Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension - Page 6
Page 6 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 126 to 150 of 396
  1. #126 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Member Grand Slam West Planner dads5.9's Avatar
    Broomfield, CO
    Kris,
    All I can say is WOW! Your stuff never fails to amaze me.
    '98 5.9L, Clayton LA on 35s
  2. #127 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Thanks for the props. This has been a fun build so far.
    I got some time to finish the gas tank skid.
    I needed to get this done so I can get the gas tank back in so I can drive this out of the garage and turn it around to work on the front suspension. The aluminum piece will be powdercoated black.
  3. #128 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    On to progress. Rear links are in. The truck is sitting at full bump on its own weight. Only about 1" higher than stock ride height with 37" tires. Woot Woot
    I even got to drive it around with no rear drive shaft or rear brakes. Felt nice to move it.
  4. #129 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Jun 2013
    oroville
    Looks real good. I can't wait to see what you do up front. How much higher will your ride height be?
  5. #130 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    4" higher than this. about 74" at the roof.
  6. #131 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    material is all on order for my Air Bumps.
    seals arrived today. Tubing and shaft material tomorrow. This should be fun.
    2.5" diameter 2" stroke air bumps on all 4 corners.
  7. #132 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got some more progress this weekend.
    drove it out of the shop and flipped it around to start on the front.
    i got the passenger doors modified and the rocker all cut out
    I pulled the stock front axle out and i also started on the front bumper.
    the bar is rolled to follow the curvature of the body. hard to tell in the pic.
    tried to keep it tucked close to the body.
    i need to find a way to fit a winch behind it while keepign the AC system.
  8. #133 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got the passenger side all wraped up
    just a bit of welding left. then onto the front axle.
  9. #134 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    My bumper sticks out about as far as yours and I was able to keep the ac with a winch. Just need to remote mount the solenoid box in the engine bay. I have about 3/4" between my engo9000 and the condenser.
  10. #135 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    So I’ve been a bit distracted lately.
    Made some progress on the air bumps.
    All the bodies made
    Honed ID with snap ring groves
    Got them back from the surface treatment. Liquide Nitrite coated and surface hardened.
    Started on the pistons
    Still lots of turning to be done on the lathe then off to the mill.
    And I picked up this a few days ago
    Chevy 2015 3500HD 6.6 Duramax. Had all the chrome wrapped white.
  11. #136 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Good looking Chevy... Definitely an improvement over that F-truck we drove from Seattle to Moab!
  12. #137 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    hahahah ya that ferd fteenthousand was a pile with no AC. this thing is PIMP!
  13. #138 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    LEHIGH VALLEY,PA.
    Damn! You are one crazy talented dude. I don't get to these here parts much anymore but am gonna keep comin back to see how this is comin.
    97ZJ 4"lift 32"KO's
    03WJ stock w/ upgraded injectors
    02 Express 3500 cutaway with utility box. (tool shed on wheels)
    80 FLHS
    77 XLH
    68 BSA 650L= '60s chopper
    Baaa aaa aaa, means NO!
  14. #139 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    More progress on the air bumps. Got the bottom caps done. The top caps done. And started on the threaded locking rings.
  15. #140 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i thought i posted this before but i guess i didn't here is a shot of the solid model for the air bump
  16. #141 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Two questions on the air bump. How did you figure out the valving, and also are you going to run a vent line to prevent crud from getting inside?
    Great work, the stuff you do is incredible.
  17. #142 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    i got my spring steel in today 0.012" thick and 0.015" thick. tomorrow i will be waterjetting all the valve shims for the air bumps.
    i also got a good jump on the front axle brackets. i just need the hydraulic ram in my hands to finish up the front end.
    would be really nie to get these cut out before the weekend. even though my buggy is blocking my garage since i blew the atlas and can't drive it in and out to work on the ZJ.
  18. #143 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    hydraulic bump stops are just very short air shocks. the shaft displaces the fluid increasing the pressure inside. you fill them with shock oil when they are compressed so they are 100% full. that way the air pressure ramps up very fast when they compress. the valving is there to control how fast the bump stop compresses and rebounds. without the valving it would be like a small spring. the valving is a fairly standard set of 0.012 thick shims for the rebound and 0.015" thick for the compression. once i get them in there the tuning process starts and you end up adding or removing shims all over the place. thats the fun part of rebuildable shocks.
  19. #144 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Cool, thanks. I can see how tuning them specific for the vehicle is necessary.
  20. #145 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    most people just mount them, fill em with nitrogen and think "wow that's better than before"
    tuning them is the fun part and hw you can really get the truck to ride like a Cadillac.
  21. #146 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Senior Member zj-monster's Avatar
    Jan 2005
    Topeka, Kansas
    Holy cow Kraqa! Good to see you building again! I just logged on for the first time in a few years. Looking forward to more of this build!
    Quote Originally Posted by CurtP View Post
    What a fucking concept, eh? How dare you bring logic to this thread. What are you, some kind of asshole?
  22. #147 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    thanks monster. i happy to be back building a full body rig again.
    the airbump parts got back from the anodizer. i had to go with EPIC Orange.
    95A urethane for the bump pads
    compression side of the piston
    bottom seal and buid bushing housing.
    locking rings on it.
    blamo!
    orange
    lock rings
    bottom seal/guide retainers
    you can see the rebound side of the pistons
  23. #148 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    You've come a long way since half-drunkedly typing in all caps
  24. #149 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    lol. yup hahaha
    even peter pan had to grow up.
  25. #150 Re: Family Wagon 1996 ZJ BUILD Cantilever Rear Suspension
    Orlando, FL
    Awesome stuff, thanks for keeping the build thread going for us to enjoy.
    www.grandslamsoutheast.com
    SOLD: 98 ZJ, 6" Long Armed, Locked 33" MTR, HP 9" and HP D30
    My Build Thread
    94 YJ, tons and 40s, no leafs, 5.3/4L60e
    04.5 Dodge 2500 CTD 4x4, Smarty Jr
