any recommendations for a rear truss?
Thread: any recommendations for a rear truss?
Results 1 to 16 of 16
  1. #1 any recommendations for a rear truss?
    Sac
    need something a little beefier, ripped both sides off
  2. #2 Re: any recommendations for a rear truss?
    Jan 2010
    SLC UT
    Pm agitatedpancake
  3. #3 Re: any recommendations for a rear truss?
    How the hell did you do that Danny??
  4. #4 Re: any recommendations for a rear truss?
    Looks like a bad design and insufficient material to compensate. What pumpkin is that? Chevy/ aftermarket 60?
    Look around on pirate. Here's a good place to start: http://www.pirate4x4.com/forum/gener...e-trusses.html
    RuffStuff has a good off-the-shelf piece. Dan also supports the board and offers a Mallcrawlin discount.
    Unfortunately, that's a familiar sight. Is that truss Clayton's?
    As already Indy already said you need to improve the design. Tie it into the diff if you can.
  6. #6 Re: any recommendations for a rear truss?
    Clayton's trusses are now square tubing. But even when they were round tubing, the upper control arm mounts were in front, not on top, of the truss. On my 8.8, the truss was tied into the diff and gusseted on both sides. I'm doing something similar with my rear truss, but since I'm running air shocks, I'll be adding tubing to span the axle.
  7. #7 Re: any recommendations for a rear truss?
    SLC, Utah
    Agree x10, I will try to get some pictures of my truss setup this week, but this is what I run http://www.rockkrawler.com/images/RK00533LJ_03.jpg
    97 with stuff....
  8. #8 Re: any recommendations for a rear truss?
    Jun 2006
    Cedar Rapids Ia
    Pretty much anything completely boxed and 3/16" or better seems to work. Like IndyZJ said pirate has quite a bit
  9. #9 Re: any recommendations for a rear truss?
    Pull the diff out. Pull the tube straight and weld it up. Add more material in the for of gussets.
    If you don't want a bandaid fix. Cut it all off and build something nice. A truss doesn't need to be fancy. Just strong. Even a thick walled tube can tear. The front truss on my axle tore through a 0.188 wall 1.75" tube well gussetted.
    Just do me a favour and don't buy the artec stuff. For some reason I find them ugly as sin.
  10. #10 Re: any recommendations for a rear truss?
    Sac
    well i think slick rock trail weakened it, and the final kill was playing around on some rocks. but over all just too many years of abuse. when we go wheelin!?
    dana 60
    yep its claytons
    I needed a quick fix to get back on the trail so I had it re-enforced and added some gussets behind the rear control arms where they were cracking. I'll go snap some pictures real quick and post em up
  11. #11 Re: any recommendations for a rear truss?
    Sac
    just sanded down, rewelded, and re enforced the back. If this still cracks down the road i'll make a proper one. just got back from the snow so everythings got a little coat of rust on it already. Forgot the topic of the cracking uni body and rear control arm mounts was on a different thread so i'll post pics of the gussets there. http://mallcrawlin.com/forum/showthr...37s-holding-up
  12. #12 Re: any recommendations for a rear truss?
    I'd do a complete redesign of the truss sooner than later. I doubt those gussets will do enough toward fixing your problem and it's not worth losing a wheeling trip over or destroying those coil overs, driveshaft, etc. You need significantly more weld area and torsional rigidity throughout the truss/ link tower. Even something simple and cheap like some 2x3 1/4" wall rectangular tubing with a couple miter cuts would be a huge improvement from what you've got now and wouldn't cost more than $50 in materials.
    How much vertical separation is there with your raised LCA mounts?
  13. #13 Re: any recommendations for a rear truss?
    Sac
    what do you think Indy? sorry for the big ass pics keep forgetting to resize
  14. #14 Re: any recommendations for a rear truss?
    I would still tie it into the top of the diff. That significantly will reduce the "twisting" forces seen on the axle tube where the truss ripped off previously. It doesn't take that much metal to do it either.
  15. #15 Re: any recommendations for a rear truss?
    it looks like it is tied into the top of the dif.
    But those gussets wont hold up for long. That truss is WAAAY to small. I woudl cut it off and do a redesign. Shoulnd't be much work and will result in a much better perice of equipment and over all peice of mind knowing that you dont' have a time bomb in the rear.
  16. #16 Re: any recommendations for a rear truss?
    Feb 2013
    phoenix
    artec industries!
