Thread: Winch Issues
Results 1 to 13 of 13
  1. #1 Winch Issues
    Santa Fe, NM
    I finally got around to installing my winch (Engo E9000s) but I'm having some issues getting things to work right. Hoping someone may have some advice before I contact Engo.
    I hooked up everything per the instructions provided. With the Jeep running at idle if I press in on the controller it kills my Jeep. Revving it to 3k barely keeps it running and the winch barely spools rope in. Initially I thought maybe my battery couldn't support the load, but after it dies it fires right back up like nothing happened. The other oddity is that the positive cable running from the winch to the battery gets really hot. Like hot enough to melt the insulation. I'm out of ideas and a bit frustrated. Anyone think of anything obvious I'm overlooking? Alternator is a brand new 130A unit also.
    Sent from my DROID BIONIC using Tapatalk 2
  2. #2 Re: Winch Issues
    Dec 2011
    Ohio
    Sounds like something is shorted.
    Me and a friend of mine installed one on his xj, and it was pretty straight forward. Match the color wire to the color post, hook up battery cables, and your done. I would just get a hold of engo, or whoever your bought it from, so you can get another one coming.
  3. #3 Re: Winch Issues
    Santa Fe, NM
    I just sent a PM to the place I ordered it. Will update when I hear back.
  4. #4 Re: Winch Issues
    Jan 2010
    SLC UT
    That's odd I've had no issues out of mine so far
  5. #5 Re: Winch Issues
    Santa Fe, NM
    I'm going to call Engo in a few minutes. Hope they are of some assistance.
  6. #6 Re: Winch Issues
    Sounds almost like all of the current isn't making it into the cables somehow.
  7. #7 Re: Winch Issues
    Santa Fe, NM
    Well I'm a fucking idiot (no surprise there). I talked to Joel @ Engo, turns out I've got the negative/ground from the battery on the wrong post on the winch.
  8. #8 Re: Winch Issues
    Jan 2010
    SLC UT
    Ah well I hope nothing was damaged with the mix up.
  9. #9 Re: Winch Issues
    Santa Fe, NM
    Joel @ Engo said it should be ok. I'm going to switch it tonight and see what happens. I reread the directions and it does clearly state that the battery cable runs to that post, I must've skimmed over them (I did read them )
    Santa Fe, NM
    Switched it. Good to go
  11. #11 Re: Winch Issues
    Jan 2010
    SLC UT
    Good to hear I love mine man I've already used it a few times and it's been great.
  12. #12 Re: Winch Issues
    Dec 2006
    You put tab A into slot B. Hate it when that happens
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  13. #13 Re: Winch Issues
    Santa Fe, NM
    Quote Originally Posted by fpkites View Post
    lol Jim, just saw this comment. You have no idea how fawking frustrating it is (or maybe you do) when you've read the directions wrong 4-5 times through
