Thread: 98 Isuzu Rodeo 3.2 bad knock
Results 1 to 8 of 8
  1. #1 98 Isuzu Rodeo 3.2 bad knock
    Warwick Rhode Island
    Hey all picked up a Rodeo for couple hundred and has a really bad knock. It's there from the time you start it and gets louder as you the rpm's go up. No smoke, runs smooth, besides the knock and dont overheat.
    Truck is a 98 rodeo 4x4 with 3.2 149,000 miles Anybody know these things and possible cause. I haven't taken it apart yet cause I just got it. I have been cruising a few Isuzu forums but it's like ju. 200 bad answers to every right.
    Im a complete newb with imports but hope to make this a decent around town ride. Even if I have to drop in a rebuilt engine I wont be in the hole much and the body and interior is in great shape.
  2. #2 Re: 98 Isuzu Rodeo 3.2 bad knock
    Not that this is useful info but my wife used to have a honda passport (same as the rodeo). Her 3.2 had terrible valve tick. We used to add 1/2 quart of mystery oil and it helped to keep the noise down a bit.
    Drop the oil pan and check the rod bearings for slop.
  3. #3 Re: 98 Isuzu Rodeo 3.2 bad knock
    Staunton, VA
    I wouldnt do anything till it blows
    Especially if nothing is leaking
    Drive it around town, when she pops rebuild it or better yet have an engine in the shop ready to go in when it dies
  4. #4 Re: 98 Isuzu Rodeo 3.2 bad knock
    I dont want to melt down the block but thanks. It's not just a tick. Good friend said i should replace the hydrolic lifters. (He is the man when it comes Imports) So i hope he is right.
    But if anybody else knows anything I would gladly take your .02
  5. #5 Re: 98 Isuzu Rodeo 3.2 bad knock
    Staunton, VA
    I know what your saying but if its a bad knock from the block area, it could be a number of things, many of which would cause needing a new block or dropping a lot of coin to sleeve it
    Lifters tick, rods knock and bang, if its lacking power it could be a broken ring, or pistion
    If you are trying to stay cheap locate a junkyard engine and hopefully you can hear it run before you buy it. Thats probably about the cheapest way to go
  6. #6 Re: 98 Isuzu Rodeo 3.2 bad knock
    Have you done a compression test? It sounds like a rod bearing from your description, but it's hard to diagnose over the internet.
    x2 on finding another used engine to drop in. Hear it run or get it from a yard that takes returns. That is usually cheaper than a rebuild.
  7. #7 Re: 98 Isuzu Rodeo 3.2 bad knock
    Well dont mater now I blew it up. Started it up and was reving it a bit to help find where the banging was coming from and it stopped cold in its tracks. I'm going to tear it down this weekend and see what it was.
  8. #8 Re: 98 Isuzu Rodeo 3.2 bad knock
    Junior Member ubtrippin's Avatar
    Aug 2010
    fredericton new brunswick canada
    ill bet a dollar to a donut its a rod bearing letting go
