GSSE Checklist - Page 3
Thread: GSSE Checklist
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 82
  1. #51 Re: GSSE Checklist
    Warwick Rhode Island
    Quote Originally Posted by MUDDTRACKS View Post
    Don't have alot to do here.
    Replace inner and outer driver front axle shaft.
    replace lockright in the front. FIXED
    replace a rear control arm joint. FIXED
    Install my aw4 manual shifter(fried my old one so built this one from scratch)FIXED
    then just go over everything seeing it has been sitting in the yard since Feb.
    Found a few more things
    head lights and rock lights dont work
    warn gold manual locking hub came out in 15 peaces
    psc power steering pump is dead(sent it to psc to rebuild)
    For the most part just waiting on parts to come in the mail. Hope they get here in time.
    Also modfied my Milwaukee Jobsite radio to work in the rig so i have toons.
  2. #52 Re: GSSE Checklist
    Senior Member bnboffroad's Avatar
    Mar 2007
    linville
    Getting RED AKA my cummins fixed this wensday
    transplanting second 6.0 in dolly this friday it makes the 6th motor shes had lol
    Ray Charles gofast Tjuggy tons atlas 40" creepys,BLACKMAMBA 3500 Suburban 8.1 tow monster
  3. #53 Re: GSSE Checklist
    Got through a local rockcrawling event this weekend with the typical scratches underneath. I won't be wheeling anymore until GSSE, so just looking to check over the rig and trailer to make sure everything is actually in order.
    Waiting on some of the spectators to upload some video from the event.
  4. #54 Re: GSSE Checklist
    Got my rear upper link mounts rebuilt this weekend... they took forever and a day to make but they're now par with the rest of the rig... slightly less ghetto
  5. #55 Re: GSSE Checklist
    maryland
    -rear tube fenders
    -throttle body
    -leaking rear diff
    -pack jeep
  6. #56 Re: GSSE Checklist
    May 2005
    Boone NC
    my checklist..
    build wills rig- done all i can do there, the rest is up to him... (and cam)
    build cobbies rig- dropping 6.0 in after work friday
    for my rig
    wire up brake, tail and headlights - done
    install thermostatic relay for my efan.. (apparently im not smart enought to turn on my fan every time i start the rig...) done..
    replace creek water in my cooling system with antifreeze and clean water..done
    install bypass hose for my now non-existant heater core...done
    replace broken front center limit strap - gotta send the strap i bought back
    making some progress now
  7. #57 Re: GSSE Checklist
    maryland
    -rear tube fenders
    -throttle body (running strong now)
    -leaking rear diff
    -pack jeep
  8. #58 Re: GSSE Checklist
    All i need is axle shaft and my power steering pump and i should be set.
    plus two stock size tires so i can fit the jeep on a trailer im about 3 inches 2 wide.
  9. #59 Re: GSSE Checklist
    Member S-10 Seanzy's Avatar
    Aug 2006
    Bristol, TN
    That's what a BFH is for...clearance that bitch!
  10. #60 Re: GSSE Checklist
    Quote Originally Posted by S-10 Seanzy View Post
    I would just cut the damn things off but not my trailer.
    I will get there one way or another.
  11. #61 Re: GSSE Checklist
    maryland
    welcome to my world. i have to swap tires everytime I load the thing on the trailer.
  12. #62 Re: GSSE Checklist
    Mechanicsville VA
    Thats alot of work! it sounds like its time to do a few changes to the trailer so the Jeep will fit
  13. #63 Re: GSSE Checklist
    Quote Originally Posted by slim616 View Post
    I guess I know what I'll be helping you with when you roll in on Thursday
  14. #64 Re: GSSE Checklist
    Jul 2008
    North Carolina
    Got to grease my front u-joints and re-charge the AC then I am good to go... good thing since we are leaving in three days haha
  15. #65 Re: GSSE Checklist
    yesterday we got the full hydro cylinder mounted and tie rods made, arms drilled, front axle and steering protection bent up and welded in, driveshafts made, lower spring perches welded, and the front rad hoop bent and welded in. if he can mount the orbital and get a radiator and his fan in today, he'll be in decent shape.
  16. #66 Re: GSSE Checklist
    May 2005
    Boone NC
    you guys got alot done in a day, must have been a long one...
    where those super high steer arms a PITA?
    He said something about bending his frame when he dropped the rig without springs?
  17. #67 Re: GSSE Checklist
    actually wasn't that bad, just HOT. started at 1, worked mostly at a casual pace and I finished up around 11. High steer arms were OK, had to space the tie rod heim down a little for him to have any uptravel at all, but that is how mine is also... bent frame sounds like classic will exaggeration
  18. #68 Re: GSSE Checklist
    May 2005
    Boone NC
    yea it was hot as fawk up here so i can only imagine what it was like down there in hell..
    glad you went over and helped.. i have this mental picture of a fish out of water when will starts to actually build anything
  19. #69 Re: GSSE Checklist
    Orlando, FL
    No more working on anything in the summer around here unless I have to. It was blazing yesterday.
    www.grandslamsoutheast.com
    My Build Thread
  20. #70 Re: GSSE Checklist
    May 2005
    Boone NC
    Quote Originally Posted by Pearce View Post
    thats funny cause i usually have to postpone projects during the coldest winter months up here because its too damn cold in the garage.. i imagine its much worse for the guys up north and out west..
  21. #71 Re: GSSE Checklist
    Haha. It's only been in the 80s up here (for like 20 straight days -- which is I think a Buffalo record) and it's too hot for my northern butt to do anything.
    I think 10-15 degrees is about my limit for working on the Jeep in the winter, though. The worst part about the cold is usually the wind, so even a non-heated garage isn't too bad if you keep moving around. You can always put on more layers in the cold
  22. #72 Re: GSSE Checklist
    OK got the reverse lights and turn signals working. Couldn't get the brake or tail lights to work though -- the two most important ones. I looked at the FSM and I mis-read the schematic and wrote down the wrong color for the brake lights -- so that should be easy to fix.
    Note to self: Look at which connectors I cut out since Jeep conveniently changes wiring color from one side of the connector to the other.
    It looks like I fuckered up the taillight wiring somehow because I can't find the feed from the light switch on the dash in running to the rear quarter. There is at least an ignition-on power feed I can directly wire the tail lights into as a quick fix to so that I at least have rear lights -- per Evarts requirements from what I read.
    The magnets I got for mounting the rock lights also weren't as strong as I was hoping, so I don't think I'll have any rock lights if we do a night run.
  23. #73 Re: GSSE Checklist
    Mar 2009
    Western NY
    Jared, The wire for the taillights may be there, but you can't find it with a test light because the fuse may be blown. Check that.
  24. #74 Re: GSSE Checklist
    May 2005
    Boone NC
    you can use mine to locate the tail light wire if you need to... I tapped into that wire after i removed my dash and all the factory headlight and tail light stuff..
  25. #75 Re: GSSE Checklist
    I got it working. There was a jumble of wires I "threw aside" the other night and didn't even bother to look at them. Had both the wires I needed.
    Got the tires aired up for the trip and made sure all other tire pressures were good. She's ready to go! Wake up, get some Tim Horton's and ship on out!!
    Probably going to relocate some of the lights, but it'll do.
