Thread: GSW 2014 Parts Swap
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
  1. #1 GSW 2014 Parts Swap
    jsteves's Avatar
    Fort Fun
    I'll get this year's thread rolling!
    I have a set of Mopar D30 OPEN shafts as spares. Original to my Jeep. Good boots and joints. 130k miles on 'em. $75
    2 sets of Mopar D44 OPEN rear shafts as spares. One pair is original to my Jeep, the other was pulled at the yard. $75 per pair.
    JKS rear Adj. control arms. Less than 8kmiles on them, never off road so no scrapes, scratches or rust. I believe the will work for TJ, ZJ or WJ. They were in my WJ and I will include the JKS spacers for WJ use (really a stack of grand 8 washers). $200
    Adj. front upper control Arms. Were on my Jeep when I purchased it. I believe they are from Rocky Road. TJ, ZJ, XJ, or WJ. $90
    Fixed front lower WJ control arms from Rocky Road. Need new poly bushings. Were on my Jeep when purchased. $25
    Rocky Road WJ A Arm spacer. On my Jeep when purchased. $45
    Maybe some other stuff laying around....
  2. #2 Re: GSW 2014 Parts Swap
    Z's Avatar
    Might want to also post on Facebook
  3. #3 Re: GSW 2014 Parts Swap
    Anybody need 4.10s for dana 30/35? Or Yukon shafts for 35?
    Also who would be interested in a Waeco/Dometic fridge cf-18? I have a line on 2 and need only 1.
  4. #4 Re: GSW 2014 Parts Swap
    Fruita, CO
    Quote Originally Posted by K2 View Post
    How much?
    Build it. Lock it. Crawl it.
  5. #5 Re: GSW 2014 Parts Swap
    $180, you would be 2nd in line. I actually have 3 fridges right now, I have 2 18s and a 35 I am trying to figure out which one I keep. Justin has dibs on what's left.
  6. #6 Re: GSW 2014 Parts Swap
    SL,UT
    Anyone need a ZJ? I'll bring the black one is someone wants to purchase it
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  7. #7 GSW 2014 Parts Swap
    Fruita, CO
    I have a couple axles up for grabs!
    Ford 8.8 4:10 LSD
    Trussed and ready for triangulated uppers
    Ballistic fab diff cover
    W/disc brakes
    $450 obo
    96' zj hd 44a
    3:73 gears open
    Unbolted stock!
    W/disc brakes
    $250
    Also have 4:10 gears for a hp d30
    $50
    Zj steering box brace
    $25
    Zj steering box
    $50 obo
    and a few other d30 parts
  8. #8 Re: GSW 2014 Parts Swap
    Highlands Ranch, Colorado
    Feeler = We just swapped in a D44A into Kyle"s WJ and therefore have a WJ D35 with 3.73s for sale. Complete and in good shape minus the brakes. Let em know if hter is interest and I can bring it to GSW.
  9. #9 Re: GSW 2014 Parts Swap
    Jan 2008
    Basalt, CO
    I have a WJ Dana 30 w/ 4.56s, diff cover (can't remember the brand), and JKS tie rod. Needs new everything from BJs, to tie rod ends to possible breaks. $200 obo
    Brian
  10. #10 Re: GSW 2014 Parts Swap
    I have the following available:
    ZJ Rubicon Express 3.5" springs, F & R (have sagged about an inch)
    ZJ/XJ Rubicon Express HD front track bar and frame side mount (new axle side bushing)
    Ford 8.8 axle shafts, perfect for trail spares
    Dana 44 TrueTrac, for 3.92 and numerically higher gears. was used in front application. (this is the LS with the helical gears, no clutches to wear out)
    Single Poly engine mount insert, can be used on 96-98 trans mounts (which is why I have only one).
    Various 231 and 242 shifter bezels
    ZJ specific 231 selector switch
    Kevins/JKS ZJ front track bar, needs new bushings. Also the frame side mount is home made.
    I'm looking for:
    35's
    17X8 wheels with a 5x5.5" bolt pattern
  11. #11 Re: GSW 2014 Parts Swap
    Looking for a busted WJ CV shaft. I want to use the outer only portion of along with a spare unit bearing hub for a trail fix. I will take a standard broken Dana 30 outer but prefer a WJ type so the tone ring works with my speedometer.
  12. #12 Re: GSW 2014 Parts Swap
    jsteves's Avatar
    Fort Fun
    Might have something better you. I pulled the fake "stub" shaft from a 2wd WJ as a trail spare but don't need it any longer since I went to the 44 Front. Also have a D30 cover and spare set of Dana 30 WJ shafts if anyone is interested.
  13. #13 Re: GSW 2014 Parts Swap
    Justin,
    The 2wd drive stub shaft is absolutely perfect and what I was really looking for. Thanks.
    We have spare shafts for Kyle's Jeep. Mine is 30 splines with a locker so I am just looking for an emergency spare in case I break a shaft.
  14. #14 Re: GSW 2014 Parts Swap
    I forgot to mention that that I'd be willing to give this stuff away if it can find a good home, or add it to the pizza in the park give-away pool.
  15. #15 Re: GSW 2014 Parts Swap
    I will give you something for those 8.8 shafts and 231 selector bezel.
  16. #16 GSW 2014 Parts Swap
    JohnBoulderCO's Avatar
    I have a stock Ford 8.8 Explorer driver's side shaft, if someone else needs an axle shaft.
  17. #17 Re: GSW 2014 Parts Swap
    Fruita, CO
    Ford 8.8 axle shafts, perfect for trail spares!
    Are you sure about giving them up? They have come in handy!
  18. #18 Re: GSW 2014 Parts Swap
    I pick up a set of alloys. These were my trail spares.
  19. #19 Re: GSW 2014 Parts Swap
    You have both sides Ted? Seems like you used one of them already.
  20. #20 GSW 2014 Parts Swap
    Fruita, CO
    I also have a mile marker winch 8000lb elec winch brand new still in the box!
    $300 obo
  21. #21 Re: GSW 2014 Parts Swap
    jsteves's Avatar
    Fort Fun
    I have at least 2 gallons of unopened green prestone. Free for anyone who could use it.
  22. #22 Re: GSW 2014 Parts Swap
    Fruita, CO
    If you could bring it I can use it!
  23. #23 GSW 2014 Parts Swap
    jsteves's Avatar
    Fort Fun
    Sure thing. Assuming you are still good for those shafts?
  24. #24 GSW 2014 Parts Swap
    Fruita, CO
    You bet!
  25. #25 Re: GSW 2014 Parts Swap
    jsteves's Avatar
    Fort Fun
    Great!
