Thread: ALERT: Check Trailer Hitches - Prior to potential accident / Law Suit etc
Results 1 to 2 of 2
  1. #1 ALERT: Check Trailer Hitches - Prior to potential accident / Law Suit etc
    Oct 2012
    United States
    Highly suggest ALL Jeep Owners regardless of Model or Year
    ADD following to your current preventative Maintenance of Vehicle.
    1. Inspect Total Trailer hitch assembly - Get up under Jeep take a look see
    2. With torque wrench Check all Bolts per Manufacturer Specifications
    REASON:
    a. While replacing Driver side Outer Wheel bearing
    b. Required to remove Diff Cover, remove C clip etc ...
    c. Noticed the inner side of Trailer Hitch
    d. NOTE: Would not have noticed from an outside inspection
    e. PDF digital Photo attached
    f. Don't want to think of the many negative things to occur if not Found
    -Hitch assembly comes apart while towing
    -Causing accident
    -Law Suits
    -And so forth
    Hope this helps all who may view this Post in the way it was intended
    Great day to all
    John from Colfax NC
    PS: After considerable due diligence research
    -Ordered New Hitch assembly
    -Draw-Tite Max-Frame = Model # 75041
    Please Conduct research for Hitch compatible for your Jeep year & Model
    Also suggest for a little more dollars purchase the Highest Class rating Hitch
    You never know what you may be towing so be prepared in advance with Highest quality hitch rating for your personal safety & general public
    HELP please - How do I upload Qty 1 PDF Digital Photo ??
  2. #2 Re: ALERT: Check Trailer Hitches - Prior to potential accident / Law Suit etc
    Oct 2012
    United States
    Correction 1
    -Seeking guidance from Members or Administrator / WebMaster
    HOW to upload Qty 1 JPEG digital Photo ??
    Great weekend to all who may view this Thread / Post
