Project blue steel!!! - Page 3
Thread: Project blue steel!!!
Page 3 of 3 FirstFirst 123
Results 51 to 69 of 69
  1. #51 Re: Project blue steel!!!
    JohnBoulderCO's Avatar
    I hope you have several struts going inboard to the "frame"
  2. #52 Re: Project blue steel!!!
    did you just cap the ends with thin gauge sheet metal?
  3. #53 Re: Project blue steel!!!
    Would thicker metal provide a legitimate strength increase?
  4. #54 Re: Project blue steel!!!
    Cut and then rolled up the bottom
    Cut and rolled.
  5. #55 Re: Project blue steel!!!
    Quote Originally Posted by egg View Post
    absolutely. the ends will crumple if you use thing material.
  6. #56 Re: Project blue steel!!!
    Cut and rolled.
    i missed that. looks good!!!
  7. #57 Re: Project blue steel!!!
    Thanks guys!
    I'll get some more pics when I get home of the underside bracing.
  8. #58 Re: Project blue steel!!!
    not the best but here you go!
    Because Jeep.
  9. #59 Re: Project blue steel!!!
    Sep 2016
    Kamloops BC
    Looks great so far. Just started my 2000 WJ
  10. #60 Re: Project blue steel!!!
    Not super new but a few weeks ago I had some issues with the Dub running rough, rpm looping and no power.
    So after a reset(battery disconnect) it ran a ton better then slowly went back to rough again so it was time for some tlc...
    After an oil change I inspected the coil packs then proceeded to pull the spark plugs to find this...
    Wow...
    so then I put these in to hopefully get a little performance and clear some codes to help it run better ...
  11. #61 Re: Project blue steel!!!
    New issue
    Wife calls and says Jeep just dies while driving so she limped it home and we traded out she took my 9ner and I take her dub... no issues
    So I take it to work a few times and check for codes no new or current/active codes
    Doesn’t die or even stumble
    We take it as a family to town over the weekend and still no problems
    She calls again today and it’s dead, didn’t even make a 1/2 mile from the house but on a Main Street
    She pumps(pounds) the gas pedal and eventually it starts... drives fine and again no codes
    This has happened a few more times from what she said but she got it running quicker before so she never called
    Opt #1. Full rebuild
    Opt #2. Trade cars full time
    Opt #3. Trade for a Toyota
    Opt #4. Something simple to fix this?
  12. #62 Re: Project blue steel!!!
    Do you have a code reader that will data log? If so, hook it up and have it record while she drives it, it may pick up the issue.
  13. #63 Re: Project blue steel!!!
    Not really I’ll probably just have to drive it till it does it
  14. #64 Re: Project blue steel!!!
    Nov 2004
    Have you been welding on the car with the battery connected?
    Poetry in commotion.
  15. #65 Re: Project blue steel!!!
    Quote Originally Posted by SuicideTireZJ View Post
    Hasn’t been welded on in two years and no I always disco
  16. #66 Re: Project blue steel!!!
    As she sits now.
  17. #67 Re: Project blue steel!!!
    So I was able to get these codes to show but still drives good for me
  18. #68 Re: Project blue steel!!!
    They may be intermittent. A large evap leak can cause issues like a vacuum leak.
    BTW, I like your bumper construction! Gives me inspiration for my ZJ. A buddy has a tubing bender and a 1" die set which could make a nice frame. All the winch bumpers I find make it look like it has a massive under bite.
  19. #69 Re: Project blue steel!!!
    All that and quite a bit later the engine is done
    So now to look for a drop-get-me-by, or wait and put a good reman 4.7...
    OR!!! Build the 5.3 ls that I have sitting on a shelf and put that in...
