Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension - Page 5
Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 396
  1. #101 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Clemson, SC
    I have 14" x 2.5" coil overs for the front. The set-up will not be as involved as the front. i will be trying to not do a shock hoop like everyone does. i want to build a shock tower that is frenched into the inner fender. it will help keep debris out of the engine compartment and avoid a bunch of gaping holes.
    I like that idea, I was looking at something like that on mine. My buddy drew up some shock towers in solid works and had them cut out and I was trying to see how I could run them in the front rather than hoops.
    -Ronnie
    98 5.9 on 35s
  2. #102 Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    I had a local guy cut me out some frenched towers for mine but I still had to do some heavy modifications because of the limited space and angles I had to work with!
    I will say that it's definitely better tower/uni-body over hoops
  3. #103 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got the rear gas tank skid support and cantilever support all finished. all i need now to finish the rear off is bump stops and links.
    1.125 bolting flange for skid all the way around
    i also got the driver side rocker/boat side in place. still lots of welding left.
    still have the factory door seal
  4. #104 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    So much sex.
  5. #105 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jan 2015
    az
    What size tube did you end up using? Looks really good.
    93zj build. 4.0 aw4, 231, 60s, and 37s. Some cutting and some welding.
  6. #106 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    4 x 2 x 3/16" Thanks. Lots of work for only a few inches. But totally worth it.
  7. #107 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jan 2015
    az
    I hope it is. Is there a reason you did your spacing on supports the way you did? I tried to have mine not interrupt leg room. When i put my interior back in you would never know i even cut the floor.
  8. #108 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i put the supports where they are to avoid seat mounting and the seat belt hold down.
    you shoulnd; tbe able to tell they are there when the carpet goes back in.
  9. #109 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Mar 2008
    westerville, ohio
    https://www.facebook.com/video.php?v=437010969785884
    Looks cool in action. I can't wait to see it on a ZJ.
  10. #110 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Junior Member jeepjosh's Avatar
    Oct 2011
    south jersey
    And I thought I was a master fabricator when I welded my pre-made bracket kit on the 8.8 haha
    It's amazing just to see tech like this going into a build on a ZJ. Wish I knew half the shit you already forgot about building a nice wheeling vehicle
    95 ZJ 4.0 l 5" l Claytons front LA l Adjustable rear arms l 33" Goodyear Wrangler MT l 8.8 in the garage
  11. #111 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Senior Member StinkoMan20X6_'s Avatar
    Aug 2005
    NC
    I like that ZJ's are finally getting the kind of tech that they deserve. Just in time for them to be practically free to own. Almost makes me wanna sell mine and start over.
  12. #112 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jan 2015
    az
    Hey kraqa, what is your axle to frame height: going to be at right height?
  13. #113 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    IIRC around 13" i will double check when i get the axle back under there.
    i think i can get away with a 3.5" lift over stock and have about 4.5" of up travel.
  14. #114 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jan 2015
    az
    IIRC?
    I think im running 12 inches from the center of the axle to the frame above the stock bump stop.
  15. #115 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Quote Originally Posted by bentwrench View Post
    IIRC?
    IIRC = if i recall correctly
  16. #116 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    not sure how much i posted of this prior...
    but i went from a round bar of 4140 chromoly to a sphere and a shank. then threaded the shank
    that one is 1.25". these ones are 1"
    then made some custom jaws, turned em sideways and bored them out and threaded them
    finished the other side in the lathe and then did some locking rings. 4 flat spots for a set screw and then the counter bore holes for the spanner wrench.
    the real magic will be when i make the inner races. i have formulated a urethane for this. 100% memory, great rebound, great impact resistance, no cold flowing like other UHMW and NYLON races. very rigid to keep the firm feel of this style of joint. pics will follow.
    everything goes out for nitrite coating and heat treatment on thursday
  17. #117 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    joints came back from heat treatment and surface finishing.
    i also got the mold for inner races done and managed to cast 48 races. i pulled 2 from the batch to test fit. the rest are post curing and annealing over night.
    the race has a built in lubricant. 100% memory. 25% compression set. 0% cold flow (UHMW has somewhere around 35%). very high abrasion resistance. there is also an internal dust seal cast into the race. currently filing a patent on the race.
    love to see the orange in there.
    then one of these joints goes into our suspension simulator to get some head to head numbers VS a UHMW race (like the RE joints), industry standard MDI urethane race like the johnny joints and a metal race like an EMF joint.
  18. #118 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    thread should be open again. can someone post to verify that it is open please.
  19. #119 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Open again
  20. #120 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jun 2013
    oroville
    yes.
  21. #121 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Had to wipe the drool of my chin...
  22. #122 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Sub'd! Killer build man! Keep it coming!
  23. #123 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Got to love the machining pron here.
  24. #124 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Member Lifetime Supporter Varkyl's Avatar
    Kris,
    Very clean work. It is inspiring me to get out and do some cutting. Now to find the time to actually do it!
    I really miss hanging out at this place.
    '96 ZJ slightly modded with more in the works (5.3L HP44 and SF 14b)
    '03 WJ Limited 4.7HO - just starting the journey
  25. #125 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    thanks. its been a busy month with not much time to be able to spend on the ZJ.
    i should be back at it here soon.
There are currently 14 users browsing this thread. (0 members and 14 guests)
