Thread: "Ideal" lift height for Clayton LA on ZJ?
Results 1 to 14 of 14
  1. #1 "Ideal" lift height for Clayton LA on ZJ?
    So I have had a Claytons L A set up for the last 3 seasons. To save some coin I used my original RE 3.5" springs with an ACOS in front and a 2" spacer in the rear. This "theoretical" 5.5" lift worked great on & off road originally, but sagged a bit over the next couple years. This was especially noticed when loaded with gear.
    The rear would bottom out and push the floor pan up. The front axle (wag d44) was even able to hit the oil pan once. I added bump stop height to solve the interferences but the issue was clearly lack of lift height.
    Fast forward to yesterday, just got done installing some new IRO 4.5" springs (on top of the spacers). Now this net 6.5" lift seams really tall. Maybe I was just used to my old lift. With only 33's there is ample clearance to fenders.
    Finally to my question: What is the ideal lift height to run the claytons kit? 4.5" is too little, 5.5" seems about right, 7" too high?
    I am willing to cut the coils on the new spings to tune the height a bit, but this will tend to stiffen the ride. Maybe the answer is to upgrade to 35's.
  2. #2 Re: "Ideal" lift height for Clayton LA on ZJ?
    35's would fill in those fender wells
  3. #3 Re: "Ideal" lift height for Clayton LA on ZJ?
    Senior Member egg's Avatar
    Apr 2006
    Denver
    5.5" with 35s get my vote
    Sent from my SM-G900V using Tapatalk
  4. #4 Re: "Ideal" lift height for Clayton LA on ZJ?
    May 2011
    Southeast Ohio
    I like these guys' thinking! 35's and the 5.5" springs!!!
  5. #5 Re: "Ideal" lift height for Clayton LA on ZJ?
    My ZJ begs to differ that 4.5" is too little. Although I do have 1" pucks in the back to compensate for added weight.
    Sent from my SM-N900T using Tapatalk
  6. #6 Re: "Ideal" lift height for Clayton LA on ZJ?
    jsteves's Avatar
    Fort Fun
    The 4.5" springs are stiffer than the 3.5" which I believe is why it works well for Dave but didn't add up for you Ted. I really liked my ZJ. I had. 7" RK springs but they only net 6" of lift with bumpers, gear, etc. I think you would like 5.5ish inches. I would go 35's either way though.
  7. #7 Re: "Ideal" lift height for Clayton LA on ZJ?
    Thanks guys! I've been looking for some deals on 35's on CL. We'll see if that happens before GSW this year.
  8. #8 Re: "Ideal" lift height for Clayton LA on ZJ?
    Salt Lake City
    I would agree that 4.5-5.5 inches is about right for 35's. Maybe 5-6 for 37's.
  9. #9 Re: "Ideal" lift height for Clayton LA on ZJ?
    I image the springs will settle a half an inch once I get the Jeep out of the garage and cycle the suspension a bit.
    In front rather that cutting the coils, I can remove the adjustment ring on the ACOS to get the minimum spacer height. On the rear I'll see how the ride height sits after I load some gear and add a full tank of gas.
    Should be at about 5.5" when all said and done.
  10. #10 Re: "Ideal" lift height for Clayton LA on ZJ?
    Yep. I ran 4.5" springs with a 1" puck in the front. The 4.5" springs in rear sat at about 5.5" of lift with the trimming I have. Was happy with the fitment of 35s. About 5-6" of bumpstops in the front are your friend with that setup.
  11. #11 Re: "Ideal" lift height for Clayton LA on ZJ?
    Salt Lake City
    bumpstops? I kid, I did have bumpstops about 1 inch from the control arm. I ran 9 down and 2 up though.
  12. #12 Re: "Ideal" lift height for Clayton LA on ZJ?
    Jul 2014
    United States
    Besides Rusty's who else makes a 5.5" coil spring?
  13. #13 Re: "Ideal" lift height for Clayton LA on ZJ?
    Apr 2006
    Denver
    Pick a company that has 4.5" springs, the spring rate you want. Then use spacers to get the height you want. amount of spacers needed will vary depending on armor, cargo, and other accessories anyways
  14. #14 Re: "Ideal" lift height for Clayton LA on ZJ?
    Jul 2014
    United States
    Quote Originally Posted by egg View Post
    Hey, just saw that you have pretty much the same specs that i would like to have in my jeep, are you satisfied with the 4.5 lift and 35? or do you think it could perform a little better if it was higher (5.5)?
    What gears are you running with those 35?
    and what's your current MPG's?
    Thanks for any input that you can offer
