Thread: Yukon Hardcore D60 35 Spline Locking Hub Installation
Results 1 to 16 of 16
  1. #1 Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Ok, for those that maybe interested in upgrading your worn lock outs with something else than the Warn's or the beloved broached spicers, or your like me and looking into going back to a dual purpose rig. The new Yukons may be the ticket for you. Here is a little write up with some pics to show off this new product.
Size:  56.3 KBName:  Box.bmp
    This is the box and the part #. For my application I needed this for a '88 HPD60 out of a F350, now in a '02 WJ Grand Cherokee.
    I forgot to mention this also as a selling point for me. The hubs revert to the locked position if broken. This is key if your like me and have broken a hub before and had to 3 wheel out of a bad situation that broke the hub to start with.
    I'm still waiting on the inexpensive shit to break!!!
    '02 WJ with 60's, locked, full hydo, ORI's, on 40's, and still have air conditioning!
  2. #2 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Here is what you get in the box. These hubs are not cheap, but the quality seems to be top notch.
    Name:  What you get.bmp
Size:  56.3 KBName:  What you get 2.bmp
  3. #3 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Ok. First thing first. I pulled the Yukon drive flanges out and cleaned the hub to make sure there is nothing in there that should not be.
    Name:  Yukon drive flange.bmp
Size:  56.3 KBName:  Clean hub.bmp
  4. #4 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Grease is your friend. Grease everything! The last thing you want is a failure because you ran a hub dry. Just don't do it. Pack and lube everything in this install.
Size:  56.3 KBName:  Grease hub.bmp
  5. #5 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Next you grease and install the spacer. You will see a theme here. Like I said, everything gets greased.
    Name:  Greased spacer.bmp
Size:  56.3 KBName:  Spacer install.bmp
  6. #6 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Next we'll install the spring.
Size:  56.3 KBName:  Spring install.bmp
  7. #7 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Next is the coupler and the driver. This can get a little tricky, and you may have to do some wiggling to get both the hub splines, the stub splines, and the coupler/Driver splines all lined up. Grease these.
    Name:  Greasy lock gear.bmp
Size:  56.3 KBName:  Lock gear and lock.bmp
  8. #8 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    You have to get this all lined up, push them up against the spring, and get the small snap ring on the stub shaft. You may need to use a tool like I did to keep the stub from slipping back. I just used a lug wrench from a truck (don't ask what it came off of), but I'm sure a big screw driver would work fine. Make sure that the snap ring seats properly.
Size:  56.3 KBName:  tool.bmp
  9. #9 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Next we are going to install the cam spacer into the retainer. Allign the ears and put it into the hub. More grease.
    Name:  lock and keeper.bmp
Size:  56.3 KBName:  installed greasy lock.bmp
  10. #10 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Next we'll install the hub snap ring to hold the whole thing together.
    Name:  bad ass snap ring.bmp
Size:  56.3 KBName:  snap ring install.bmp
  11. #11 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Check to make sure nothing is binding by pushing on the retainer. It should slide fairly easy with a little pressure. If it hangs up, you did something wrong. I packed the hub with some more grease, and flipped the dial over to fill the ports with grease also. Install the driver dial with the supplied allen bolts and torque to 22lbs. DON'T OVER TORQUE!!! I used blue Loctite on the bolts. The instructions do not tell you to do this, but I use Loctite on every fastener I can. If you use permenant (Red) Loctite on them, well, you're an idiot. You still need to be able to get these off one day. You've been warned.
    Name:  blue loctite.bmp
  12. #12 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Sep 2006
    Cleveland, MS
    Now let's make sure that the hub locks and unlocks properly. Twist the dial 1/4 turn to lock and back 1/4 turn to unlock. Everything should be smooth. If it's binding, don't force it! Remove your driver and look to see what you put together wrong.
    That's it! You should be ready to go!
    In closing. These hubs have to be the best quality locking hubs I have ever put in an axle to date. Everything fits well, the parts are beef. Yukon claims that these are very close to the strength of thier drive flanges. Being that is what I took out of this axle, only time will tell. These hubs are not cheap as I stated at the start of this review, but quality rarely comes with a reduced price tag.
    I hope I helped someone understand a little more about the installation of these lock outs, and even if you never purchase or own a set, you'll have a little more knowledge in your hat.
    Thanks for reading, or at least looking at the pictures.
  13. #13 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Looks good, Jim!
    I have to ask, though. What advantage do these offer over broached Spicers? A warranty and parts availability?
    Sep 2006
    Cleveland, MS
    The broached spicer hubs are a great option as for the strength. I feel that these will hold there own with any lock out that comes down the road, ever. The availability is what made my decision. I wanted something "off the shelf", and actually designed to be that way. We, as gear heads never leave anything alone. It was nice to have an "out of the box, bolt on". The spicers are a tried and true design and I'm sure they will be used for many years to come, but it was nice to actually follow the instructions and not have to void a warranty, modify 20 year old parts, to get something to work on my rig. Haha.
    Sep 2006
    Cleveland, MS
    These have a striking resemblance to the another hub manufacturer.
    http://www.dynatrac.com/products/parts/DynaLoc.html
    Sent from my iPhone
  16. #16 Re: Yukon Hardcore D60 35 Spline Locking Hub Installation
    Jul 2007
    Utah
    I have these on my trail Jeep and have been very happy with them for the past couple years
