I need to find a system to mount my RTT onto the ZJ, the Thule gutter mounts obviously wont work from my XJ.
The issue i see is needing a minumum of three crossbars (i have four) under a wider 1.8 Overland RTT and the curverture of the ZJ's roof. The center crossbar/s would sit taller if i swapped in new feet to attach to the ZJ luggage rack rails?
Anyone aware of an adjustable height foot that would allow me a flat surface?
Any other bolt on options? TIA..
I used to have a thule rack mounted on a ZJ of mine, and the Thule feet definitely stuck up there. I haven't looked around lately for other options, but if that is what you use to put a tent up there, that baby is going to be top heavy.
My Mombasa RTT only uses 2 cross rails. I would think removing the majority of the original roof rack assembly and fabricating a new one to meet your specs would be the best bet. Everything down to the rails.
I was hoping to find out there was an adjustable height foot/tower that slid into the original rails. Only thing i found available is the TrekkerII which wont work.
The idea was to source something quick for upcoming Memorial Day weekend as i wont have time for any fab work any time soon.
I'm sure you guys have seen it, tksmith did a mounting system for his rack that was steel strap bolted to the original nutserts and "legs" cut to length to level it. I think eventually i'll do something similar with a few more mounting points.
Dave, my Overland is wide (Queen).. i need more support under the center.
