GSW 2013 Carnage Report - Page 2
Thread: GSW 2013 Carnage Report
Results 26 to 50 of 52
  1. #26 Re: GSW 2013 Carnage Report
    Boulder, CO
    Easiest thing to do is replace with a D60 AFAIK.
    -Ryan
  2. #27 Re: GSW 2013 Carnage Report
    Tyler, I may still have my open D30, although it's from my ZJ. I don't see any reason why they'd be different. If I still have the carrier you can have it, spider gears and all. I'll check tomorrow and shoot you a text.
  3. #28 Re: GSW 2013 Carnage Report
    Boulder, CO
    If he changes carrier to an open, instead of LSD, he needs to change his axle shafts as well.
    Or are you saying just for him to use the spiders?
    -Ryan
  4. #29 Re: GSW 2013 Carnage Report
    Mar 2011
    Lakewood, CO
    I have thought about going the D60 route up front with 4.56's and 40's filled with helium to balance the added weight and the limited clearance. That should pair well with the 3.73 rear on 35's.
    01 WJ
  5. #30 Re: GSW 2013 Carnage Report
    I'm just saying he can have the spiders.....if I still have the carrier.
  6. #31 Re: GSW 2013 Carnage Report
    Apr 2013
    Price, UT
    Tyler, I have my old LP D30 LSD (2004 WJ) sitting in my yard that no one wants to buy from me lol. If you want parts from it to fix yours, let me know.Id rather help you out than have it sit in my yard and rot away.
  7. #32 Re: GSW 2013 Carnage Report
    Mar 2011
    Lakewood, CO
    Looks like I'll be hitting the junk yard this weekend because I broke more than just the gears. Holy crap there are lots of parts in one of these limited slips.
    This is a good time to learn how to set up a ring and pinion before I build my new axles.
    Sent from my SCH-I605 using Tapatalk 2
    01 WJ
  8. #33 Re: GSW 2013 Carnage Report
    Well I think it's safe to say you found the source of the noise!
  9. #34 Re: GSW 2013 Carnage Report
    I was thinking the same thing.
  10. #35 Re: GSW 2013 Carnage Report
    Boulder, CO
    Told you it wasn't your axle shaft
    -Ryan
  11. #36 Re: GSW 2013 Carnage Report
    What gears are you running and what all broke?
  12. #37 Re: GSW 2013 Carnage Report
    Mar 2011
    Lakewood, CO
    Completely stock hydrolock with 3.73's. The dingus that applies pressure to the clutches shattered and shards of it gouged the clutches and the side/spiders were skipping. Junk.
    01 WJ
  13. #38 Re: GSW 2013 Carnage Report
    A girl I work with just had the front end replaced on her WJ, bent/cracked tubes. She is checking to see if and what parts they have left over.
  14. #39 Re: GSW 2013 Carnage Report
    SLC, Utah
    I put a crease in my passenger rear door on Kane Creek. Not to big, but its there. Otherwise no carnage. Honestly though I intentially took it easy this year.
    Where on the trail did this happen?
    97 with stuff....
  15. #40 Re: GSW 2013 Carnage Report
    Dec 2006
    A few of us got a decent rub about mid-trail where hugging the rock to the right got you through pretty level, but veering left to miss the rock tried to put your passenger side glass all over said rock
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  16. #41 Re: GSW 2013 Carnage Report
    SLC, Utah
    Quote Originally Posted by fpkites View Post
    I'm trying to picture where on Kane Creek this is, we run it 2 or 3 times a year and never came close to any body damage. But I will say I hate the wash outs on the first 1/3 of the trail that get you a little sideways.
    97 with stuff....
  17. #42 Re: GSW 2013 Carnage Report
    Dec 2006
    I'll have to see if we have a pic of the spot.
    There were a ton of spots that were washed out pretty severely.
    Jim Karlin
    GSW 2010 Pics
  18. #43 Re: GSW 2013 Carnage Report
    SLC, Utah
    I think this is the spot you had in mind?
    97 with stuff....
  19. #44 Re: GSW 2013 Carnage Report
    Dec 2006
    Quote Originally Posted by black_zj View Post
    Yep, that's the spot. If I remember correctly it was MUCH more washed out this year than in your pic. Enough driver to miss the big rock would lean your passenger side on the boulder and leave behind a glass deposit
    We could possibly have gone straight longer than we did, then turned down, but it looked like it was heading straight for vegetation, which to me is off trail.
    Even with your line (2 years ago if your camera time stamp in the last pic is correct), your RR quarter panel was pretty dang close to the boulder.
    How long of a time between pic 1 and pic 4? I'm thinking 4 is much later than 1 unless you put the water jugs in the rack mid-obstacle
    Jim Karlin
    GSW 2010 Pics
  20. #45 Re: GSW 2013 Carnage Report
    SLC, Utah
    Those are old pictures from 2 different trips in 2011 with the black ZJ. When we were there this May it was washed out a bit more than before, below is the first picture-worthy moment of the day on this trip though, wife stayed in the Jeep up until this. I like the variety of Kane Creek, especially for lunch spots by the creek if you have kids or dogs, but those washed out spots definitely can make you nervous in a taller rig.
    97 with stuff....
  21. #46 Re: GSW 2013 Carnage Report
    Nov 2007
    Fountain Hills, AZ
    Ok...my carnage report (finally). Hit deer with pickup on the way there about 60 miles south of Moab. Had to be towed in and had it repaired there at Arches Repair. Total cost to repair pickup was over $8,100.00 and it took 6 or 7 weeks. Just went back up there this last weekend to pick it up and drive it home. O....and I bent the drive shaft on my Jeep while there and got another one installed at Moab 4x4 outpost for $220 bucks.
    1998 5.9, 7" RockKrawler, HP30, Warn lockouts, E-locker, 231 TC, winch, bumpers, sliders, etc, + 1 bone stock 5.9 daily driver
  22. #47 Re: GSW 2013 Carnage Report
    Lakewood, Co.
    God that's crazy it took so long to get done.
    How'd you bend the drive shaft?
    Quote Originally Posted by Nakidgun View Post
  23. #48 Re: GSW 2013 Carnage Report
    Nov 2007
    Fountain Hills, AZ
    Quote Originally Posted by Colorado 5.9 View Post
    Bent the drive shaft the first day on Cliffhanger. Not so bad it wasn't drivable, but couldn't go over 40 mph without it vibrating like crazy. Moab 4x4 outpost fixed me up. He has a whole stack of used drive shafts out back just picked through them until we found one the right length. The pickup sat there for over 3 weeks before the insurance company FINALLY authorized the repair. Took them two weeks to get an adjuster out to look at it. Then another week or so to order the parts. Insurance company (American Family) really drug their feet. But, on the other hand, when they finally did come through they paid for more than I needed. For example the hood and one fender were barely dented....easy fixes.....but they put on whole new hood and fender. Didn't scrimp on the repairs...just took them forever to authorize it.
  24. #49 Re: GSW 2013 Carnage Report
    Lakewood, Co.
    Well at least they paid for everything.
  25. #50 Re: GSW 2013 Carnage Report
    I finally drained the trans. The filter was a bit clogged by the pickup. I put in 7 quarts, should only be 4, and it seems to be driving fine. I need a longer trip but around the neighborhood it did fine. My neighbor thinks it was low on fluid. I checked twice with other people watching. However, his theory is that if it was clogged, the fluid would be in the pan and not in the rest of the trans so it would seem full. We will see.
