Killallblues 2002 wj - Page 5
Thread: Killallblues 2002 wj
Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 161
  1. #101 Re: Killallblues 2002 wj
    Member killallblue's Avatar
    Jan 2013
    baltimore
    busted out the band saw to clean up the crap
    got it sitting back alot further still need to tweak the harpoons and square off the ends
  2. #102 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    so i got a winch for fitment still have tweaking to do and that strap was barely holding it up while i made sure it had clearance will all be level when it gets welded up. what do you guys think open to ideas
  3. #103 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    no real updates got a new ds finally the right yoke new rear a arm bushings in
  4. #104 Re: Killallblues 2002 wj
    Jan 2015
    az
    If you haven't finished the bumper yet i would look into recessing it into the front sheet metal and trimming the grill. A little more work for a better approach angle.
    93zj build. 4.0 aw4, 231, 60s, and 37s. Some cutting and some welding.
  5. #105 Re: Killallblues 2002 wj
    Jun 2013
    oroville
    X2 with what bentwrench said. I did mine first as close as I could get without recessing it and hated it after about a month. Even with 42s I would hit it on steep climbs.
  6. #106 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    haven't done it yet its on my weld list along with rockers now because of this lol
  7. #107 Re: Killallblues 2002 wj
    Aug 2009
    knoxville, TN
    How did you manage to do that?
  8. #108 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    headlights cut out i pulled over onto the shoulder turns out was a sink hole that front bar is the only thing that stopped me from a full roll over
  9. #109 Re: Killallblues 2002 wj
    Jun 2013
    oroville
    Whoa! That's some bad luck. That's kinda cool you didn't go all the way over. Did anything get broken on your rig?
  10. #110 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    smashed rocker bent drag link and now the jeep is siting a inch lower on that corner and everything looks fine so i need to barrow a spring and see it that got messed up
  11. #111 Re: Killallblues 2002 wj
    That sucks! Swap them side to side.
  12. #112 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    was just thinking that after i posted that ill do it tomorrow and see if thats it ill order some new iro springs
  13. #113 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    did some small stuff and took a trip
    new tweets i used the factory speaker as a bracket
    pile of parts
    rebuilt all my joints
    thinking about getting metal mesh and running like this
    new yoke and ds
  14. #114 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    photos from the small trip
  15. #115 Re: Killallblues 2002 wj
    What all ended up being bent from your little trip into the ditch besides the drag link? Did you end up screwing up a spring? I hit a rock pretty hard snow wheeling a long time ago and bent the axle side lower control arm mount on one side, took a bit to find it. Your Jeep looks like it's sitting right now, that's why I ask.
  16. #116 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    o i forgot to update on that so that front upper joint on the body got blown out and bent the snap rings and the side out so i bent it back for now waiting on johnny joints to swap them all out
  17. #117 Re: Killallblues 2002 wj
    Makes sense. Thanks for letting us know what happened!
  18. #118 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    some new temp tires for winter till next summer
    buddy lifted his 6" now so us 3 years ago and last week
    got some of the winch plate project done
  19. #119 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    tires on
    had to fix a control arm mount before the snow
    let there be snow
    day 2 of snow
    decided to go out
  20. #120 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    decided to redo my switch wiring and add a plug
    picked these up off amazon needed something for night driving on back roads
  21. #121 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    ok so i have a question i have a chance to get a set of wagoner dana 44s axles for almost nothing think it would be worth my time im never going bigger then 37s for the way i want to set my ring up
  22. #122 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    well a set of wagoneer dana 44s have been given to me for free so i think thats what will be going under the jeep
  23. #123 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    found a Columbia edition wj at the pick and pull i stripped it
  24. #124 Re: Killallblues 2002 wj
    Jan 2013
    baltimore
    so i re did my tank tuck yesterday went 2" higher and made room for a hitch
  25. #125 Re: Killallblues 2002 wj
    Nice!
