The dreaded to-do thread...GSW 2013
Thread: The dreaded to-do thread...GSW 2013
Page 1 of 3 123 LastLast
Results 1 to 25 of 75
  1. #1 The dreaded to-do thread...GSW 2013
    Dec 2006
    Upper/Lower balljoints - DONE
    Steering box - DONE
    Drill 4th hole in uniframe - DONE
    Trans filter and gasket - DONE
    Adjust tcase linkage so I can hit all 4 modes - DONE
    Spare Fluids - DONE
    F/R diffs - DONE
    TCase - DONE
    Crankcase - DONE
    Upper control arm bushings - DONE
    New/used RE coils to replace old tired Teraflex - chase down CLNinja
    Denver shitty weather needs to happen in the middle of the week instead of the weekend so I can get this shit done, dammit!!!
    Also - when I pull into Moab, a KOR bumper just might be waiting for me (I have the most kickass wife in the world )
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
    All I have to do is put a working tcase back in.
  3. #3 Re: The dreaded to-do thread...GSW 2013
    Build and burn on all brackets, tabs, truss etc. for Dana 44 and 60 (they were FREE, so why not)
    Ring and pinion for both, 4:88
    Hydro assist
    New wheels for new lug pattern
    New (correct) Coilover springs install
    Build new tube doors
    Lube ALL JJ's and suspension parts
    Rocklights
    Create playlists
    Neil R.
    Funniest thread on MC
  4. #4 Re: The dreaded to-do thread...GSW 2013
    Really cool on the bumper Jim!
    Me, first need to look at my ZJ and build the list.
    i do know that I want to et a trail run together on a road by Gateway, CO on the 30th of this month. That will probably help me start my list.
    1. Replace headlights with bone yard salvaged units and bracket tabs.
    '04 Honda Civic - my DD
  5. #5 Re: The dreaded to-do thread...GSW 2013
    Mar 2011
    Lakewood, CO
    There is no rear axle under my Jeep.
    Finnish rear L/A's
    Rear shocks
    tranny fluid/filter
    make sure brake lines are ling enough and secure
    build skidplate
    build cargo containment system
    If all of the above gets done, build 9" and install 4.56 gears in front.
    BTW I need either a 17" 5 on 5 wheel or a 35" tire for a 16" wheel.
    Shakedown run before last WKND in April would be nice.
    01 WJ
  6. #6 Re: The dreaded to-do thread...GSW 2013
    Jan 2012
    durango, co
    Somehow make my inside the disc rodeo ebrakes work. Adjusted out as far as I could to still be able to put disk hat over them and no dice yet
    Mount up harnesses
    Get spare shafts for waggy and isuzu axle just in case
    Get spare steering box or sector shaft
    Radio antenna, cb antenna
    Junkyard source some 44 hubs
    A hundred other things.
  7. #7 Re: The dreaded to-do thread...GSW 2013
    Option A: Do nothing but drive to Moab.
    Option B:
    - Install new F track bar
    - Swap in 231
    - ReGear F/R axles
    - Install front ARB locker
    - Replace trans mount
    Option A is looking good!
  8. #8 Re: The dreaded to-do thread...GSW 2013
    Boulder, CO
    Mine is similar Ted,
    Option A: Do nothing (except change some fluids and perhaps a u-joint or two).
    Option B: I have a baby, I can't afford to upgrade anything anyways
    -Ryan
  9. #9 Re: The dreaded to-do thread...GSW 2013
    Haven't you seen "Honey-Boo-Boo"? Kids are money makers!
  10. #10 Re: The dreaded to-do thread...GSW 2013
    Jun 2006
    Cedar Rapids Ia
    From 3 years ago
    -shorten front disco's
    -ford e-fan... if time
    New
    -boatsides
    -rear brakes or e-brake adjust not sure till I get in it
    -new road lights (screw KC, got Hella now)
    -fix glove box lock (bent latch)
    Not gonna happen
    -polish and port intake, have on the bench but too busy and too dirty (gotta organize the garage)
    -glass headlamps
    -8.8 rear axle with matching 4.11 gears in front
    -front long arm
    -heated front seats
    -replace driver side seat motor
    -used 33" MTR's on junkyard rims
  11. #11 Re: The dreaded to-do thread...GSW 2013
    Jun 2006
    Cedar Rapids Ia
    Only if you have the brain of a Chimpanzee.
  12. #12 Re: The dreaded to-do thread...GSW 2013
    Jun 2006
    Cedar Rapids Ia
    Ted_Z get a baby food grinder. Not sure if this is your first or if you know about these but they are fantastic as you get your young one off liquid onto solids. I try to point these out to every newborn parent I see.
  13. #13 Re: The dreaded to-do thread...GSW 2013
    Highlands Ranch, Colorado
    On the must do list on my WJ is a new radiator. Then maybe build a rear bumper.
    We are thinking about bringing Kyle's WJ. His will need sliders first. Well see.
  14. #14 Re: The dreaded to-do thread...GSW 2013
    Fruita, CO
    Way to much...
    Change/ check all fluids
    HP 44 purchase and swap[ purchased ]
    Finish upper rear links and the truss[DONE!]
    Finnish tube fenders
    Buy and install winch[Done!]
    Finish front bumper and front end
    Find electrical issue (yeah right)
    Grease all.
    Rear locker? ...
    find time and money to do half of this.
    More?
  15. #15 Re: The dreaded to-do thread...GSW 2013
    Put about 70 miles on the Jeep today driving it around town. Most everything seems to be working really well right now. Few small things to get done, but the junkyard t-case is doing great. Most miles I've put on my ZJ in one day without it breaking in a LOOOONG time.
  16. #16 Re: The dreaded to-do thread...GSW 2013
    Mar 2011
    Lakewood, CO
    Well, I scratched the 9 off the list for now and am elbow deep in a 231 swap.
    While I am under there and in a pile o oil it will be the perfect time to chenge the tranny fluid and filters.
    Anybody know how much fliid it holds off hand? WJ V8 auto?
    01 WJ
  17. #17 Re: The dreaded to-do thread...GSW 2013
    Seems like my wife's 01 was about 6-7 quarts for pan drop and filter replace, but it is also a 4.0L.
    My list just got longer after bending my rear driveshaft yesterday on a ledge climb.
    Swap in SYE 231
    Rotate rear axle yoke up towards t-case
    Measure length for new slip drive shaft and calc for full droop and full stuff
    Check brother's "extra" DC driveshafts and if no-go, order replacement drive shaft
    Check clearance on ledges before climing going forward...
  18. #18 Re: The dreaded to-do thread...GSW 2013
    Junior Member 93 grandwagoneer's Avatar
    Jul 2007
    huntington beach
    Regear, install hp30, find out why t case is making noise change all fluids, find air leak in my Arb locker, new water pump and I'm sure I'm forgetting some things
    rick aka woody
  19. #19 Re: The dreaded to-do thread...GSW 2013
    Quote Originally Posted by PassRunnerZJ View Post
    Check clearance on ledges before climbing going forward...
    Why bother, the uni-body will bend for you.
    Dec 2006
    Rock lights!!!
    (Or should that be lock rights? )
    These came on the slow boat from china today (I know, buy American, but try sourcing USA made LED strip)
    Jim Karlin
    GSW 2010 Pics
  21. #21 Re: The dreaded to-do thread...GSW 2013
    Lakewood, Co.
    Maybe I might get mine on this year. HA!!!!
  22. #22 Re: The dreaded to-do thread...GSW 2013
    SYE is in, still need to get the fluid in and attach the lever and electronics and then get the rear upper adjustable control arms in, spin the rear diff up, and get a driveshaft figured out.
  23. #23 Re: The dreaded to-do thread...GSW 2013
    Dec 2006
    Adding HPOP o-rings and plug on the tow rig...dropped a c-note tonight on parts, and grabbing the line disconnect tool from Dave in the next week or so.
    Cap/Rotor, air filter (Amsoil one is getting nasty despite cleaning, plus some blow-by) - DONE
    Friggin list grows like my kid
    Jim Karlin
    GSW 2010 Pics
  24. #24 Re: The dreaded to-do thread...GSW 2013
    I put the new radiator in this weekend. What a pain in the ass. I went ahead and put in new radiator hoses, new transmission cooler lines, new cap and serpentine belt. Considering the new water pump and thermostat I did last year, I have a completely new cooling system.
    Basically I am ready for GSW. Now to prep Kyle's WJ with sliders and a front diff cover. Not sure if we will be ready for his or not. Lots of travel for me between now and June.
    By the way did I mention the radiator was a pain in the ass?
  25. #25 Re: The dreaded to-do thread...GSW 2013
    It was a good weekend to wrench.
    Finally replaced my bent driver's side 8.8 shaft. It was nice to see that the splines were straight after a season on 37's.
    Fluid change for the 231. I like to do that often now and look for metal and/or plastic bits after going through a few mode forks. I have been running Mobil1 5W-30 in the T-case now. Got that tip online and from the local transmission shop.
    Replaced my leaky thermostat. Easy job.
    Last on the list, still need to replace my worn track bar bushing, but don't we all.
