Killallblues 2002 wj - Page 4
Thread: Killallblues 2002 wj
Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 161
  1. #76 Re: Killallblues 2002 wj
    Member killallblue's Avatar
    Jan 2013
    baltimore
    No updates it snowed so I went and got a few pics
    o I forgot to post one update I'll do that in a few
  2. #77 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    than i did my fender trim finally
    put crash tape over my holes from my light bar to hold me over
  3. #78 Re: Killallblues 2002 wj
    looks liek you could use a larger tire. or lower it a bit. the wheel wells look huge!!!
    i liek it.
  4. #79 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    thank you and the plans are for now to do a axle swap in the late summer or fall depending and go to 37s just have to do alot of research im new to axle swaps lol
  5. #80 Re: Killallblues 2002 wj
    sweet. lookign forward to the details on the swap. i remember when i did my first. i was nervous about makign sure everything was compatible. in the end it was a piece of cake.
  6. #81 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    no updates just snow pics im just saving for axles right now and i have a parts jeep i have to pick up in a week or so another steal blue pearl im going to use the hatch and make a tail gate and make trail doors and shit from it and keep the motor to stroke and sell the rest
  7. #82 Re: Killallblues 2002 wj
    Fruita, CO
    That's really a great color!
  8. #83 Re: Killallblues 2002 wj
    Jan 2015
    Callahan, Florida
    35 12.50 17 mud grapplers? On you 4" inch coils and 4" long arm kit?
  9. #84 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    Quote Originally Posted by fischerry View Post
    no im at 6.5 and yeah thats my tire size
  10. #85 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    well got a chance to see if the cutting worked and if i need more and what bumps it needs again looks good up front need coil retainers and it will be perfect and new coil buckets at the bottom
    me next to stock
    also swapping for a 04 grill
    also front shaft figured out just need to order it
  11. #86 Re: Killallblues 2002 wj
    Jan 2015
    az
    That's a good looking rig. I can't believe wjs came without any spring retainers at all, at least it's an easy fix.
    Does your drag link really hang as low as that last pic makes it look?
  12. #87 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    nah thats the stabilizer it gets twisted around every time i go out i need to relocate it
  13. #88 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    got to work on my dash cant wait to have this in and ill have a big *** gps and what not lol
  14. #89 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    well i swapped motors again from my parts jeep lol this time took 2 days
    got the header on
  15. #90 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    meet with a few people
    then i started on a led project for my 3rd brake light
    testing
    and made another that dose brake and turn signal
  16. #91 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    part jeep is gone buddy came and got the roof for his thats why its cut off
    seeing if my cuts were good enough and how much i need to bump stop for the 35s
    clearly need to cut the back out and add 1 more inch of bump stop
  17. #92 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    next to a jk with 3.5" lift and 35s
    painted the front some
  18. #93 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    and i never learn my lesson lost a spring messing around at cpo chaos had to lift me up so i can put it in
  19. #94 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    then went to pick and pull got a door to replace the one of the 2 fucked up ones and got cross rails and a 04 grill that took some cutting to make fit on my header panel
  20. #95 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    photo next to the jeep that has my old springs
    then decided to start cutting the front up for the next few projects
  21. #96 Re: Killallblues 2002 wj
    Looks nice and clean. Good work! Anything so far that you'd do differently?
  22. #97 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    yeah i wouldnt have bought the rc 4" kit lol and i would have never bought the 35" mud grapples not a fan at all of them hopefully they build should get better i just bought a daily so i can actually work on it and not work about having to work Monday
  23. #98 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    local guy stopped by so i could look at his and figure out a few things we are going to do to it sp i took some pics
  24. #99 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    part for my winter project slowly buying shiz for the build
  25. #100 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    i picked up a winch plate for 30 of cl the plan is to weld it into the old bumper mounts
    how the mounts were
    i set the plate there just so i can see in my head
    took off the harpoons flipped them up and slide the plate in i still need to clean them up so i can slide that plate back all the way but kinda get the idea how it will be
