How has the currie upper front joint holding up with that setup?? I have been thinking I will go with that setup once these bushings die.
Got the ZJ washer bottle installed and updated my rear tire carrier to hold the bigger tire and my high lift.
Washer pics, bumper pics to come later.
added some lights to the roof, 1" square tubing and four pilot 55w lights
I wonder what the GVWR of that WJ is.. Maybe we should ask Tyler.
Seriously though that thing has got be getting pig ass heavy at this point. IIRC curb weight of a WJ is like 4400lbs. What kind of mileage are you getting?
Watchin the build. At first I thought the rear bumper was overkill and a little awkward BUT with the bigger tires and lift, it seems much more "at home" now. Great job!!! Keep it up
yeah maybe or possibly rotate it 90 degrees and put them in front of the bar.
not sure the weight, probably 600 or 700 pounds heavier, the box in the rear is only there when I go wheeling. I carry the factory spare on the bumper when not wheeling as well so that saves a few on the road. Gas mileage I am calculating, it was about 15 before I did a new fuel filter and that seems to have raised it some, thinking maybe 17 now if I keep my foot out of it.
Thanks I always thought the scale of the rear bumper matched well with the front ARB bumper. The 35s really make it look different. Now time to get it on the ramp and do some trimming so I can wheel it again, just have to find the time to do it.
So any updated wheelin pics? Did you decide to swap the lights over to under?
Have not had time to get it out and wheel. Still need to do some trimming. I am thinking of tieing the front and rear bumpers to the sliders with Dom that follows the fender clines to serve as rub rails for on the trail. May eventually lead to a full exo. Who knows?
Have not moved the lights. There is not enough space underneath. Couldove to the front but I think it will increase glare off the roof and hood.
built some tube fender protectors and widened the sliders.
bunch of pics of it finished
happy with how they came out hopefully will save soe fender damage in the future
just added a speedo correction to my WJ
Here is a great writeup on it.
http://www.offroadpassport.com/forum...&postcount=415
works great, my speedo is exact to my gps now, 14.8% off with the 35's
cool write up. has been on my mind lately cause i have been doing a lot of driving with my gps and always checking how fast im 'actually' going
Did a little trail clean up at Uwharrie today for the monthly work day. Picture of the crew and some shots on the poser rock.
cool poser pics. I like the tube work you did around the fenders. You got extra points for making it a bolted flange on the bumpers incase you need to remove the bumper!! Nice work
So it decided to add a receiver to my ARB front bumper
Cool Idea on the front hitch, makes that one long nosed bitch. Like the aux lights in the corners. You weld in some tubes behind the cuts? Any close up pix?
Well I went and made a big hole in my jeep. God it is empty, any chance of changing my mind?
Left over parts
Followed WJCHRIS' thread on Jeepforum.com so not going to redo the build instructions
Here is the porn, look at that pretty diff
What do you all think, my axle was hitting the tank after I stretched the wheelbase a little so I had to do it.
Left over parts
Had my knuckles rotated and my spring pads flattened out on my front axle. Added 4.5" IRO springs and Bilstein shocks, 5100s on the front and 5125s on the rear.
