GSW Damage report
Thread: GSW Damage report
Page 1 of 3 123 LastLast
Results 1 to 25 of 64
  1. #1 GSW Damage report
    Post up what broke.
    I didn't fair too bad; despite running with the big boys on rusty nail and pritchet (dragged through).
    I cracked a weld on my front bumper, destroyed the axle-side track bar bushing and bent the belly skid (pushed up 2"). The latter is saying something since it is 1/4" steel plate backed up by 1-1/2" tube. I also have a new vibration on the highway which could be anything froma drive shaft to a missing wheel weight.
  2. #2 Re: GSW Damage report
    SL,UT
    You did damn well on Rusty Nail too! I was impressed to say the least. You should've had that obstacle with all the boulders.
    My damage report isn't bad, I just need to build a new rear driveshaft since I tagged this one pretty good. Then replace the front axle end driveshaft u-joint...the joint has a shattered cap. I think that's about it, or at least all I know of...
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  3. #3 Re: GSW Damage report
    Boulder, CO
    Some tack welds on my exhaust hanger broke (combination of not wanting to weld next to my gas tank and exhaust hitting a rock). I call that a good trip
    -Ryan
  4. #4 Re: GSW Damage report
    I made it out unscathed!
  5. #5 Re: GSW Damage report
    Boulder, CO
    Quote Originally Posted by K2 View Post
    LIES!
    -Ryan
  6. #6 Re: GSW Damage report
    Bent my unibody by hitting a ledge too hard. Made the ledge, but now I need to straighten the body.
    Behind Clayton's LCA mount (rear passenger side), the unibody is pushed up. The rear passenger LCA threaded rod is also bent, the square tubing part of the arm is straight. The passenger "C" pillar has two crinkles and the passenger "B" pillar has a little crinkle and "bows" out.
    Both passenger side doors do not line up when closed. The driver's side passenger door does not line up either. Before Bryant did a little door bending for me, you had to open the rear passenger door before the front passenger door could be opened. The doors overlapped. I should have taken a pic, the gaps were pretty big.
    I need to take it to a frame straightening place and see what they can do. Then build a stiffer sub frame with integral rock sliders. Maybe add a cage for more stiffness.
    After running Rose Garden Hill yesterday and driving home, a very loud clicking that shakes the Jeep developed as I drove through Vail. (Why does my WJ always break in Vail?) It only clicks under deceleration, so I left foot braked to keep a load on the driveline to make it home. Hopefully it's only a front hub.
  7. #7 Re: GSW Damage report
    Boulder, CO
    I bet it is a u-joint John...mine always do that coming back from Moab with that dusting getting into all of the joints.
    -Ryan
  8. #8 Re: GSW Damage report
    Sep 2008
    Mesa, Arizona
    Pulled the passenger side front brake line off the mount going up Moab Rim. It's interesting having no brakes when there's a cliff to your left and behind you.
    Only damage my ZJ suffered was the lens cover on the turn signal coming loose while sitting on the trailer on the way out. Pam did a number on her ankle though coming back from Mill Creek. Between me, Putz, and Brewer though we were able to carry her out when it was too hard to limp it. Looks much better today though.
  10. #10 Re: GSW Damage report
    SL,UT
    Saw the pic! Just a bad sprain?
  11. #11 Re: GSW Damage report
    Need a new transmission mount and Avatar photo.
  12. #12 Re: GSW Damage report
    SL,UT
    Build a tranny mount...? I'm running a poly mount that I built and it's still holding up great.
    As for the Avatar, have Dave make you one. He's the creator of mine I believe....that or for some reason he has this photo saved onto his computer or searched for it......which worries me a lot more.
  13. #13 Re: GSW Damage report
    MallCrawlin Supporter
    Kauzi Zj's Avatar
    Apr 2009
    Developed a "dead spot" in my steering, and a nasty vibration, probably a u-joint...other than that, a sunburn...had an awesome weekend as usual!
  14. #14 Re: GSW Damage report
    Member Grand Slam West Planner dads5.9's Avatar
    Jun 2006
    Broomfield, CO
    Totally destroyed ANOTHER Currie High Pinion ring and pinion.
    Slow drive back to Denver from the trail rebuilt rear driveshaft from spare parts.
    '98 5.9L, Clayton LA on 35s
  15. #15 Re: GSW Damage report
    4 JEEPIN Lifetime Supporter
    Santa Clarita, CA
    Absolutely nothing broke this year!
    Sandy Reshes
    05 Rubicon
  16. #16 Re: GSW Damage report
    jsteves's Avatar
    Fort Fun
    Quote Originally Posted by dads5.9 View Post
    What did we learn? Currie sucks.
  17. #17 Re: GSW Damage report
    Steering is off a little after PSM from what I can tell, but I don't know where I would have done it on PSM. Probably happened on Moab Rim and I just noticed it on PSM. Overall nothing broken that I can tell and even running at 75+ on I70 there weren't any shakes or vibrations, I should say new ones as I needed to get the tires balanced before GSW anyway.
    I bet u-joint on yours John as I ran into a similar thing when I had a truck w/a bad u-joint. Glad you made it home mostly OK though. Sorry we couldn't trail straighten your WJ on Rose Garden Hill.
    '04 Honda Civic - my DD
  18. #18 Re: GSW Damage report
    Is your axle trussed? I almost wonder if the housing is deflecting. 1 R&P failure is one thing, but having another one fail leads me to believe that something else might be causing it. One of my friends has been running a Currie Hi9 in his rear for years on 36" SXs and a healthy V8 -- to my knowledge he never broke a R&P.
  19. #19 Re: GSW Damage report
    Boulder, CO
    Brian (ZJones) ran Moab Rim and ripped out his brake line from the caliper. Luckily Chad (I think) had a spare and Bryant held his finger on the bleeder.
    Of course Ken's (K2) drive shaft snafu:
    -Ryan
  20. #20 Re: GSW Damage report
    jsteves's Avatar
    Fort Fun
    It is trussed with a Clayton's old style square tube truss. I am somewhat concerned the housing is bent.
  21. #21 Re: GSW Damage report
    The problem with a Clayton's truss is that it's not a complete truss -- so the tubes can just bend where the truss ends. I also know for a fact that the tubes can be bent on an axle with a Clayton's truss in Moab -- just ask Rockfather.
  22. #22 Re: GSW Damage report
    Dec 2006
    Scratched the axle side of my front left Clayton LCA. Beating my head against the wall for not getting the skids welded on to the 1/4" axle bracket
    Clicky front left axle shaft, but it's a junkyard special, so I'm sure the ujoint is dry as a bone. Smooth as butter coming home though, the trailer absorbs all vibrations from the Jeep's driveline
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  23. #23 Re: GSW Damage report
    Boulder, CO
    Moab Rim video (in HD if you click on it and change the resolution settings) - contains the recovery of Chads flop.
    -Ryan
  24. #24 Re: GSW Damage report
    Member Shinobi's Avatar
    Oct 2008
    Reno, NV
    Broke two things nothing to crazy tho .. my hydro assist fitting and my hydro assist bolt....
    RIP 2004 WJ - 3.5' lift , JKS Disconnect and 33's
    NO! Shinobi's Jeep up side down on the news
    2001 WJ - 6" Clayton , 35's BFG AT KOs , and buch of stuff
    Insurance Settlement Build
  25. #25 Re: GSW Damage report
    Jan 2008
    Basalt, CO
    Power steering line and rear locker went out.
    Brian
