #304 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Holy moly! Good luck with the new pump! I can only imagine how anxious you must feel to drive it.
  5. #305 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    ive driven it a bit with the leaking pump. the rear cantilever needs the shocks tuned really bad. its so soft that with the rear swaybar if one shock compresses under a pothole the other side will follow. There is alot of leverage on the shocks and they are not valves for it right now.
  6. #306 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    My luck has been terrible with this.
    the good...
    -The PS pump issue is fixed. The steering is not twitchy anymore. it drives great. no leaks.
    -the front drive shaft is in.
    the bad...
    -i now have a massive oil leak on the drivers side of the block. Its to the valve cover. I need to get under there and check it out. the pumpkin in covered in oil.
    -the tcase wont shift out of 2wd. I bench tested it when i rebuilt the case. i pulled really hard while driving at low speed to see if i could get it to go and bent the linkage. I'm going to have to rig up something cable actuated
  7. #307 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Senior Member Grand Slam West Planner Cody's Avatar
    Salt Lake City
    and you probably have 5 lanes of gridlock until about 330 a.m.
    Resident hater of tall lifts, dana 44's, 4.0's, stingers, exo cages, and ZJ tow rigs....and the word "overlanding"
  8. #308 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Wanted to bump this. Have you been driving around yet? I'm curious how you like the double ended ram hydro assist? Happy new year to you btw
  9. #309 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i have been driving it about once every 2 weeks to work. I've taken it off road a nit. did a 2 day camping trip.
    the truck works AWESOME once i took the rear sway bar off. it was way to stiff. the steering is good once you bump the RPM up to about 1500. i need a smaller diameter pulley on the pump. once that gets taken care of it will be perfect.
    Shock valving is a problem. the FOA's are so inconstant that i have had a hard time tuning them. The fronts are due to come out and be revalved next.
  10. #310 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    That's awesome to hear. Any thought about using a wj power steering pump instead of the pulley swap? I'm hoping to run the same style steering as you built but just assumed a wj pump would work better.
  11. #311 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    I’ve heard that about FOA’s so went with Fox and not one issue!
    Sent from my iPad using Tapatalk
  12. #312 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    they are real bad. i shop an FOA bumpstop through my hood at KOH 2011.
  13. #313 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    VHF Radio Mount
    i removed this from the overhead console. Its the garage door opener and sunglasses holder.
    I will get it powdercoated matt black.
  14. #314 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Now to build one for the short console/sunroof...
  15. #315 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Love this build, just read through it again for the third time. Definitely helps me plan for my build and inspires all of us to think big! Bought my ZJ as a winter beater/family wheeling rig and will be building it in stages. I'd be interested in pricing on the bracketing/skid plate as a DIY kit for future planning. Keep it up, man!
  16. #316 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    and the Radio Mount.
    ........all powdercoated texture black.
  17. #317 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    That window basket thing is awesome! Did I spy one for the passenger's side on the bench in the second to last picture? How do you have them attaching? I'm assuming that you took all the trim out and have it bolted in there, but seeing or hearing how you did it would be interesting. It gets me thinking about something like that for mine, but since I still have the spare inside I'd have to put it on the passenger's side. Looks like you laser- or waterjet cut them out of one sheet of flat stock, right?
  18. #318 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i will show more install pics when i do the other side....yes...there is another one for the other window.
  19. #319 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i finally got around to fixing the shitty stock headlights.
    stripped the chrome off a set of aftermarket housings and got a set of morimoto D2S mini HID projectors
  20. #320 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    not nighttime and they haven't been adjusted yet.
  21. #321 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Nice! Especially since you haven't adjusted them yet. I expected a little more beam scatter with the lens in front of the projector, but they have a great cut-off.
  22. #322 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    ya i'm super happy with the cut off. sooo much better than factory.
  23. #323 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    so my seats arrived. PRP Premier, i opted to add the camelba water pouch to them. its a bit of a gimmick but my wife liked the idea and well....why not keep her happy.
    Carbon fiber with slate and black tweed.
    i had amazon seat heaters installed in the factory seats. so i pulled those out and installed into the new PRP's.
    the back pads were a bit more difficult since the cover doesn't come completely off the seat but i managed to slip my hand through the harness hole by the neck rest and pull the eating pad up the back. good thing for small arms.
    I am keeping the factory power seat bases, these are the adapter brackets to mount the PRP's to the factory base.
  24. #324 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jun 2013
    oroville
    Love those seats man. I never realized how BA and comfortable PRP seats were until I sat in a demo set at KOH.
  25. #325 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    nice lights with a great beam cutoff! glad to see they are alive =)
There are currently 7 users browsing this thread. (0 members and 7 guests)
