Thread: 2011 GSW To-Do-List
Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 140
  1. #51 Re: 2011 GSW To-Do-List
    Agree, down turns suck or blow. I run straight pipe from the CAT to the back. That made it jsut as quite as running a FM muffer that I just kept banging on the rocks.
  2. #52 Re: 2011 GSW To-Do-List
    SL,UT
    I already have one on there, and a couple weekends ago I built my own exhaust out the back. I have replaced a constant loud noise (turndown after muffler) with a quieter ride, except when between 1900-2500 RPM's and anytime I accelerate, I have this higher pitched noise that kills me. I have added insulation (Jegs branded Dynomat) along the path of my exhaust (helped) - but it is still an annoying noise. I want to make my Jeep tolerable to drive - not set off car alarms when I start it up. </rant>
    You need a resonator up towards the cab of the vehicle. Do you have a cat on your setup still?
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  3. #53 Re: 2011 GSW To-Do-List
    Boulder, CO
    Three of them. Two pre-cats at the manifold and one cat (resonator) around the TC, a Hushpower II muffler behind that, and exits out the rear.
    -Ryan
  4. #54 Re: 2011 GSW To-Do-List
    SL,UT
    What size tubing are you using now?
  5. #55 Re: 2011 GSW To-Do-List
    Boulder, CO
    2.5" throughout.
    -Ryan
  6. #56 Re: 2011 GSW To-Do-List
    SL,UT
    And you're still getting a lot of resonance inside the cab? Hmmm....I'd say the only thing you may want to add is a resonator after the muffler then, but that usually just quiets down the tone outside the cab, the closer you put one to the engine, the more it helps with inside resonance/drone.
    So it's just 2.5" all the way from the y-pipe back? I believe stock is 2.25" right? Does it step back down to 2.25" anywhere after a 2.5" section?
  7. #57 Re: 2011 GSW To-Do-List
    Boulder, CO
    Stock is 2.5" to the cat, then 2.25" from there back. My setup is 2.5" the whole length. I used to run 2.5" with a FM70 and it sounded great. That muffler is ~8 times bigger than the Hushpower II muffler though so it doesn't fit with Claytons
    -Ryan
  8. #58 Re: 2011 GSW To-Do-List
    Yep, no room for a big muffler with Clayton's and the little muffler I tried really didn't do anything except get hit on the rocks.
    I like the sound of my V8.
  9. #59 Re: 2011 GSW To-Do-List
    SL,UT
    Yeah, a resonator would probably help a lot of your resonance since the Hushpower doesn't have near as much packing in it as the 70 did.
  10. #60 Re: 2011 GSW To-Do-List
    Dec 2006
    With this conversation, I'm starting to think I should just have a shop run pipe from the cat to the back of the rig. I really need to make a decision since I'm running just the cat right now. We cut off the muffler back for the Claytons. It's loud, but not nearly as bad as I suspected it would be.
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  11. #61 Re: 2011 GSW To-Do-List
    Boulder, CO
    For me it isn't bad 4-wheeling, it is bad on a 6 hour drive to Moab, or driving around town. If you have a DD & a trailer I wouldn't mind running a turn down.
    -Ryan
  12. #62 Re: 2011 GSW To-Do-List
    Dec 2006
    I'd like the exhaust going out the back - gets the gases away from the back seat where my most precious cargo sits....Tricia if she's not in the front seat, and Bridget if Tricia is up there.
    That, and if I have to do a dyno smog test again, I don't have to bring dryer hose
    Jim Karlin
    GSW 2010 Pics
  13. #63 Re: 2011 GSW To-Do-List
    Run it out the back. Makes a huge difference in the sound level compared to a turn down and yep, points the gases in the correct direction.
    I'm running out of things to do. Wait, still a few items on the list.
  14. #64 Re: 2011 GSW To-Do-List
    Member Lifetime Supporter Mochisme's Avatar
    Seattle, Washingotn
    Well now that I have a reservation at the Moab Rim RV Campark (made this morning), the only thing left is to load the camper with food, clean the KOH dust/sand out of the air filter on the jeep so I can start a new collection of Red Utah Dust and head down the road.
    Ted
    2000 WJ Stock, Towed behind the Motor Home
    2000 Monaco La Palma 34' Class A Motorhome
  15. #65 Re: 2011 GSW To-Do-List
    Moab Red Dust is > any other dust. Except maybe Peruvian sand dune dust, but I have never been there, just pictures in motorcycle mags.
    '04 Honda Civic - my DD
  16. #66 Re: 2011 GSW To-Do-List
    MallCrawlin Supporter
    Kauzi Zj's Avatar
    Apr 2009
    Well my Jeep now has the IRO OTK steering and KOR front tow points installed....which was quite cool since Im in North Dakota, and my Jeep is in Colorado...hehe, it also got an alignment. Whis really only leaves a little work on the fron bumper, and my AC condenser installed (both of which might happen before I get home), then basic maint/service...
    Side Note! Anyone still needing a room at Redstone?
  17. #67 Re: 2011 GSW To-Do-List
    Fruita, CO
    got a good list of things to do on the jeep (which is cool that I can do them this year!) as following:
    build 8.8 and get it in
    install new lca's
    get the tires on the correct rims (this just shows how much I have been wheeling) XdoneX
    full service on fluids (grease oil etc,,.)
    trans filter and fluid change XdoneX
    locate a freaking trailer!!!
    service tow rig brakes.
    and maybe more that I can't think of...
  18. #68 Re: 2011 GSW To-Do-List
    Kauzi Zj's Avatar
    Apr 2009
    install new lca's
    When I get back we can get together, and wok on some of this stuff, i need to do a lot of the same...I "might" be able to help with the trailer...I'll have to check...
  19. #69 Re: 2011 GSW To-Do-List
    SL,UT
    Well....I got the Jeep mostly ready. Heading to Moab this weekend for Memorial with the family. We'll see if that brings any more changes that need to be made if I make it to GSW.
  20. #70 Re: 2011 GSW To-Do-List
    Dec 2006
    Claytons are done, just have to pipe the exhaust out the back.
    BPEs installed - thanks for the great deal last year Ken (K2). When I dropped the 30 to put brackets on, I forgot to put bumpstops back in - they're in there now.
    Adjusting the front trackbar turned into quite the ordeal - ended up having to use penetrating oil and heat to get it to adjust. Now it's got a shit-ton of anti-seize
    Passenger slider got some flap disk love and some paint. I'll do the driver side this week. Both sides have some pretty good cancer. I'll have to drop them both this winter and clean them up, maybe even send them to a sandblaster.
    Just need to make another fluid check, then it'll be on the trailer June 6th or 7th.
    I'm thinking real hard about getting limiting straps for the rear. Not too keen on using my shocks as limiters. Especially since I was able to squeeze my front coils out to put in the hockey pucks without disconnecting the shocks.
    I do need to figure out why my front discos were such a whore to get off the post. Front trackbar might be a little bit on the long side.
    Jim Karlin
    GSW 2010 Pics
  21. #71 Re: 2011 GSW To-Do-List
    Jan 2008
    Basalt, CO
    Only took a year to get Claytons in, Jim.
    Brian
  22. #72 Re: 2011 GSW To-Do-List
    Dec 2006
    A year and a month...almost exactly
    Jim Karlin
    GSW 2010 Pics
  23. #73 Re: 2011 GSW To-Do-List
    New thermostat is in and seems to be working good. Cleaned a shit load of crap out of the fins of the a/c condencer, radiator, and from between the trans cooler and a/c condenser. Much better now!
    Last edited by PassRunnerZJ; 05-22-2011 at 11:36 PM. Reason: Frisking iPhone predictive spelling and can't touch correctly
  24. #74 Re: 2011 GSW To-Do-List
    ABS pump is out and new brake lines are in. I also put a longer serpentine belt on so the adjustment pulley doesn't hit the steering box. I removed the rear track bar bracket (body side) so it doesn't hit my exhaust!
    Next weekend is 4 front arms and new springs front and rear. Probably some spacers for the front wheels. Hopefully I can get the rear shocks relocated too.
  25. #75 Re: 2011 GSW To-Do-List
    Member theksmith's Avatar
    Sep 2007
    Phoenix, AZ
    mine with the FM 50 Delta-flow and turndown sets of car alarms sometimes, but it doesn't drone on the freeway IMO - the FM 50 Delta just barely fits in there with claytons
