Biggoofy's 96 ZJ build! ** HP44 and 9" swap ** - Page 7
Thread: Biggoofy's 96 ZJ build! ** HP44 and 9" swap **
Page 7 of 36 FirstFirst 1234567891011121314151617 ... LastLast
Results 151 to 175 of 885
  1. #151 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    I will be getting a new pilot and throw out bearing maybe a new clutch depending on the shape of the one I pull as for the master and slave Ill be using pulled parts unless I cant find them or they are damaged. Im trying to do this as low buck as I can since Im still trying to get the 35s on here rather soon along with the new axles.
  2. #152 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2009
    Lufkin, TX
    just do yourself a flavor and get a new clutch.
    No longer a JeepTech01 fan.
    Just boobs.
    And biggoofy.
  3. #153 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    I figured you'd balance it somewhere along those lines, and I'd probably do it the same way. Bearings definately take top priority for being new, the hydraulics are semi easily replaceable even once assembled, and the clutch you should be able to visually inspect so that should work out.
    You got a plan, can't wait to see it happen!
  4. #154 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    Yeah I figure it should work out pretty well man. I'm stoked for sure I really hope this weekend works out if not I have to wait till I get paid and go next weekend which still isnt to bad. Does anyone know if the XJ 242 and the ZJ 242 have different spline counts? I dont want to pull a t case unless I need to.
  5. #155 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    I know early XJ's used a 21 spline, but I'm not sure if you could get 242's with those or only 231's. With the AX15 I'd assume it's going to be 23 spline but I don't know about input shaft length!
  6. #156 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    I have to pull from a 94+ so I guess Ill find out lol Its not like its that hard for me to pull an XJ 242 or 231.
  7. #157 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    The death on a 42RE
  8. #158 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Ha! thats not that deep LOL. I swamped my WJ like that the first time I wheeled it when I broke a cv.
    Although mine was fine after I got pulled out
    2004 Ford Lightning
  9. #159 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    So today I finally had enough of the wet carpet so I cut it all out but what is covering the trans tunnel to try and keep the noise down. I'll be rhino lining the area with out carpet as soon as im sure everything is dried up.
  10. #160 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Beaumont, Texas
    Just trash all the carpet man. Sooner or later the heater core will leak then then the a/c drain and so on and so forth. Muddy feet and spilled beer also hurt my carpets life span.
  11. #161 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    Ill take a pic tomorrow man Its 90% gone now. Ill probably pull it all out when I swap the trans.
  12. #162 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Raptor liner ftw. I have some pics in my WJ thread. Cheap and spray on.
    2004 Ford Lightning
  13. #163 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    Ill have to look it up man. I have been hearing good things about that stuff.
  14. #164 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Member Wwildman's Avatar
    Oct 2010
    NC
    That doesn't look like it is that deep but you need more ground clearance.
    As for wet carpet I would have pulled it and let it dry then pressure washed it clean . it is a bit easier in yours then mine with the cage inside
    Warren You might be a redneck if you actually know what kind of leaves make the best substitute for toilet paper
  15. #165 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    Carpets overrated!
  16. #166 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    I figured I would post up my rear parts, fluid, and tool storage solution.
  17. #167 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Austin, TX
    The solution was to advertise Amsoil?
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  18. #168 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    LOL Well I do love the stuff but I need more stickers for it. Mainly trying to make it look like I didn't get it from work haha.
  19. #169 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Feb 2010
    Springfield MO
    How do you keep your rear hatch open? I dont see any vice grips! Haha.
  20. #170 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    The glass struts are shot but these somehow still work haha.
  21. #171 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Beaumont, Texas
    My struts still hod unless its cold outside, then it falls on my head and pisses me off.
  22. #172 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    So I got a package in the mail today from FCZJ and I cant wait to get everything painted up and installed tomorrow. The Rad support is BEEFY as hell and very well made to say the least. The steering brace looks fawking sweet and the welds are killer!! Thanks for the great product Neil!
  23. #173 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Beaumont, Texas
    Those look well built to say the least. I need to get a steering brace on mine before it is too late. This isn't going to be one of those threads that gets rollin good then falls dead is it??
  24. #174 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Jan 2010
    SLC UT
    HELL NO!!! I am still waiting on my 35s to ship out so my current focus is finding an AX15 or a used 42re if the swap proves to be more trouble than its worth but im 95% sure it will be a AX15 that winds up swapped in. Then I will shift my focus back to the long arms and axles getting thrown in. I still need to gear the 8.8 and HP30 with my ECGS 4.88s that I got from Chase on cyber monday for a great price!
  25. #175 Re: Biggoofy's 96 ZJ build AX15 swap in progress!
    Nov 2008
    the desert
    Those are not KOR products correct? Similar design of course jus makin sure you didn't buy them third party. Are there any more available or can another steering brace be made to order? Price?
    93 ZJ 5.2.headersCAImoparPCMmsd,boredTB,efan, custom ugly bumper,KOR tb radsup,242, 5.5 lift Claytons LAs front adj SA's rear, d44 aussie locked, danaturdy w lockright, 35s
    Bloody box addict
