242 went out
Thread: 242 went out
Results 1 to 9 of 9
  1. #1 242 went out
    Sac
    I have a 242 that worked great for 10 years but now when I put it in any type of the 4 wheel drive options, it wont engage the front drive shaft.
    If I leave my hubs unlocked and put the case in 4wd ft or pt or low I can spin the front shaft freely. Sometimes it trys to lock and if it does the slightest bit of pressure will pop it out.
    Took the case apart and found this heap of metal on the magnet. the shift forks looks straight to me and seem to operate correctly when i shift and watch the forks move. The inside smells horrible like burnt fluid, and some of the gears on the differential are black. The last pic with the red circle around it also looks concerning, I assume this hole is not suppose to be there?
    Thoughts or suggestions on what to look for or what you think is wrong is appreciated. First time I have taken this apart.
  2. #2 Re: 242 went out
    Senior Member IndyZJ's Avatar
    Apr 2007
    Indianapolis
    The front fell off.
    You already circled it. Time for another new-to-you t-case.
    re: testy
    scrotum.
  3. #3 Re: 242 went out
    Sac
    as always appreciate the help Indy. I see the differential is not suppose to be like that after searching around online for other pics. As for the 4wd not engaging tho, could that be shift for related? because its my understanding that dif does not spin unless its in full time correct?
    I was trying to but yes looks like I better start searching for a new to me case.
  4. #4 Re: 242 went out
    Nov 2013
    Pakistan
    So, nice video it is,a bundle of thanks for sharing with us on this board.
  5. #5 Re: 242 went out
    The front fell off.
    I LOL'd for real.
  6. #6 Re: 242 went out
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  7. #7 Re: 242 went out
    SLC, Utah
    So swap it out and get on with your life, they are under $100 from most junkyards. And if you post asking which 242 to replace it with then there really is no hope....
    96 4.0 ZJ, 4.5in RE coils with Teraflex arms, Yukon gears, ARB front bumper, 33x12.50 M/TR's, homemade OBA setup....
    97 with stuff....
  8. #8 Re: 242 went out
    Sac
    do i replace it with a 21 or 23 spline 242?
    forgot about this thread. I ended up replacing just the diff, threw in a new chain and bolted it back up in time for a thanksgiving day trip.
  9. #9 Re: 242 went out
    Senior Member Lifetime Supporter ZJ TINS's Avatar
    Jun 2006
    Cedar Rapids Ia
    Not to hijack but fpkites video, every time I see it I marvel at the fact that someone actually makes the US politicians look good at least for a few minutes.
    “I ask, sir, what is the militia? It is the whole people, except for a few public officials.”- George Mason
    "The beauty of the second amendment is that it will not be needed until they try to take it." -Thomas Jefferson
    “The great object is that every man be armed.” -Patrick Henry
