Thread: Which Bedliner?
Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
  1. #26 Re: Which Bedliner?
    Member blackjack12982's Avatar
    Apr 2009
    Wichita, KS
    Yes, it's very thick in the passenger footwells and rear cargo area. I had 2 gallons, and realized it was way too much. The drivers feet area and the cargo area had 4 coats, versus 3 coats in the other footwells, versus 2 under the seats/side areas.
    I don't have any pics of the Rhinoliner, but comparing the thickness of it to the thickness that I applied in my ZJ doesn't compare at all. The Rhinoliner was installed at the dealership immediately after purchase. The exposed factory paint area looked to have no prep on it at all for the Rhinoliner. I would have to imagine that had a large factor in the easy scratching, but there still is hardly any thickness at all in the Rhinolining.
    Edit- Rereading your post again, there was absolutely no way that the Rhinolining was 1/8-1/4 thick at all.
  2. #27 Re: Which Bedliner?
    Mar 2007
    Dealer screw up, then. I think the average installed thickness for a regular coating of Rhino is around 1/8".
    ~Franklin D. Roosevelt
  3. #28 Re: Which Bedliner?
    Apr 2009
    Wichita, KS
    Quote Originally Posted by JordanA View Post
    Yeah, that's what we thought too. I wonder how many people get that kind of shoddy bedlining?
  4. #29 Re: Which Bedliner?
    Member FleshEater's Avatar
    Mar 2011
    Harrisville PA
    I actually contacted Monstaliner with a few questions/concerns. How did the Monstaliner hold the heat down in the cab? I've come to the conclusion that if the heat becomes a factor with my Herculiner job I'll be sanding it a bit and applying Monstaliner on top of it.
    Shove it.
  5. #30 Re: Which Bedliner?
    Mar 2007
    What did Monstaliner have to say?
  6. #31 Re: Which Bedliner?
    Apr 2009
    Wichita, KS
    Quote Originally Posted by FleshEater View Post
    It never even occured to me before I read this thread about the risk in increasing the heat inside the cab, and I was pretty worried about it as I installed it. It was mid 70's yesterday, and I drove down the interstate for a little over an hour. I was able to place my hand on the tranny tunnel, and could tell it was warmer than with the carpet, but it wasn't nearly as bad as others have said their bedliners were. By no means would it scald your legs if you touched it. I'll definitely keep an eye on it as it gets hotter outside.
  7. #32 Re: Which Bedliner?
    Mar 2007
    my first DIY liner, duplicolor I believe, would literally allow the heat from the tranny tunnel to burn your leg.
  8. #33 Re: Which Bedliner?
    Apr 2009
    Wichita, KS
    Yeah, like I said, I saw this thread right before I applied it, and it's one of the reasons that I applied it so thick/so many coats over the tranny tunnel. I'm definitely glad I did, there's no way I would live with burning my legs everytime I drove anywhere.
  9. #34 Re: Which Bedliner?
    Mar 2011
    Harrisville PA
    Monstaliner said (if my memory serves me right) that they weren't sure how it would reduce the heat but said that the Lizard Skin wouldn't be the best thing to apply before applying a bed coating. However, they did say that if my Herculiner doesn't do it for me I can sand a little of it and apply the Monstaliner on top.
    Personally...I think this is a try and see what happens situation. There are not enough ZJ, WJ, XJ write ups to support a solid 100% conclusion. So I'm going to apply the Herculiner as best as I can and see how the heat is. If it's bad I'll apply Monstaliner if it's not bad I'll leave it be. Had I heard about Monstaliner before Herc I would have bought the Monsta.
    I'll log on to MC through my place of employment and post the e-mail they sent me back. He said it was a good question and was going into the FAQ.
    Shove it.
  10. #35 Re: Which Bedliner?
    I think my raptor liner made a significant difference in the interior heat but honestly I think the thickness makes a difference when sprayed inside the pass compartment more than the media. Now if you sprayed the undercarriage reflective properties come into play at that point.
    2004 Ford Lightning
  11. #36 Re: Which Bedliner?
    I just bought a roll of that reflective insulation you can get from any hardware store and cut it to fit around the transmission tunnel. That worked wonders at keeping the heat down -- although it's not exactly the most eye-pleasing solution. Although you could probably figure out a way to cover it without it looking purely functional.
  12. #37 Re: Which Bedliner?
    Mar 2007
    No offense, but I would take what Monstaliner had to say about using competitor's products with a grain of salt. That's like asking a Chevy dealer to tell you why NOT to buy a Ford.
  13. #38 Re: Which Bedliner?
    Mar 2011
    Harrisville PA
    Here you go to better/further explain and understand what was conversed. My original question concerned heat and sound...
    Hi
    Heat and sound dampening are mainly conquered with film thickness. Anything you put between the heat or noise source will do something to reduce them but the thicker you go the more effective it becomes.
    Lizard skin probably does better by itself than any DIY bedliner. Part of the reason it may be better for sound is that it's recommended to be applied thicker than most DIY bed liners. It's also quite expensive for the coverage recommended. I've played with Lizardskin. It's almost like peanut butter in consistency. Basically a latex paint with a lot of filler. The filler is a light weight, hollow ceramic particle and because it's basically filled with air it may be better in dissipating heat/sound but I still think it's more a function of thicker is better
    Raptor will be no different than any other DIY liner as it is thin and has no special fillers or ceramic.
    Monstaliner has a solid ceramic filler more for durability and abrasion resistance and because it's designed to go on thicker than other DIY products it will do better for sound dampening. It does shield some heat and withstands heat very well.
    Herculiner in reality, is a very thin coating that appears thicker than it really is because the rubber particles are much larger than the thickness of the coating and they stand way above the coating surface when it's dry.
    I would use the Herc you already have and consider adding additional coats of something when you see/hear the results.
    Today was your lucky day as I don't usually write this much but it was a great question that I'm using for an updated FAQ
    I hope this helped.
    Regards
    Eric
    Eric Rosenthal
    President & Technical Director
    631.842.7700 - Ext 100
    Cell: 516.313.7865
    www.magnetpaints.com
    www.monstaliner.com
    More detail about Lizard Skin:
    A few have asked if Lizardskin could be installed first and I think yes. The problem with doing that is the Lizard stuff stays relatively soft and pliable for quite some time (months) before it really hardens well and if you put a bedliner over that on a walkable surface it may dent and is kind of unpredictable regarding long term durability.
    I don't think Liz Skin was designed to be walkable by itself as it's usually used under carpet or on the back of body panels and in concealed areas. People use it as alternate to Dynomat
    Shove it.
  14. #39 Re: Which Bedliner?
    May 2008
    Chesterfield, MI
    Just for FYI .
    There are drain plugs in the front pans of a ZJ.
    They are oval in shape and glued in.
    You can use the same replacement rubber plug for a TJ rear passenger drain whole.
    The ZJ rear seat pans have 2 plugs each.
    I have a thread on this somewhere on this site.
    I got the plugs off ebay for 2 each. Drains fine
  15. #40 Re: Which Bedliner?
    Apr 2009
    Wichita, KS
    Quote Originally Posted by JINX View Post
    Just for FYI .
    Wow, I wish I would've known that before I coated them over. I looked and didn't see any that were blatantly obvious. I was gonna source a set of marine plugs.
    Robert
    94 ZJ 5.5" and 35" KM2's...
    47 CJ2A
  16. #41 Re: Which Bedliner?
    Mar 2007
    Quote Originally Posted by blackjack12982 View Post
    I believe they're beneath the glue/insulation crap that comes from the factory. Unless you removed that prior to coating, you'd never have seen them.
  17. #42 Re: Which Bedliner?
    Apr 2009
    Wichita, KS
    I removed the carpet/insulation underneath it. I also removed the foam that was on the firewall in the footwells, however, I didn't remove the glued on body color painted "whatever". I've read the horror stories of trying to remove that gummy mess.
    Robert
    47 CJ2A
  18. #43 Re: Which Bedliner?
    Mar 2007
    Yeah I didn't bother with it, either.
  19. #44 Re: Which Bedliner?
    May 2008
    Chesterfield, MI
    The oval shape plugs are almost right in the middle of each section of floor pan. They are glued down but a heat gun and a small sturdy scraper pulls them right up with no problem.
    They have clips on either end that you have to bend in. But nothing difficult.
    Here is the link to the replacement ones. They fit right in. Very cheap compared to the dealer $8.00 version.
    http://cgi.ebay.com/ebaymotors/Swap-...Q5fAccessories
  20. #45 Re: Which Bedliner?
    Mar 2011
    Harrisville PA
    Has anyone removed the insulation glued or welded (no idea what this stuff is) to the floor of their ZJ or WJ? I'm not sure if the XJ and TJ guys have this stuff but I know the WJ does. It's all over the bare metal floor in squares with a bubbly top...I believe I read it's a "tar" like material.
    Just trying to figure out whether or not it's worth trying to tear out or just leave it and deal with it.
    Also, when you guys were rolling the bed liner on how did you plug the bolt holes? The instructions suggest shoving tape down in there but I'm not to sure of using that method...I was thinking of just leaving the bolts in their holes and taping around them in a square.
    Also decided to buy another Herculiner kit and install both...I'll let you know how it holds the heat/road noise out.
    Shove it.
  21. #46 Re: Which Bedliner?
    Mar 2007
    1. Yes... it's been covered more than a few times on here.
    2. tape works great for the bolt holes, don't over-complicate this.
    Search, and you shall find.
  22. #47 Re: Which Bedliner?
    Mar 2011
    Harrisville PA
    Sorry...found it after a couple searches.
    After reading I don't think it's worth the effort to remove it and it's a foam sealer to stop moisture from creeping through the floor welds so in PA it's probably a good idea to leave it.
    Shove it.
