Thread: 6.0L WJ Build
Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 158
  1. #51 Re: DaveJeep's 5.3l WJ Engine Swap
    Seattle, WA
    Damn my man, you have done in a month what I have done in 10 haha!
    As far as the tach goes, as soon as I get it running I'll start working on the tach signal generator and I can make you one too.
    Per your question about the oil cooler, my engine didn't come with one. If it had I would be hard pressed not to try and use it. Within reason, extra cooling is better and oil gets into places and absorbs heat from parts of the motor coolant doesn't get to.
    I collect Jeeps.
    The Polar Bear Detailed Build
  2. #52 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    It runs!
    BUT I have a major trans leak between the transmission and transfer case. I'm pulling the case right now but have no idea what it could be. I know on the Jeep trans the rear output seal was sealed up by the input shaft of the t-case. On the 4L60E the reluctor ring is on the output shaft and there is no seal or no place for a seal on the rear of the trans.
    Any ideas?
  3. #53 Re: DaveJeep's 5.3l WJ Engine Swap
    How awesome is it that you just brought this up, I was looking at this thread not 10 minutes ago on how I want to notch my drivers side frame rail haha!
    http://agitatedpancake.com/random/je...p/dscn3990.jpg
    The rear of the trans has no fluid seal at all? That seems odd to me...
  4. #54 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Well it does but it's in past the reluctor ring. Maybe this trans has fluid in the tail end unlike others.
  5. #55 Re: DaveJeep's 5.3l WJ Engine Swap
    Seattle, WA
    Congratulations, let's see a video!
    I collect Jeeps.
  6. #56 Re: DaveJeep's 5.3l WJ Engine Swap
    Nice build. Noticed the 9" back there. Is that a CHP or a True9?
    Keep it up.
    Will
  7. #57 Re: DaveJeep's 5.3l WJ Engine Swap
    Quote Originally Posted by DaveJeep View Post
    It runs!
    Any ideas?
    On my 700r4/231 combo there was a gasket between the two from the factory. I put a bead of black rtv around the adapter and stuck the t-case on after it set up when it was still in the blazer (donor) and it never leaked. Did the same thing when I put it together again and it hasn't leaked yet. I haven't been able to find the gasket, but it hasn't been a problem.
    There is a gear-driven governer back there that gets trans fluid on 700r4s - apparently the 4l60es didn't get any additional seals.
  8. #58 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Thanks for the advice. I figured it out right after I made the last post though. No more leak!!!
    I have the front end all back on and most stuff taken care of except for the air intake, trans & t-case shifters. The stock GM throttle cable was a perfect fit. Even clipped into the fire wall just like the Jeep one.
    My driveshafts do have to be changed, rear is way too short, front too long
  9. #59 Re: DaveJeep's 5.3l WJ Engine Swap
    Senior Member SLO MO's Avatar
    Edmonton, Canada
    Keep it up.
    Currie.
    2K WJ 4.0L, 242, Rockcrusher60 front, Prorock60 rear 39.5" IROKS, Bold Bumper and Rocky Mountain Pinstriping
  10. #60 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Quote Originally Posted by SLO MO View Post
    Currie.
    Thanks, missed that post.
  11. #61 Re: DaveJeep's 5.3l WJ Engine Swap
    Edmonton, Canada
    No prob.
    How's it coming? Gonna be ready for May long?
  12. #62 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    No prob.
    I'm having troubles getting the t-case to seal to the transmission right now. I'm pretty much done though. It moves on it's own power now but still no exhaust on it till next week. I'll be done for May long for sure
  13. #63 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Well I resealed the T-case to transmission. Seems to be holding with the Mopar ATF-RTV so far. Built a transfer case cable bracket, cleaned up some wiring, mounted the coolant bottle and GM PCM, finished the coolant lines, etc. Did a bunch of other small things. Waiting on a bracket for my transmission shifting cable.
    I do have a trouble code that I need to figure out. P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage. One guy on LS1tech told me my cam bolts are loose but I highly doubt it. Said it was a big issue in the Vette motors.
    I have not checked to see if there's voltage at the CMP sensor yet though.
    Sorry no pics yet.
  14. #64 Re: DaveJeep's 5.3l WJ Engine Swap
    The cmp sens reads from the very back of the cam off of a vane that is machined in so I doubt it is loose bolts? Its possible you have a loose connection or bad sensor IMO.
    2004 Ford Lightning
  15. #65 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    I did have to loosen the sensor and rotate it a bit to get the oil pressure sensor in there but I put the hold down bolt back in and it's tight. Maybe I forgot to plug it back in lol
  16. #66 Re: DaveJeep's 5.3l WJ Engine Swap
    It will set that code if it is unplugged...LOL
    2004 Ford Lightning
  17. #67 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    It was late that night, that's my excuse if it's unplugged due to my stupidity lol
  18. #68 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Got all my little issues figured out and now the jeep is at the mufler man getting a y-pipe built. Gonna be driving it by tonight!
    I really gotta get some more pics.
  19. #69 Re: DaveJeep's 5.3l WJ Engine Swap
    what was causing the code?
  20. #70 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    hahaha Like I though, stupid me forgot to plug the cam sensor back in.
  21. #71 Re: DaveJeep's 5.3l WJ Engine Swap
    Mar 2009
    Connecticut
    i remember this jeep, things a beast. Keep up the good work. Nice to see someone doing something different
  22. #72 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    thanks
  23. #73 Re: DaveJeep's 5.3l WJ Engine Swap
    Edmonton, Canada
    Quote Originally Posted by flexxthese View Post
    You're probably thinking of Rizzo's Jeep. This ain't it. He had the same front bumper (that I helped build) but that's it.
    This one's all Canadian
  24. #74 Re: DaveJeep's 5.3l WJ Engine Swap
    Edmonton, Canada
    C'mon, need some pics Dave
  25. #75 Re: DaveJeep's 5.3l WJ Engine Swap
    Aug 2009
    Alberta, Canada
    Sorry buddy! Too busy driving it lol
    I will try and get some pics to night.
    Also ordered some 38x13-16 TSL Bias today
