Thread: WJ Rear Axle Truss & Skid (d44a or d35)
Results 1 to 23 of 23
  1. #1 WJ Rear Axle Truss & Skid (d44a or d35)
    Member quadratokn's Avatar
    Illinois
    Valhalla Fabrication is excited to announce the NEW WJ Rear Axle Truss & Skid. Finally, the WJ Grand Cherokee has a good truss in production! This fits both the Dana 44a and 35. Some have even made the skid work on a ZJ! This heavy duty truss is designed to be used with your factory A-arm OR a 4-link suspension.
    Features Include:
    - Your choice between an A-arm version and a 4-link version. A-arm version can easily be converted to 4-link even after installation.
    - 1/4" steel, skid uses 3/16" steel
    - CNC laser cut to tight tolerances
    - CNC bent
    - Reinforced with interlocking 1/4" gussets for strength and easy assembly
    - Raises the A-arm 2" so you save money on an A-arm spacer
    - Hardware included for the A-arm
    - May save you from replacing wheel bearings that wear faster due to excess flex from the steel tubes pressed into the aluminum center section
    - Does not interfere with anything except for the brake lines, which need to be re-routed
    - Welding required
    Truss: $200 with FREE shipping
    Skid: $115 with FREE shipping
    Website: valhallafab.com
    Email Address: valhallafab@gmail.com
    Phone Number: 847-595-1134
    Facebook Page:
    facebook.com/ValhallaFab
    CLICK HERE FOR PICTURES
  2. #2 Re: NEW Dana 44a Axle Truss and Skid
    Apr 2013
    N IL
    PMed, I want one for sure..
    Cook County IL? If so cool I'm in Winnebago county so shipping shouldn't be too much
    That should work good with my adj. A arm.
  3. #3 Re: NEW Dana 44a Axle Truss and Skid
    Illinois
    Quote Originally Posted by USFORCES View Post
    PM replied. Your aftermarket control arm will bolt up to the truss for sure.
    Thanks!
  4. #4 Re: NEW Dana 44a Axle Truss and Skid
  5. #5 Re: NEW Dana 44a Axle Truss and Skid
    Highlands Ranch, Colorado
    Nice to see them ready, I will be ordering one soon for my Son's DubJ.
  6. #6 Re: NEW Dana 44a Axle Truss and Skid
    Apr 2013
    N IL
    I sent you another PM on 04-10 if you could would you answer it.
    Thanks
    USFORCES
  7. #7 Re: NEW Dana 44a Axle Truss and Skid
  8. #8 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
  9. #9 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Senior Member speedmontzj's Avatar
    piedmont al,
    Would it be possible to use this on a zj if you took the a-arm mount off and mounted it to a 1/4" plate diff cover instead? I lost my clayton truss when i sold my tons, and i have to get one anyway.
    "Intelligence is a burden that only the truly ignorant are willing to bear" B. Franklin
  10. #10 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Illinois
    Quote Originally Posted by speedmontzj View Post
    I bet it would probably work!
  11. #11 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Nov 2013
    Chattanooga TN
    Still making these?
  12. #12 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Illinois
    Quote Originally Posted by DaveS View Post
    Still making these?
    Definitely, we have several on the shelf.
  13. #13 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Jan 2012
    utah
    How much to ship a skid usually?
  14. #14 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
  15. #15 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Jan 2012
    utah
    Cool I just might be placing an order soon. I have a zj and am just looking to protect that aluminum housing
  16. #16 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
  17. #17 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Jan 2012
    utah
    Now just gotta quite spending money on the XJ long enough to get thus for the ZJ
  18. #18 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
  19. #19 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Jan 2012
    utah
    That's a good enough reason.
  20. #20 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
  21. #21 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Jan 2009
    Tempe, AZ
    I'm in the market to beef up my 44a and am running Clayton's long arm kit. You guys still making these? I know the thread is a little old. Also, does the truss and skid come welded, or just in separate pieces?
  22. #22 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Illinois
    WOW my post/response to this disappeared. I'll respond again so everyone knows...
    We will ALWAYS be selling this truss and skid.
    And they do not come pre-welded.
  23. #23 Re: NEW WJ Rear Axle Truss & Skid (d44a or d35)
    Quote Originally Posted by quadratokn View Post
    None of your posts were deleted by anyone here, and there was never a response posted to LSRGreg's question. However, if you would like to continue to use the Vendor Forum to advertise your products I would ask that you renew your vendor subscription.
