wj Knuckle clarification
Thread: wj Knuckle clarification
Results 1 to 21 of 21
  1. #1 wj Knuckle clarification
    Senior Member 93ZeeJ's Avatar
    Oct 2007
    Littleton
    ok so i was pretty confident that i had my setup just right for when i install it all but after reading a thread or 2 on pirate about it.. im unsure
    heres what im going to be using for brakes on my WJ knuckles swap
    sport trac rotors
    akebono calipers
    wj knuckles
    jks tie rod and drag link
    yada yada rest doesnt matter
    the question i have is... with the sport trac rotors.. do i still need to space out the caliper? i have heard yes and seen pictures that show that i do.. but i have also heard that with the sport trac rotors the calipers do not need spaced
    which is it?
    i was under the impression it needed to be spaced still
    where did you guys source your longer bolts from?
    also i know there is a way to do this without using spacers...is that by getting different hubs? which hubs is it that make it so you dotn need caliper spacers
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
    HP30-truetrac/D44a-Aussie 4.56
    6.5" Long Arms, 35"s
  2. #2 Re: wj Knuckle clarification
    I don't know what rotor Andy was using, but he had the hub spacer and little 1/4" spacers for the calipers. That much spacing for the caliper isn't really thaaaat big of a deal
  3. #3 Re: wj Knuckle clarification
    IIRC the 01? xj/tj knucks have different spacing since they switched to composite rotors. There is a thread or two on here about it. One of them even specs the standoff heights for the different bearings. Alberslondh and I were discussing it.
    2004 Ford Lightning
  4. #4 Re: wj Knuckle clarification
    jsteves's Avatar
    Fort Fun
    Yes, you still need the spacer.
  5. #5 Re: wj Knuckle clarification
    Aug 2008
    NH
    [Potentially stupid question] Did you assemble everything yet? Seems to me this would be the best indicator of whether or not you need a spacer. Shouldn't take more than a few minutes to slap it together, even if the knuckles aren't mounted yet. [/Pontenitally stupid question]
    Think Twice Garage
  6. #6 Re: wj Knuckle clarification
    Good point. If you have all the stuff put it together and let us know. I have yet to start gathering my parts.
    2004 Ford Lightning
  7. #7 Re: wj Knuckle clarification
    jsteves's Avatar
    Fort Fun
    My old man used the sport trac rotors...you still need the spacer.
  8. #8 Re: wj Knuckle clarification
    I got a nice set of the mesh style 17" WJ wheels today for $50 I wonder if I can use the WJ knucks rotors and bearings. I know they use XJ stubs for the WJ u jointed shafts?? Then I just have to swap my rear spacers on the 8.8
    2004 Ford Lightning
  9. #9 Re: wj Knuckle clarification
    Oct 2007
    Littleton
    i would piece it all togethor but the axle assembly and hubs are elsewhere right now
    hubs are on the jeep ( going to reuse old ones )
    and the new HP30 housing thats going to replace the current HP30 housing is getting its truss and inner c gussets and stuff done to it right now... once i have all of that done i can get started
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  10. #10 Re: wj Knuckle clarification
    Oct 2007
    Littleton
    OK ... so ive read multiple places that 99-06 TJ/XJ hubs eliminate the need for the caliper spacers
    timken part number HA597449
    found them for 142.00 shipped on rockauto.com
    anyone know if these hubs still require some machining for the sport trac rotors to fit over them? or do they eliminate that step as well?
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  11. #11 Re: wj Knuckle clarification
    Aug 2011
    Sweden
    I've done WJ knuckle swap on my rig, very nice mod actually.
    Here's parts you need.
    Akebono calipers 4802 casting number, make sure caliper brackets are included. WJ caliper bolts M12 x 1.25 pitch grade 10.9
    WJ rotors, you will have to redrill them. Other rotors will require caliper spacing. Use an old hub to mark drill holes
    JKS flange spacers
    If you go OTK, use GoFerit inserts to flip your tie rod and drag link
    TJ 2001-2006 hubs part number 5016458AA
    These hubs together with WJ rotors will eliminate the need to space out the caliper
    Here's the difference, TJ's to the left.
    ZJ '93 5.2 9.5"LA, 8.8 rear, D30 HP trussed, RCV orange dome shafts, ARB f&r, 37" Iroks, hydroassist, IRO stuff, WJ Knuckle mod, OBA(ac), more to come
    WJ '01 4.7 untouched (yet)
    http://www.diman.se/gallery/albums/u...0001/zj-wj.jpg
  12. #12 Re: wj Knuckle clarification
    Senior Member Jim311's Avatar
    Gainesville, FL
    Yabut, then you need to buy new unit bearings $$$
    Is it really that big of a deal to put in a few washers to space it out? Not to me, cuz that's what I did.
  13. #13 Re: wj Knuckle clarification
    Houston, TX
    I still have not done my swap yet, as Im' waiting for it to cool down some from being 100+ everyday. but I also am going the route of using the newer unit bearings. but before I purchased them I mocked up the longer/bolt spacer method and never really liked spacing the brakes like that. I know tons of others have done it and I don't know of anyone that has had an issue, and the additional leverage may not be much but I was not comfortable with it. anyways I needed new bearings anyway and got new ones off of Amazon of all places for less than half what Vatozone wanted for the SAME Timkens.
    and I like to make things difficult to I'm going to try and get ABS to still work on it=) I have a few ideas but I need some front sensors for mockup first.
  14. #14 Re: wj Knuckle clarification
    Oct 2007
    Littleton
    what was the timken part number for the hubs that you got?
    was it HA597449 ??
    also has anyone tried the newer TJ hubs with the sport trac rotors? do they fit without shaving the hubs a little?
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  15. #15 Re: wj Knuckle clarification
    Houston, TX
    yes those are the ones=) I'm using redrilled WJ rotors. I used a wheel adapter that converts 5x5 to 5x4.5 and bolted that to the WJ rotor and then used that as a drilling template. it worked PERFECTLY to get exactly centered 5x4.5 bolt holes.
  16. #16 Re: wj Knuckle clarification
    Oct 2007
    Littleton
    how willing would you be to mail me that adapter so i can redrill mine? ill pay shipping to Colorado
    ive called a few shops and they all say not to redrill rotors cause it is unsafe.... opinions?
    edit nvmd i found a few places
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  17. #17 Re: wj Knuckle clarification
    Houston, TX
    I used ones like these:
    http://www.ebay.com/itm/4pc-5-Lug-4-...item3cb04c9ef1
    I bolted these to the WJ rotor so things are NICE and TIGHT, then used the 5x4.5" holes as drill guides for my drill press. BAM perfectly centered holes. If you want to borrow the adapter hit me up a pm
    Oct 2007
    Littleton
    Does anyone know if the 06 TJ hubs have the same size or smaller diameter flange? I'm curious if those newer hubs eliminates the need to grind a little off the edge of the flange if using the sport trac rotors
    Sent from my SGH-T989 using Tapatalk
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  19. #19 Re: wj Knuckle clarification
    Nov 2011
    Dayton, Ohio
    okay first post here. I have and XJ and jst bought a 97 ZJ that all my stuff is moving too. I have all the stuff for a WJ swap, but need to know if anyone here with the ZJ's has upgraded to the WJ M/C and booster or is the ZJ M/C and booster up to the task of the Twin piston calipers and a Ford 8.8 Rear end?? Thanks, John
    Oct 2007
    Littleton
    Solution found! !!!!!!!
    Iron rock offroad now sells cross drilled and slotted WJ rotors that are dual drilled! They have 5 x 5.5 AND 5 x 4.5 bolt pattern. 139.99 for the pair! Gonna return my rotors to advance auto and buy these instead
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  21. #21 Re: wj Knuckle clarification
    SLC, Utah
    Any updates on this? I need more braking power for the 35's and am curious if you ever got this finished.
    97 with stuff....
