Help identifying locker
Thread: Help identifying locker
Results 1 to 11 of 11
  1. #1 Help identifying locker
    Nov 2011
    Glendale, AZ
    Anyone know what brand locker this is? I got it used and need to order springs for it. Its out of a HP30.
    Thanks.
  2. #2 Re: Help identifying locker
    Jan 2010
    Colorado Springs, CO
    Looks like a lock-right. Images look similar
    http://completeoffroad.com/i-122969-...r-pt-2210.html
    The Steel City ZJ: Murdered Out with Steelers, Steelers, and more Steelers
    www.militaryjeepers.com
    97 ZJ 4.0, 5.5", Clayton's, Serious Off Road Products 1 Ton Steering, 242, 35" MT/R's with Kevlar
  3. #3 Re: Help identifying locker
    SLC, Utah
    My common sense is telling me there is likely a number etched in it that you can google.
    96 4.0 ZJ, 4.5in RE coils with Teraflex arms, Yukon gears, ARB front bumper, 33x12.50 M/TR's, homemade OBA setup....
    97 with stuff....
    Nov 2011
    Glendale, AZ
    You would think. Each part does have a part number engraved but I get nothing in google. It uses smaller springs inside the main springs to hold them in instead of pins and there are four smaller springs on each side of the cross pin (12 springs total) if that helps anyone identify it.
  5. #5 Re: Help identifying locker
    Looks like a Lock-rite. Take note of the notching of the cam gears in the exploded diagram here:
    http://eastcoastgearsupply.com/i-128...line-open.html
    Aussies don't have that square hole 90 degrees opposite the crosspin plus the holes for the pins are a bit too large. Same could be said for the spartan (based on the pics I've seen).
    Nov 2011
    Glendale, AZ
    I think your right. That diagram is the only one I've seen with the square hole and the holes in the cross pin cutout.
    Nov 2011
    Glendale, AZ
    Actually now I'm thinking it is a powertrax but a no-slip not a lock-rite
    Nov 2011
    Glendale, AZ
    http://www.jegs.com/i/Powertrax/754/...oductId=744476
    Only one I've found with 12 springs and no pins.
  9. #9 Re: Help identifying locker
    Member dyn0mitemat's Avatar
    Jun 2011
    ↑↑ This side up ↑↑
    I can confirm it is NOT a spartan. Spartans have tiny holes next to each pin to let you push a roll pin through to hold them in while installing
    98 ZJ - Build hd44/88, 35s, long armed, locked, blah blah blah...
    Build thread
  10. #10 Re: Help identifying locker
    Aug 2006
    Asheville, NC
    Quote Originally Posted by Sbrach View Post
    ^This. A lock-rite only has 8 springs (4 large & 4 small that fit inside of each other). The No-slip is supposed to have better manners on-road than a traditional lock-rite. Usually the no-slips are about 2x's the price of a LR too.
    2000 WJ - Stroked, Locked & Long Armed
    2006 XK 2" RC & 31" AT's
    Nov 2011
    Glendale, AZ
    Well I picked up a kit for a no slip and it was correct. Got it installed this week and I can't tell it's there. I'll see how it works this weekend on the trails.
