wj 242 input shaft
Thread: wj 242 input shaft
Results 1 to 6 of 6
  1. #1 wj 242 input shaft
    Member Lifetime Supporter wannabe_offroad's Avatar
    Jan 2006
    Next door to - The land of corruption
    On my 02 WJ, I'm looking at swapping out the 242 (behind a 545rfe) for a 241or. I haven't been able to find the exposed length of the 242's input shaft to see if the input shaft on the 241or will match-up with my transmission. According to the following post, the input shaft can't be swapped out on a tj 241or, but can on a jk 241or. http://www.jeepforum.com/forum/f310/...31/index3.html
    I've also sent some emails back and forth with a company that sells input shafts and they could only tell me the 242 has 4 possible input shaft lengths (I already knew that from their website) and that they don't make input shafts for the 241or. I really don't want to take my tcase off before I'm ready to put on the clayton's and order a new rear DS. Anybody know the 242's exposed input shaft length? How about the tj and jk 241or's? Thanks
  2. #2 Re: wj 242 input shaft
    Dec 2011
    Ohio
    Ill measure my mine tomorrow for you. Can I ask why you want a 241? Or do you mean 241OR?
    01 Laredo 4" claytons, 33x12.5-15 MTR K's, ARB/M8000, 231hd, lockright
  3. #3 Re: wj 242 input shaft
    Jan 2006
    I appreciate it. I'd like to ditch my stock 242 for the rubicon case (241or).
  4. #4 Re: wj 242 input shaft
    Mar 2007
    -----Rocklin, Ca ----- USAF RETIRED 462X0
    Quote Originally Posted by wannabe_offroad View Post
    You are looking for the input shaft lenght for a 242HD that sit behind the V8 right and not I6. If it is the 242HD you wont have any problem selling it to someone swapping out a 247.
    The V8 242HD is 2 7/16.
    01 Grand, 6in lift, 33's, Aussie locked 30/35, front disco's, home made rock rails, Surco rack, grille guard, front and rear hitch, t-max 12500lb hitch winch, rock lights, TJ transfer skid plate, OBA and a few other things.
  5. #5 Re: wj 242 input shaft
    Jan 2015
    United States
    Still struggling with this concept can i purchase new a correct WJ V8 type input shaft for the 242HD that comes in other vehicles like Durango to make it a bolt in? If yes where? I don't mean used junkyard parts
  6. #6 Re: wj 242 input shaft
    Mar 2007
    Dont know where you can get them.
    242ld(I6) input shaft pn is 5003 446AA
    242hh(V8) input shaft pn is 8350 3507
