44 Alum build
Thread: 44 Alum build
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
  1. #1 44 Alum build
    Mar 2005
    LasVegas
    my 35 is crapping out so im building a 44 Alum for it
    as it sits now
    whats coming
    : http://s159.beta.photobucket.com/use...%20skid?page=1
  2. #2 Re: 44 Alum build
    Dec 2006
    You're going to rotate it 90 degrees? Amazing!!!
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  3. #3 Re: 44 Alum build
    Don't forget to weld the tubes to the center.
  4. #4 Re: 44 Alum build
    SLC, Utah
    What's "built" about it? Are you building a truss?
    97 with stuff....
  5. #5 Re: 44 Alum build
    Mar 2005
    LasVegas
    [QUOTE=black_zj;339950]What's "built" about it? Are you building a truss?[/QUOT
  6. #6 Re: 44 Alum build
    Jun 2006
    Cedar Rapids Ia
    I hope you got it free cause for the effort an 8.8 is a better option. That why you see no build threads here or Pirate for an Aluminum D44.
    Mar 2008
    westerville, ohio
    Agreed. The 88 is stronger and has a wider aftermarket. With the 88 truss ZJ swap kit from artec you would be crazy not to use a 88
  8. #8 Re: 44 Alum build
    Quote Originally Posted by polar_jeep_04 View Post
    8.8 is a stronger axle, but he has a WJ, so he'd need wide spacers/ adapters to match the front. The 44A can be a decent axle if set up properly and is a good match for a 30. A real truss and a skid would fix two of it's bigger issues, other than extremely limited aftermarket support.
    I would figure out a way to tie the differential into that "truss"/ glorified wishbone mount and weld up a BTF diff cover for it. It would probably be easiest to tie it all together through the diff guard, but there may be an easy way to tie into the stock wishbone mount, too.
  9. #9 Re: 44 Alum build
    Member quadratokn's Avatar
    Illinois
    That's the plan.
    The market is small enough as-is, those that warrant a need for a 44a truss aren't likely going to need something that spans from flange to flange, etc etc. At that point you're better off building a 60, 14b, 9, etc.
    I'd bet money on snapping a shaft or splitting a carrier cap before bending a tube. There's too many variables to say for certain though.
  10. #10 Re: 44 Alum build
    It's a good product, especially for the WJ crowd as the vast majority that are even wheeled are not abused beyond the survivability of a 44A's components - the biggest problem is the housing itself and this design at least takes a good deal of strain off of the aluminum chunk, ties the tubes together, and adds a skid so you don't grind through the bottom of the pumpkin.
  11. #11 Re: 44 Alum build
    Mar 2005
    LasVegas
    As mater of fact I did get it for free and I could have gotten an 8.8 if I would have wanted it.
    However for this WJ build it is going to be my daily driver/ expedition/ gold prospecting rig which will never see any bigger than 33 inch tires, it will be wheeled and it will be protected, after rear is done up
    and as soon as quadratokn hookes me up with the truss and skid i will move on to sliders then to bumpers,
    The 44 will bolt in uses same lug pattern, same e brakes has the same gear ratio as my front axle has and is plenty strong enough for what i need it to do.
    Mar 2008
    westerville, ohio
    I didn't even think about it being a WJ 'doh! My bad. I have ZJ on my mind.
  13. #13 Re: 44 Alum build
    Jun 2006
    Cedar Rapids Ia
    Well good luck, the Al center will be tough but it will be interesting to see what you come up with.
  14. #14 Re: 44 Alum build
    Mar 2005
    LasVegas
    making it purty
    The i ordered this lol
    Axle all cleaned up just need parts
  15. #15 Re: 44 Alum build
    Mar 2005
    LasVegas
    Got diff cover in last night made it purty tonight
    Should have rest of the parts next week
  16. #16 Re: 44 Alum build
    SLC, Utah
    One thing to keep an eye on is the BTF cover rubbing the gas tank skid, happened to mine until I did some adjusting.
    97 with stuff....
  17. #17 Re: 44 Alum build
    Mar 2005
    LasVegas
    got truss last night got to start on it tonight seems very nice!!!
  18. #18 Re: 44 Alum build
    Mar 2005
    LasVegas
  19. #19 Re: 44 Alum build
    Mar 2005
    LasVegas
    made som more progress tonight 3 hours of welding
  20. #20 Re: 44 Alum build
    Mar 2005
    LasVegas
    making it weather proof
  21. #21 Re: 44 Alum build
    Mar 2005
    LasVegas
    got it installed today no major probs ended up using D35 backing plates didnt even have to crack a break line.
    Did have to drill and tap a new hole for axle vent and break line attachment, I will be getting a braided steel line to replace it but it works for now.
    Sway bar hits the BTF cover bad had to take it off for now going to have to make some spacers for it not to happy about that!
    Also it looks like it my hit the tank at full compression got to check that out still.
    I forgot about the drive shafts being different and i was in bind at time cuz this is my only vehicle at the moment and since I plan on a hack and tap later I just cut 1 inch from output shaft and yoke seems to work for now.
  22. #22 Re: 44 Alum build
    Mar 2008
    westerville, ohio
    This that the brake line going past the bottom of the diff cover?
  23. #23 Re: 44 Alum build
    Mar 2008
    westerville, ohio
    I still think a 8.8" would have been better. If the only grip is the narrow axle the adapter to make it 5x5 would have offset that.
  24. #24 Re: 44 Alum build
    Mar 2005
    LasVegas
    That was the rear sway bar hitting the BTF diff Cover
    "I still think a 8.8" would have been better. If the only grip is the narrow axle the adapter to make it 5x5 would have offset that"
    8.8 prob would be better but I got this 44 for free so that helps and I didn't have to buy a bracket kit drive shaft adapter re drill axel to 5.5 figure out how to get ebrake to work ect ect ect...
  25. #25 Re: 44 Alum build
    Jan 2013
    Lake George, CO
    The swaybar spacers IRO sells will keep it from rubbing on the BTF cover.
    Did you toss in a lunchbox locker while you had it apart?
    02 WJ, 6.5 RC-LA, IRO springs, crossmember, xfercase skid, Bilsteins, BTF covers, Aussie, rear truss, front sleeved, gussets, RCVs, 10k hidden winch, swingout tire carrier, JCR sliders, 3 catback, Airraid, 265/75 Duratracs
