Thread: GSW Damage report
Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
  1. #51 Re: GSW Damage report
    Chipped a few teeth. Hard to see in crappy cell phone pic, but it's on the coast side, which would jive with my symptoms. At least it's better then the T-case.
  2. #52 Re: GSW Damage report
    Senor Member Lifetime Supporter ArloGuthroJeep's Avatar
    Boulder, CO
    See if you had the 4.0 you would never need the coast side of the gears 4.0 FTW
    -Ryan
    '04 WJ w/6" on Clayton LA's, 242 SYE, 4.56 (locked 44a), 35" BFG MT KM2's
  3. #53 Re: GSW Damage report
    Quote Originally Posted by ArloGuthroJeep View Post
    QFT!
    Also front or rear?
  4. #54 Re: GSW Damage report
    Ryan, that's a good one.
    Rear with less then 3K miles on them.
  5. #55 Re: GSW Damage report
    The "chipped" teeth are smooth and right by the cross pin. After checking with a gear shop, this is most likely a little sanding to clear the cross pin in the carrier. I will look closer tonight. Guess it's time to crack open the T-case. At least I'm getting a lot of wrench time in.
  6. #56 Re: GSW Damage report
    I ground down the teeth on my ring gear a little bit right there too.
  7. #57 Re: GSW Damage report
    John, if you need help let me know.
  8. #58 Re: GSW Damage report
    Thanks! I'm running out of things to check that rotate, but at least I'm getting all the fluids changed. LOL
  9. #59 Re: GSW Damage report
    It's running. The range selector fork was all chewed up, a la GSW 2010. The T-case was full metal shavings, including the oil pump.
    Not sure of the root case. The range selector fork that was put in at GSW 2010, might not have been out of a 231 or the oil pump might have died causing the failure at GSW 2010 or the oil pump died later after the repair at GSW 2010 or I'm destined to replace 231 parts when attending GSW....who knows.
    I now have a new range selector fork (231 for sure), a new oil pump and new little bushings on both shift forks. Everything is squeeky clean and running smooth.
    If it goes again, I'm swapping in another T-case, one with twin sticks. I guess that will be June of 2012, which gives me a year to save up. Now it's off to a frame straightening shop.
  10. #60 Re: GSW Damage report
    Salt Lake City
    Quote Originally Posted by JohnBoulderCO View Post
    Resident hater of tall lifts, dana 44's, 4.0's, stingers, exo cages, and ZJ tow rigs....and the word "overlanding"
  11. #61 Re: GSW Damage report
    Jan 2008
    Basalt, CO
    John, we should go do 21 road in it before you get the frame straightened.
    Brian
    99 WJ - 6" lift w/ Claytons, 231, 4.56, 44 Front, Locked 44a, Custom bumpers, 35 KM2s, Spyderlocks
  12. #62 Re: GSW Damage report
    Adjusted the doors today. Looks decent. I scoped out putting in some "mega" rail stiffeners and talked to a local guy about putting in a cage, but I'm going to hold that off until the winter. It's almost August and I don't want to loose the wheeling season.
  13. #63 Re: GSW Damage report
    I was driving the Jeep around this weekend, making sure everything is working, when my swing out tire carrier let go. The "hub" where the carrier pivots sheared off. Looking at the break, it's a long term fatique failure. Luckly the latch held and the carrier didn't take out the rear glass or eject off the back. I need to come up with a better concept or just put the tire back inside.
    If it's not one thing, It's another!
  14. #64 Re: GSW Damage report
    Boulder, CO
    I knew a guy who used a D30 hub and an outer shaft to pivot on...could give that a shot.
    -Ryan
