Jeeptech's SAK (swiss army knife) XJ build FINALLY 4X4 - Page 5
Thread: Jeeptech's SAK (swiss army knife) XJ build FINALLY 4X4
Page 5 of 22 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 527
  1. #101 Re: Traitor.. Jeeptech's 01 XJ build
    I saw yours when you did it. Looks good! I gotta say Im stoked about how well they came out. Another tech walked past and couldnt even figure out what I did to it. He knew something was up by the pile of metal on the floor though.
    2004 Ford Lightning
  2. #102 Re: Traitor.. Jeeptech's 01 XJ build
    That took a lot of convincing
    I've never liked that extra bit of metal down there. The quarters look a lot less bulky with it folded up. How much clearance do you gain behind the tire?
  3. #103 Re: Traitor.. Jeeptech's 01 XJ build
    Beaumont, Texas
    Pics mang pics
  4. #104 Re: Traitor.. Jeeptech's 01 XJ build
    I guess I gained a bit of clearance except now the tire will come up to more of an edge. All the metal is rolled in though so it shouldnt hurt the tire at all. Im gonna seam seal it and rosette weld all the panels up in the next day or two but when I get tires I may revisit the rear wells and open them up some more and redo the outer section of the wheel tubs.
    As requested..
    What do you guys think. I'll be building a bumper that wraps around the sides.
    2004 Ford Lightning
  5. #105 Re: Traitor.. Jeeptech's 01 XJ build
    Feb 2010
    Orlando Florida
    Looks nice and clean.
    I don't have a lot experience with vampires, but I have hunted warewolves. I shot one once. But by the time I got to it, it had turned back into my neighbor's dog.
    -Dwight Schrute
  6. #106 Re: Traitor.. Jeeptech's 01 XJ build
    Beaumont, Texas
    a liitle black paint and it will look bitchin.
  7. #107 Re: Traitor.. Jeeptech's 01 XJ build
    I was gonna use some red factory matched stuff but I figured the bumper would back up to it and be sprayed in bedliner so it would look stupid so after all the finishwork and seam sealer I sprayed it with the same bedliner as the front bumper. It came out sharp! I was just about to start masking off the fender lip and a good ole Florida thunderstorm rolled up and shit on my productive day. Oh well I still got alot done. I'll post some finished pics later this week when the fender lips are done.
    2004 Ford Lightning
  8. #108 Re: Traitor.. Jeeptech's 01 XJ build
    Ok I finished all the finishwork to the rear quarters and it looks good. Hopefully I'll be starting on some new projects this week.
    My list of to-do's before the LS swap is as follows:
    repair front clip and paint grille
    8.8 swap
    33's
    front middle and rear stiffeners
    rear bumper w/ integrated hitch
    truss refurbish and install HP30
    I also realized a flaw with my cardboard tire.. I didnt take into account the loss of height due to the tire bulging roughly 3/4" under the weight of the rig. So I fixed that and my uptravel appears to be a bit more doable for the time being.
    Gonna build a small shield or mod the stock one for the filler
    2004 Ford Lightning
  9. #109 Re: Traitor.. Jeeptech's 01 XJ build
    Senior Member dp96zj's Avatar
    Texas
    Damn that looks great. Very clean work, like always!
  10. #110 Re: Traitor.. Jeeptech's 01 XJ build
    Beaumont, Texas
    Damn dude thats looks nice. Wish i would have taken more time to trim my fenders and surrounding areas. It was like 3 in the morning and the dremel died so I just used a grinder.
  11. #111 Re: Traitor.. Jeeptech's 01 XJ build
    Seattle, WA
    I like it
    You should add to that list of to do's a real front axle to go with that transfercase you installed Just sayin you might want 4wd in that purdy Jeep...
    I collect Jeeps.
    The Polar Bear Detailed Build
  12. #112 Re: Traitor.. Jeeptech's 01 XJ build
    Sexy. You wanna come to cali and cut my quarters and weld em up??
    Will
  13. #113 Re: Traitor.. Jeeptech's 01 XJ build
    Thanks! Anal retentiveness struck again LOL.
    Body saw, die grinder with 36 grit sanding disc, and a shitload of masking tape
    I like it
    Ha yea I forgot about that. I plan to have the 30 trussed up and under there before the swap so I dont have to guess front ds clearance. I havent put it in yet since Im afraid I'll be too tempted to wheel it. I know if I wheel it it will = demise of wounded 4.slow. Right now it just goes to work and back which is all highway and very little traffic so as long as I change the oil/water crankcase mixture every 2.5k it is happy. For some reason it is not intermixing the two and making milkshake. Not sure why honestly but I have never seen a 4.0 intermix with a hg or head issue.
    Cali.. hellz yea! I'd love the vacation. Lemme know if you need an address to send the plane tickets to.
    2004 Ford Lightning
  14. #114 Re: Traitor.. Jeeptech's 01 XJ build
    Haha yeah man that looks great! The previous owner of my friends Cherokee did that, but not nearly as clean. It's a great increase in clearance though!
  15. #115 Re: Traitor.. Jeeptech's 01 XJ build
    Thanks! May have to boatside after lookin at all your newfound ground clearance.
    2004 Ford Lightning
  16. #116 Re: Traitor.. Jeeptech's 01 XJ build
    Well its been a rollercoaster of emotions for me this past week. The Buick is finally sold and for a good price but I'll be a bit disappointed to see it go. Alot of positives come from the sale though. I bought the wife a super nice "pre owned" low mile Explorer to replace the other one. I also was able to pay off some bills and show the XJ some love. Now I'll also have more time to dedicate to my family and hopefully soon wheelin with my son.
    So with my slice of the pie I ordered a ruffstuff 8.8 bracket kit, ruffstuff 8.8 diff cover, H.D. offroad front middle and rear frame stiffener set, and 4 285 75 16 Guarddog MT's from treadwright. WOOT!
    The 8.8 bracket kit and diff cover from Ruffstuff came in today. Awesome discounted price, high quality parts and fast shipping!! This stuff is pure beef. Still waiting on the other stuff but I should have it all by the end of next week. Progress pics should follow soon.
    2004 Ford Lightning
  17. #117 Re: Traitor.. Jeeptech's 01 XJ build
    Nov 2008
    RI
    I cant wait to hear how you like the guard dogs
  18. #118 Re: Traitor.. Jeeptech's 01 XJ build
    Glad to hear the Buick sold for a decent price and you're getting to spend time with the family.
    Ruffstuff parts are very nice and customer service is always top notch. Anything I haven't felt like making for my YJ has come from Dan. All of the stiffeners should help it hold up to a real motor
  19. #119 Re: Traitor.. Jeeptech's 01 XJ build
    Quote Originally Posted by Gb02WJ View Post
    I've talked to alot of people with them and done alot of internet searching so I think they'll be great. I promise a full report.
    Tks. Im feeling more and more like a responsible adult. UGH. It has its rewards though LOL.
    I'll def be purchasing more from Dan in the future.
    Im also working on a few other ideas to stiffen this thing up. More on that later..
    2004 Ford Lightning
  20. #120 Re: Traitor.. Jeeptech's 01 XJ build
    Santa Fe, NM
    Viagra? Cialis?
    Can't wait to see the rig with the new tires on it.
  21. #121 Re: Traitor.. Jeeptech's 01 XJ build
    Seattle, WA
    Bob has a few tips on how to stiffen it up.
    I collect Jeeps.
  22. #122 Re: Traitor.. Jeeptech's 01 XJ build
    Cant see the pic at work so Im assuming it isnt very constructive
    2004 Ford Lightning
  23. #123 Re: Traitor.. Jeeptech's 01 XJ build
    Well the Buick got loaded up last night and is headed to its new home in Va. It felt really wierd letting someone else hop behind the wheel. Well maybe not wierd.. more like someone kicked me in the balls so hard that I threw up in my mouth a bit.
    So I swept out the garage and cleaned out my parts stash both Jeep and Go fast stuff. I'll be putting stuff I dont need up for sale in the next few days to begin funding the ls swap parts.
    I spoke with treadwright today and it looks like the original 2 week eta for my tires was a bit off. They say that they should arrive in 7-10 more days. I can live with that as long as the quality of the product is as high as I have read.
    So right now Im kinda stuck since I wanted the tires on before I began any of the installs on the other stuff I ordered. Which has all arrived already.. go figure.
    2004 Ford Lightning
  24. #124 Re: Traitor.. Jeeptech's 01 XJ build
    Beaumont, Texas
    You are destined to roam the earth tireless.
  25. #125 Re: Traitor.. Jeeptech's 01 XJ build
    Whaddaya mean I still got my bald 29's.
    I tested the whole will the aw4 shift normally in 4lo today. Cant remember who was asking me. The answer is yes it does up to 20mph. Didnt go any higher.
    AFAIK the aw4 has no idea what range the t case is in and nor does it care.
    2004 Ford Lightning
